Question about John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
Turns over but will not fire. Coil is good, carburator has been cleaned, new spark plug, battery O.K.
NEW COIL STILL WONT FIRE WHATS WRONG
Posted on Mar 02, 2011
98 harley fatboy turns over but wont start
some after market ignitions don't spark on the first couple of turns but first take off your air cleaner twist the throttle and look to see if gas is spraying in the carb if not give it a little starting fluid if it fires but then dies then its carb issue. now other thing to check is if you have three posts on your coil then its single fire and your plug wires might be going to the wrong spot switch um around.
May 09, 2014 | Harley Davidson FLSTF Fat boy Motorcycles
Recently purchase a non running 03' 883cc. with 10k. miles, I change plugs, wires, ign. coil, cleaned the carb. replace all fuses, main fuse, starter relay, new battery fully charged, checked all wires...
What the VOS does is controls spark advance, it will NOT cause the spark plug to not fire.
You said no spark.
I assume at spark plug?
Did you check for fire at coil?
When you replaced coil, did you wire it correctly?
Did you use the right coil? Different Harleys require different Ohm coils.
If all above is good, follow wiring back to find why no fire.
Mar 04, 2014 | Motorcycles
1993 klx 650 wont start
some bikes need a certain amperage from battery for the pickups to work, is battery good, and correct type
Feb 14, 2013 | Motorcycles
1993 Nissan 300zx: Number 4 cylinder doesnt fire.
Please read about misfire diagnosis and repair here.
Oct 01, 2012 | 1993 Nissan 300ZX
2000 YZF R1 ONE DAY I SAW THAT BATTERY WAS SWOLLEN. REPLACED BATTERY WOULDNT START
Hi, Merle and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and CDI box.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose, check for spark leakage in the dark.
6. Faulty ignition coil, pick up coil, trigger coil or CDI box testing needs to be checked with an ohmmeter at 70 degrees Fahrenheit
7. Faulty safety switches clutch, kickstand, neutral, off/on etc.
8. Faulty ignition switch.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/102-00-01-r1-mechanical-help/287594-2000-r1-wont-start-no-spark.html
http://www.r6-forum.com/forums/57-garage-mechanical-help/38102-00-r6-turns-over-but-no-spark.html
2000 2001 Yamaha YZF R1 Service Manual R1 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Aug 21, 2012 | 2000 Yamaha YZF-R1
75 John Deere 2030 gas tractor will not start. Changed plug wires, plugs, drained tank, new gas, new battery, new coil, new wires, getting spark turns over but does not fire.
first thing is to test and see if it is firing,if so clean out the carberater.
make shure all moving parts are clean inside and out,flotebowl,neddle valves,and jets should be
free of gunk and allow good flow of gas.
Jun 25, 2011 | Garden
1989 chevy truck, 5.7...will not start....no fire at spark plugs, Bat. voltage at ignition coil and to ignition module, tested ignition coil (OK), new distributor and rotor, no change. Used starting fluid...
Hi, I believe there is a computer problem. If possible check codes for no start condition. if you know the no.#1 cylinder at TDC (Top Dead Center) on engine then you will know no#1 distributor is. Good luck.
Jun 14, 2011 | 1989 Chevrolet C1500
My bike turns but dosent get the spark to fire up
Quite often I've found on older bikes the coil can become corroded.  I would begin by taking apart all the electrical connections between the battery, ground, the plugs themselves, the coil, and the generator, and giving them a good clean.  Most of the time I've found, that should eliminate your problem.  A good way to troubleshoot this is to jumpstart the bike.  If the bike will start (i.e. has spark) while jumped, but will not run when you disconnect the jumper cables, it is most likely a corrosion problem somewhere in your system.
Good luck with your bike!
May 26, 2009 | 1985 Yamaha XJ 700 X Maxim
Not getting spark when engined turns
Suspect failed crank sensor. Sensor is located on left rear of engine and mounts into the bell housing fro the transmission. Common problem for this vehicle.
Apr 11, 2009 | 1999 Jeep Grand Cherokee
1196 chey blazer
overheating could be caused by a stuck thermostat or a clogged radiator not firing on #1 plug could be a fouled plug or bad wire or it may be grounding on the block and your coiil may not have been put in at the right mark
Aug 09, 2008 | 1996 Chevrolet Blazer
John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter Logo
930 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
