Question about Brother IntelliFAX 4100 Laser Fax
Brother business class laserfax 4100 getting inconsistent send errors such as line NG, not every time, but often enough. Over a period of months now, seems to be more frequent.
Getting a triangluar warning on display
Posted on Mar 03, 2011
Intellifax 4100e ..not receieve fax
Look at the front door that you open when you change the toner/drum. You will see that it has not closed properly at one end. Give it a gentle whack and the error should go. Very common problem as the catches can be stiff.
Mar 11, 2014 | Brother Intellifax 4100 Business Class...
Error Code 77 on brother 4100 fax intelifox business class
( 76 Heater harness disconnected or broken. Or heater thermistor harness
disconnected or broken when the power is turned on, the front cover is
opened and closed, or the machine exits from the sleep mode. )
( 77 Power turned off and on at the occurrence of error 76 or 78. )
( 78 Heater thermistor short-circuited. Or heater thermistor harness disconnected
or broken when the machine is on standby. )
Nov 05, 2010 | Brother IntelliFAX 4100 Laser Fax
Brother Inellifax 4100e will not send
It appears that you have interference somewhere in the office. Have you recently gone to DSL in the office? A DSL line transmits a signal that requires a filter to receive only phone signals instead of the DSL signal. If the fax machines are receiving an unfiltered DSL signal, this would explain the interference. If this is not the case, the link below is a Brother's Solution to the NG Poor line quality. Best of luck to you with your fax problem.
Greg
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000200/000009/faq000209_002.html?reg=us&c=us_ot&lang=en&prod=mfc6490cw_all
May 12, 2009 | Brother IntelliFAX 4100 Laser Fax
Cannot receive faxes or copy, but can send out
make sure you auto recieve light is on.
check your lights the one for FAX only has to be on only.
not TEL or FAX_TAD
good luck>
Mar 21, 2009 | Brother IntelliFAX 4100 Laser Fax
Unable to send faxes long distance
Do you have to dial a code for long distance access?
Oct 29, 2008 | Brother IntelliFAX 4100 Laser Fax
First plug in a normal tone tellefone into the wall jack that your fax is using.Make sure you get the fax signal from the faxnumbers you struggling with.If you can hear any line noises on the line it may be the problem why you cant get a fax trough.Make sure your fax is set on the correct county code-tone or pulse.
Vonage vs Brither 4100
Have you called your own fax line and just listened to the fax hand shake? might sound simple but I have called fax lines before and it just rang, or it was busy or static, if your not getting a clear fax hand shake, then it is the phone line, if there is no answer you may have turned your fax to manual receive mode, If you don't know how it should sound call a friends business fax line and listen to it. I have actually gone out to businesses that reported send or receive problems just to call the line and listen to a disconnect message, that would make it difficult to fax.
Jan 13, 2008 | Brother IntelliFax-4100e Fax
Sending fax
NG STANDS FOR NOT GONE , TYPICALLY THIS MEANS THAT THERE IS A COOMMUNICTION ERROR AND THERE IS ALINE DISTURBANCE /NOISE DURING THE CONNECTION WHILE SENDING THE FAX MESSAGE. TRY CHANGING THE TELEPHONE LINE IF IT IS AVAILABLE. HAPPY FAXING OMNIPRESENT
Oct 02, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
120 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
