Question about Tilia FoodSaver VAC420
My food saver isn't sucking the air out of the bag. Any idea why? Also it sounds louder then it usually does.
4 Suggested Answers
SOURCE: Food Saver quit working.
i have a game saver plus. when i start the seal light comes on then it sucks the door closed then the seal light comes on again and the door opens and it stops
Posted on Apr 30, 2010
SOURCE: My food saver won't vacuum.
Does it have the black rubber gaskets like my V845 Foodsaver? If so, make sure that you wet down the black rubber gaskets like with a wet paper towel before each sealing, and of course make sure the edge of the cut bag is between the two black rubber gaskets. Hope this helps you.
Posted on Dec 06, 2010
SOURCE: Tilia Food Saver Vac 420 sucks air but won't switch to seal mode
Thanks to Mikeytheeye!!!
I became frustrated and figured I had nothing to lose. I had no idea what a vacuum switch was, but I took it step by step and moved on. It happens to be the round brown piece that has the tube coming in on the board.You have to remove the six small screws to the board and flip it. I tried to remove the "star" screw without removing the switch from the board, couldn't do it (also, I only had a t25 star screw attachment that worked at first, but started to strip). You can turn the switch but it does not open. I waited until the morning to make a home depot run and got a t27 star attachment and a soldering kit (only $18). From there, you just touch the two points and the switch comes off. I also got the contact cleaner ($3) and let soak. After cleaning it out and letting it dry I put everything back together and nothing happened. I took everything apart again and I tightened the star screw down almost all the way. Put everything back together and presto - the sealer worked after the vacuum cycle. For the record, we have a Foodsaver v345 model. Thank you for all the help.
Posted on Jan 02, 2010
O2 dodge dakota sounds like it sucking air at low rpms
Most likey is just the sound of air being sucked into throttle body. Some vehicles make louder noises like that especially if it has an aftermarket cold air intake. Because the air filter box muffles that sound. It's possible that it has a vacuum leak as well which can make a sucking noise if it's large enough. Usually a large vacuum leak will affect the way an engine runs though
Sep 17, 2016 | Dodge Dakota Cars & Trucks
It won't vacuum. Why?
vacuum sealer won't pull vacuum - GardenWeb
forums.gardenweb.com > Garden Forums > Harvest
Nov 9, 2008 - I know many of you use vacuum sealers, so hope you might be able to help. I have a FoodSaver Pro Sport, it's probably about three years old.
How to fix Food Saver - Vacuum Sealer? - Instructables
www.instructables.com/.../How-to-fix-Food-Saver-Vacuum-...
InstructablesMar 2, 2012 - I have a Food Saver brand Vacuum Sealer, that all of a sudden stopped ... If it won't heat up to seal the bag, then you probably have a break in
vacuum sealers - Frequently Asked Questions
Feb 03, 2016 | Kitchen Appliances - Others
Door to my foodsaver is stuck on one side. It's shut. How can I release it? Is there a release button anywhere?
Trouble with Food Saver Brand - Survival Podcast
thesurvivalpodcast.com > ... > Food Preps > Processing Food For Storage
Aug 15, 2010 - 17 posts - ‎13 authors
We have been using our Food Saver Vacuum sealer we bought ... connects somehow got stuck open and therefore the bags would not ..... I've had the FoodSaver V3840 for about 10 months now and thus far it has been great.Missing: door
FoodSaver Repair - YouTube
? 8:22
https://www.youtube.com/watch?v=jguFiF0Rouw
May 21, 2014 - Uploaded by Kelly Kimble
Repair a FoodSaver that isn't drawing out air anymore. In this case, its ... Vacuum Sealer Troubleshooting - Duration: 10:25. katzcradul 52,345 views. 10:25 ... How to Food Saver Lemon Juice or Other Liquids - Duration: 4:56.
[PDF]Use and Care Manual - Home Depot
Jan 25, 2016 | FoodSaver Vacuum Food Sealer - V3840
Why is my Foodsaver V2440 motor noisy while vacuuming bags?
This is normal it means that its just pumping air out of the bag but if it gets too loud and its not pumping air out of the bag then you might need it looked at soon
Jul 12, 2014 | FoodSaver V2440 Advanced Design Vacuum...
I have a sharp twin energy, the hose isn't sucking very well, and just today it had a burnt plastic smell
This sounds like something is plugging the air flow. You need to take apart until you find it. Air flow also cools your unit.
Jun 09, 2011 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
My Rival food saver does not vacuum air out
We discovered we were not moving the bags in far enough to be grabbed properly. After pushing in the bag before closing the unit we found it started sealing properly. This was on an older system, so be sure the bags you're sealling are between the black rubber rectanglar sections before closing the door.
If this is for a canister, be sure the rubber around the lid is seated properly. The rubber can be removed, cleaned and wiped dry. Clean out the lid and dry it too. Reseat the rubber seal and try again... Hope this helps.
Apr 19, 2010 | Vacuums
Jan 08, 2010 | Tilia FoodSaver V2240
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Tilia FoodSaver VAC420 Logo
1,076 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Lee Eismann
Mike Squire
Ed Mac
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
