Question about Roper RGX4634KQ Gas Dryer
Dryer wont heat up just spins keeps spinning with timer set. replaced heat element and still wont dry
  • Roper Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
l;
Posted on Mar 18, 2011
SOURCE:
Ml1987295
I will assume that you have cleaned the lint trap and checked that there is no lint stuck in the lint trap cavity
First, check the dryer vent. Any blockage anywhere in the vent will stop air flow. A dryer needs air flow to dry. Check every bit of it, even where it goes outside.
if that isn't the problem, then check your electrical connections. Your electric dryer runs on 220 volts, but it's really two wires carrying the electricity to the dryer at 110 volts each. If one of those wires isn't connected, the dryer could still turn on and spin, but it won't dry the clothes.
I learned that the hard way going through 2 dryers. Turned out one of the fuses in my apartment's fuse box had blown, but 2 fuses made up the 220v circuit. The dryer would spin and would work a little bit on low settings, but any other setting it would just spin and not dry at all. Replacing the fuse fixed the issue. With a breaker box, the 220v double breaker is connected, so if one trips, they both trip, and it wouldn't spin or turn on at all.
So check the socket with a multimeter (or have an electrician check it) and unplug and check the dryer cord making sure each connector is securely screwed in to the panel on the back. There is typically an access panel on the back of the dryer right next to where the cord goes in that you have to take off to get to the connection panel.
The last thing I would say a DIYer could look at is the heating element. If you take the back off, you can access the heating element and see if there is any lint or debri in there... if there is, clean it out and try the dryer... if it still doesn't work but there was debri in the heating element's channel, it could have burnt up a safty sensor that shuts the heating element off when it senses too much heat (fire, or potential to cause a fire) I suggest using and appliance repair man at this point.
Jul 31, 2014 | Whirlpool Dryers
Not catching lint or drying clothes
Hi Diane
Sounds like you have a clogged vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Bud
Oct 12, 2013 | Maytag Dryers
Dryer wont stop buzzing
follow this steps and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and need replaced. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. replace the heating elements
Jul 09, 2013 | Dryers
Dryer heat fails intermittently
Probably an intermittent timer, not the heating element.
Jul 26, 2017 | Maytag Neptune MCE8000AY Electric Dryer
Fer211as heats but wont dry! heating element comes on but kicks off after gets to temp then element will not come back on unless stopped and restarted?
Runs but will not heat
1.loose wiring--check terminals & wiring
2. Defective thermostat--replace thermostat
3.defective centrifugal switch in motor--replace switch (check linkage to motor)
4. Defective timer--replace timer
5. Open heater element---replace heater element
6. Heat switch set to off----set switch for desired heat
Sep 22, 2011 | Frigidaire FER211A Electric Dryer
I have a kenmore dyer model #10070602990, the dryer spins, but it does not heat up. what could be the cause?
thermal fuse, heating element, timer, or thermostat:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Here is another website that is helpful:
http://www.applianceaid.com/general.html#timers
Feb 16, 2011 | Kenmore Dryers
Dryer will spin but not dry , heat element is fine
Try replacing the high limit switches if the element is fine. The limit switches will not allow power to the heat strips if they are blown. They are the little silver buttons on the heat strip. There are usually two wires connected to them one coming from the controls and one from the heat strip itself
Dave
Mar 05, 2010 | Magic Chef CYE4000AWW Electric Dryer
Whirpool amana dryer runs but no heat. on timed try timer doesnt move either.
HI, the timer motor is malfunctioning. this can affect the way you dryer heats in this case. I would advise to check the thermal fuse before replacing the timer. it is located on the blower house or, on the vent duct. in will show no continuity if defective. replace the timer if the thermal fuse is showing good continuity when measure with a meter.
Jul 24, 2009 | Whirlpool LER4634J Electric Dryer
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 20, 2009 | Roper REX3614KW Electric Dryer
Roper RGX4634KQ Gas Dryer Logo
300 people viewed this question
Top Roper Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Dennis Boxerman
Are you a Roper Dryer Expert? Answer questions, earn points and help others
