Question about Ulead Videostudio 8 for PC
Recording with easy cap 2.0
I got my easy cap 2 days ago and ever since I have been messing with it to try to get it to work. I have my 360 and the easy cap cables joining into splitters which connect to my video 1 slot on my tv ( since i dont have a monitor out slot) now when I start unlead 10.0 and I go to the cature video area the preveiw screen is blank, now I have occasionally been able to get my TV image on the preveiw screen but as soon as I move my character in my video game the preveiw screen freezes immediatly, 1 single time long ago the screen did not freeze but it was choppy and laggy as hell. I have un and re-installed the driver and unlead 10.0 many times, replaced the splitters and rca cable thing....and tried many so-called solutions but all were in vain. I run a windows vista laptop and am in desperate need of advice...PLEASE HELP>>> you can also email me...bplacs14@yahoo.com
    Champion:
  • 258 Answers
Re-Installing and removing does not remove everything from your REGISTRY. If you Install something then uninstall it you will be left with info in your registry therefore you r reintalling on same info vista has
Posted on Jul 30, 2008
Xbox 360 freezing and red ring flashing
Im sorry bout the xbox, trust me i know how it feels for a system to mess up and ive read the Xbox 360 flashing red, is indicating some major trouble is about to go down.
sorry for the bad news.
i hope i have helped!!!!
Jan 05, 2010 | Microsoft Xbox 360 Console
Xbox has no picture but sound works fine.
Hi, this is an internal problem, please send your console to microsoft if under warrenty.
Jun 16, 2009 | Microsoft Xbox 360 Console
360 CONTROLLER WONT TURN ON
Try taking out the batteries and then cleaning the inside. Then put in new betteries and make sure everything is plugged in and secure correctly.
Apr 05, 2009 | Microsoft Xbox 360 Controller
Ford F450 motorhome will not start
It may be the evap system. Could be as simple as the gas cap. try taking the gas cap off and starting it. If it starts then its the gas cap causing a vacuum. if not, then it could be:
1. Fuel filter.
2. Fuel pump. undo the fuel pipe into the engine and check to see if fuel is being pumped. disconnect the coil lead so engine doesn't start. Be very careful and make sure you put a container to capture the fuel.
3. If fuel is being pumped, then it could be the purge valve and/or vapor cannister. If these are faulty, it could cause a vacuum and vapor lock.
frankly, the fuel system isn't something you want to mess with if you are not a qualified mechanic.
try these easy forms of diagnosis to see if the gas cap is causing a vacuum, or if your brave enough, try the to see if the fuel is being pumped into the engine.
Good luck
Oct 03, 2008 | 2004 Ford Super Duty F 450
Engine Light/tighten fuel cap
Good Day,
Sounds like your fuel cap needs to be replaced, there is a rubber seal in there to which keeps fuel pressure up, when this seal goes bad you get a drop in pressure and your engine light will come on. Replace the cap with a new one. As far as your lighter ports that is probably due to a blown fuse and unrelated to the fuel cap issue.
Hope this helps
Sep 10, 2008 | 2005 Chevrolet Silverado
My stiletto records for about 18 minutes then stops
Daylight savings time change a few months ago messed up the timer recording schedule - you must now fix it. Daylight savings time changes will always mess up this recorder. You must reset your recording schedule.
For more info on fixing, go to:
http://shop.sirius.com/edealinv/servlet/ExecMacro?nurl=control/StoreItem.vm&ctl_nbr=2640&siId=1745656&catParentID=7874&scId=7874&oldParentID=&cid=SL100PK1
2 other remote possibilities:
If no signal is present at the time the recording is scheduled to start, the recording will be skipped.
Make sure you have followed all instructions on pp. 55-58
-Tha Mp3 Doctor
Jun 03, 2008 | Sirius STILETTO 100 MP3 Player
Stiletto only records for about 18 munutes
-Tha Mp3 Doctor
My Subs blew out but I dont know why??
rewire the whole system with new wires,you could have a bad ground or wire try it first if that dont work rewire
Jan 08, 2008 | Jl Audio 12W3 Car Subwoofer
Cannot write from HDD to DVD
I also shipped in my xbox 360 into microsoft and they told me that they have such a high demand for the 360 that they needed to have 3 different manufacturers handle their dvd rom drive assembly.....the rep told me that it seems to be that one of the companies who mad the dvd drives isnt up to par with the requirement of the system....so theoretically if 3 million copies of the xbox 360 were made...and 1 out of the 3 companies messed up (1/3) 1 million xbox 360's should be malfunctioning....a HUGE problem....i sent my in before the masses and then there is no telling how long it would take so my suggestion is to send it now dont wait to see "if" they could solve it some other way just spend the week or 2 with out your precious xbox to ensure its working condition because they can only fix it before your 90 day warranty runs out.....
Nov 15, 2007 | LG RH1999H DVD Recorder/HDD Recorder
XBOX 360
The problem is probably that you have put the cords in the wrong places or have used the wrong cords
Nov 13, 2007 | Microsoft Xbox 360 Console
Ulead Videostudio 8 for PC Logo
724 people viewed this question
Top Ulead Computers & Internet Experts
d3yavu3
Alun Cox
Karan Sethi
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
