Question about Westwind Classic Hugger Polished Brass 52" Ceiling Fan
Ceiling fan has the normal black blue white wires. The ceiling has orange yellow and grey. What connects to what?
  • mjlehto536 Jan 03, 2011
    It is a single family house 7 years old in a suburb on chicago. I really doubt it is 277/480, but I'll take your warning and probably waste 250 dollars on a electrcian for a simple hook up. I guess it's better safe than sorry, but I don't really have the money.
  • 3,287 Answers
Do NOT attempt to connect this fan to this ceiling box!
In the USA, a color code is employed to quickly alert the electrician about the voltages found in circuits. Black, red & blue insulated wires with a white colored neutral wire indicates a standard residential 120 / 240 volt system. Brown, orange and yellow wires with a gray colored neutral on the other hand, indicates a common commercial or industrial 277 / 480 volt system.
Since I don't know where you live, but it could be the USA (or other country that also observes this color scheme for system voltage identification), I urge you to contact a qualified electrician. If you insist of checking it out yourself, please exercise EXTREME caution. Accidental contact with 277 volts will burn and most likely kill in an instant.
If it is determined to in fact be a 277 / 480 volt system, the fan you selected will not be able to be connected to this circuit as it is a 120 volt fixture. Connection will result in damage, fire or worse.
I hope this helps. Please rate my reply - thank you!
Posted on Jan 03, 2011
  • 2 more comments
  • Steve Jan 03, 2011
    Sorry about having to call an electrician.. no one here can tell you how to make the connections based solely on the color of the wires you mentioned. It does sound odd to have those colors used in a residential setting - I certainly wouldn't sleep very well had I told you to simply connect this color to that and something happened to you. Check around with others in your neighborhood - maybe they can shed light on the colors used for you.
    Steve
    One last tidbit - IF you're on a 120/240 volt system with that color scheme, the gray wire would be your neutral, and both the orange and yellow wires would be your line (or "hot") wires. That is, a meter connected between the orange and yellow would indicate 240 volts (or 480 if a 480/277 system) and yellow to gray or orange to gray would indicate 120 volts (or 277 if a 480 / 277 system).
    Continuing from above - You're probably on a 120 / 240 system, and the electricians in Chicago used a color code used to indicate the 277 / 480 system for whatever reason. You need to use a meter (or wiggy) to check though. A test light won't tell you the voltage, and could blow up if not rated for the higher voltage system. Your connections would be between the gray and either the orange or yellow wires to yield a 120 volt circuit. It is also possible that one of those wires is on constantly while the other turns on and off with a switch in the room. But again, you must check with a meter or wiggy, first between the gray to the other two with the wall switch on then off.
    If the wires are determined to be set up as one on constantly, the other controlled by a switch - you could connect the "switched wire" to the fixture light wire (blue), the fan wire (black) to the "always on" wire and the white to the gray wire. You could replace the wall switch with a dimmer if you wanted, too. Make sure the switch or pull chain for the light on the fixture is "on" (and then removed to prevent accidentally turning off) otherwise it will never come on with the wall switch. The fan would be controlled solely by the pull chain for on / off
Need a wiring diagram for a hampton bay ceiling fan
most of the manuals have wiring instructions - check out any one of the manuals here
Jul 12, 2012 | Hampton Bay 24002 Ceiling Fan
Wiring diagram for harbor breeze celing fan
The colors of the wires in the Harbor Breeze ceiling fan kits tell you what their functions are. The black wire is hot for the fan, the white is a common wire for both the fan and the light kit, green is ground and blue is hot for the light kit. locate the black and blue wires from the ceiling fan and connect them to the black wire inside the electrical junction box by twisting an orange wire connector onto all three wires. Locate the white wire from the ceiling fan and the white wire from the junction box and attach the two wires together with a wire connector. Connect the bare copper wire onto the green wire from the ceiling fan mounting bracket by twisting an orange wire connector onto the two wires. Push all wiring inside the electrical box. good-day !
Nov 26, 2011 | Hunter 52" Ceiling Fan With Light And...
Wiring diagram for a 3 way ceiling pull switch.
These fans are manufactured by a number of overseas companies and sold exclusively by Home Depot. They do not have a standard color code for the fan switch. What you can do is turn off the power, keep the white neutral connected. Then using the black power wire fro the ceiling, take one of the switch wires and connect to that black, turn the power on and observe the speed .. low mark it 1, medium mark it 2, high mark it 3. Repeat untill you have identified all the speed wires. Then connect these wires to the 1,2,3, terminations of your new switch
Questions?
Please Vote !
May 29, 2010 | Hampton Bay 24750 Huntington III Ceiling...
I have four wires from the ceiling fan black white blue orange just 3 wires from the ceiling box white black and ground how do I wire it?
Try hooking up without the oprange , connect the white to white ,.. and the house black to the fan black and blue. The ground will connect to any green or bare wire, and also to the fan mounting bracket
May 18, 2010 | Hampton Bay 24002 Ceiling Fan
Ceiling Fan
Green is always equiptment ground. It goes to the green wire ,if you have one in the electric outlet box,or mounted to the box itself itf you have not the green in the box.
Green always  to green White to white. Nutural wire. Orange to black if their is no black in the box. Orange =Black
I am also thinking that you blue will is also the positive for the fan. I woudl hook it to your orange also .  .
Jan 05, 2009 | Hampton Bay 24002 Ceiling Fan
Ceiling fan wires
is the old fixture still installed?
Oct 16, 2008 | Hampton Bay 24002 Ceiling Fan
Ceiling fan wiring
blue would be your earth.
black and white are phase and neutral.
for the wiring in your roof you need to call a local sparky. just ask which is which and connect them appropriately.
Sep 01, 2008 | Hampton Bay 24002 Ceiling Fan
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Westwind Classic Hugger Polished Brass 52" Ceiling Fan Logo
212 people viewed this question
Top Westwind Dryers Experts
Dan Webster
Dan Webster
Are you a Westwind Dryer Expert? Answer questions, earn points and help others
