Paper doesn't get pulled in when trying to print. only right side goes in a little bit and then get message that there is no paper
  • 147 Answers
Most likley a dirty pick up roller Remove the paper and with a damp cloth, clean the main pick roller with a side to side motion. Also check on the left side for debris that could be impeding the paper path (previous jam torn out incomplete)
Posted on Jan 03, 2011
When i turn the printers power button on a little yellow light comes on and the printers sound goes off.
If a yellow light comes up that means something might be stuck inside of the printer because i have 2 or 3 printers the same a little bit as your's
  1. Unplug the power cord.
  2. Check to see if the print carriage moves freely from one side of the printer to the other. ...
  3. Remove the print cartridges. ...
  4. Gently move the print cartridge to the far right of the printer.
  5. Remove the paper from the paper In tray, but do not remove the drawerimages?q=tbn:and9gcql4vvqpurkyfvqqmw9rwhtdflbrbabxkdolb-lu_srxwwin5o-9q
Jan 15, 2016 | Canon PIXMA Office Equipment & Supplies
Tip
HP LaserJet LJ 4350 locks up when duplexing
Symptom: Your LaserJet 4350 prints just fine until you try to print a double-sided page. Then you see the page start to exit, pull back in, then stop. The Data light continues flashing green, and the display reads, "Processing..." There is no error indication, but the machine won't print the second side and continues to hold the half-printed paper in the duplexer. If you open the top cover and close it again, the printer will eject the page, then try to print the whole thing again, unless you're quick enough to cancel the job first.
Cause: The printer is expecting a different sized paper than what it's running. Often it's not the menu settings, but a little lever in the paper tray itself. Pull out the paper tray you're trying to print from and look for a little blue lever on top of its right-hand side. The lever is labeled "Standard/Custom." Flip it to Standard (parallel to the tray side) and your problem should go away.
on Mar 17, 2010 | HP LaserJet 4350dtn Printer
Getting message that I have a paper jam but there isn't on to be fpund
Try checking the printer for foreign objects that might be interfering with the paper path. Tilt the printer sideways and try shaking it a bit. After that, try printing. If the issue persists, clean the rollers of the printer.
Dec 13, 2012 | Lexmark X4850 WIRELESS All-In-One InkJet...
I have an epson printer and when I hit print, the paper slides right thru & says paper jam
  • Carefully remove the jammed photo paper. Gently pull the paper up and out of the paper feeder tray.
  • 2
    Reload the paper into the tray. Stack the paper on a flat surface and then carefully slide the paper stack straight into the paper feeder tray---along and aligned with the right side of the tray. Secure the stack in place by sliding the left "edge guide" against the paper stack.
  • Sponsored Links
  • 3
    Press the "OK" button to resume printing. If you had a "Paper is jammed in the printer..." error message displayed on the control panel LCD, pressing "OK" should also clear the message.
  • 4
    Pull the paper from the printer, if the status message reappears and/or the printer doesn't print, and check the paper for folds, buckling and curled edges or corners. Also check the sheets for sticking. If any of your sheets stick or have damage, remove them from your photo paper stack and replace with new sheets. Reload the paper and press "OK" to try again.
  • Performance Chip
    May 22, 2012 | Epson NX415 All-In-One Printer
    Error message to "Load Paper"
    Push something thicker than a plain sheet of paper through. Cut a side of a manilla folder into a 8.5"x11" and let the printer try to grab it during a copy. After doing it's normal "grab the right side until it's skewed and stop", continue to try to push it through.
    Nov 30, 2011 | Canon imageCLASS® MF4150 All-In-One Laser...
    Printer says error 6000 printer mx320 series
    According to you this error indicates that the purge unit is not giving the correct timing signal as it rotates inside 360 degrees. Therefore, something is either broken or jammed inside. If you had a paper jam and tried to forcefully pull it out, you could have pulled the internal gears out of alignment. If it doesn't help you then open the printer cover and when the carriage head moves to center pull out the power cord. The Purge unit is on the right side. Use a flashlight and you will see two ink pads. This is where the print-head is PARKED and is the top of the Purge unit. There you will find wiper blades that move from the rear to the front. They wipe the bottom of the print-head when it is parked.
    Use some rubber gloves and a paper towel and see if you can press the ink pads down just a little bit - about 1/4". See if for some reason the wiper blade is stuck extended; if so see if you can get it unstuck. Please do this gently such that you don't break anything there.
    So you will need to do some maneuvers to try to release the cartridge from its parking position. Again, don't try hard. It will help you.
    Jul 06, 2011 | Canon Office Equipment & Supplies
    Printer pulls paper to right side jams does not print
    usually this indicates some foreign object on the opposite side where the paper goes in. Please check to see if you have some small pieces of paper or something else in the paper path area.
    also, another possibility is that your pickup roller is missing, dirty or damaged. try cleaning it too.
    thanks adi
    Dec 01, 2009 | HP Deskjet 3845 InkJet Printer
    HOW DO I REMOVE JAMMED PAPER
    Please turn the printer Off and then ON , till you see the error message of " Paper Jam" check all the flags on paper path, specially on Fuser Assembly.
    Turn printer OFF, pull all trays out gently,
    Disconnect cables to network or PC. turn printer ON,
    check the message gets repeated - paper Jam,
    Conclusion : There is some bit and piece of paper activating flags,
    take all toners out gently and transfer Drum, look into printer, and
    lift the paper path under the toners, push the door a little bit and unscrew the paper path and can see a piece of paper on right side..
    Pull the paper out and screw bach. put every thing back in their original status.
    Now the printer will work and there will not be any papers..
    Jul 31, 2009 | HP Color LaserJet 2600n Printer
    Paper jammed but no paper is jammed.
    Sounds like something has fallen into the paper path. Use a flashlight and small mirror to look down the slot where the paper goes. You may have to use a straightened paper clip or the like to help remove the obstruction.
    Jun 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
    White scratches and a "breaking" mark on printout
    Epson CX11NF printer problem-repair solved
    To clear stripe....Open the front cover and look on the inside of the right side of the printer....There you will see a pictorial instruction showing the PRINTER HEAD cleaning procedures.
    Follow them (remove tab/plug on right side, pull out on head lock arm on inside right, then fully pull out the printer head arm inside the port on the (outside of printer) right side.....Then push it back in, replace tab cover, push the lock back in (inside right-front) and problem solved.....
    God Bless,
    Happy Epson CX11NF User
    Oct 14, 2008 | Epson ACULASER CX11NF All-In-One Printer
    19 people viewed this question
    jasbo
    jasbo
