Question about Haier Refrigerators
HAIER portable icemaker, model HPIM35W. Unit is brand new but ice being produced is not properly frozen and is watery.
ttech
  • 139 Answers
SOURCE: Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
I Have a Solution for this Problem,Contact live on line Now ttech
Posted on Jul 21, 2007
dididsaythat
  • 291 Answers
SOURCE: Hotpoint HSS25GFP icemaker stopped working
are u sure that model # Is right.. DOnt come up in any of my model data bases Seems like u might of got a bad icemaker.. if the water is coming into the icemaker from the water valve.. icemaker has to have power, to do that... all funtions after that would be controled by the iceaker .. The only other thing i can think of is your refrigerator has to be a certain temp to activate icemaker somewhere around 0 give or take some to be safe
Posted on Aug 21, 2007
fridgetech
  • 473 Answers
When you open the freezer door the light should be blinking. When you hold the flipper door shut (on the left hand side) without blocking the beam, the light should stay on solid. If all of this happens then the optics are o.k. If optics are ok then you most likely have a broken motor module on the icemaker and should replace the icemaker thermostat along with it. A bad icemaker thermostat will lead to the module breaking. If you not sure how to replace these parts then I would just replace the whole icemaker. That would be easiest and usually not much more expensive.
Posted on Nov 07, 2007
fridgetech
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
abhishek33
  • 1239 Answers
SOURCE: Icemaker not producing ice at all. Tried all the
hi
it is the compressor problem ..check it
thank u,,//please rate it
Posted on Jul 04, 2009
How do i fix my whirlpool icemaker it seems that it gets stuck half way into icemaking and does not produce ice.the model is ed5hhaxv002 it is very frustrating i havce tried a blow dryer to heat the r
Your rubber tube is most likely not freezing up and therefore does not need to be heated but only you would know for certain. My experience with ice makes spans several different models but I've found the most common problem for me with no ice being produced is when the bar that shuts of the icemaker gets stuck in the up position because - ice cubes have frozen into a big clump, Ice cubes have jammed the bar by sticking between the ice tray and the bar, or the gear inside that rotates the ice cube tray is stripped in that area because of previous jams and needs to be replaced.
Dec 01, 2014 | Whirlpool Refrigerators
Whirlpool model # ed5vhexvq1 side by side ...ice maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
Model FGHB2846LF3 ice maker not working
The ice maker has a heater element underneath it that is designed to melt the ice a little bit so that the fingers of the icemaker can scoop out the ice. If the element does not turn off and the fingers do not push the ice out it will melt with the result that you have. Appears that the cam conducting the operations is not working properly. Rather than buy this part separately (expensive) you can get a new working icemaker on ebay for about 45 dollars and you can easily install the unit yourself.
Nov 27, 2013 | Frigidaire FGHB2846LF
My Scotsman undercounter icemaker is not producing much ice and the little it does produce is watery. How do I fix? The model # is DCE33PA-1WB. Is this model discontinued?
Wow! That the first time I saw one of these! Never even knew they made it under
counter types.Anyway I'll give it a shot,Let's see here It's not producing ice as it should huh? I Googled it for complaints and found this for you,Linda go to
(http://www.retrevo.com) and once you get there type in (Scotsman DCE33)
into site search engine and it'll list service manuals for your model to seek a fix.
It stated how to make maintenence adjustmments ok now good day!
Jan 02, 2011 | Scotsman 15" Luxury Consumer Ice Machine
Does not make enough ice
Ice machines are rated in pounds per hour. They usually have an arm paddle switch that tells them when they are full or a weight switch that works the same way.
If possible, transfer the produced ice to another container when the machine is full and allow the unit to keep making ice.
This assumes the machine is working properly and that the cubes are solid. (frozen and not watery).
Dec 07, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
U-Line co29ff, brand new unit. Makes clear, hollow, watery ice.
2 things you need to check. If you remove the icebucket look for armaflex the goes on the sensor tube from the icemaker to the back wall. If missing call U-line to get the correct one. The second thing you can do is check the icemaker control. Remove the grill, on the base in the right corner you will see a control with a screw. Turn the screw all the way to the right then back it so it will be straight up and down.That will set it cooler
May 10, 2009 | U-Line Refrigerator Ice Maker
RS2630SH icemaker slow production
Had the same problem. This allows 12 seconds for the tray to fill. If your water filter is the least bit dirty or the water supply line is clogged a bit, you will get an incomplete fill and the cubes will be hollow, mishapen, or, in my case, all won't eject properly. Replace your filter. If that doesn't do it then use a shop vac with any kind of modification to it that will fit into the supply line and **** out the blockages. Hope this helps.
May 27, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
167 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
