Question about Tomtom GO 510 GPS Receiver
Tomtom go 500
Tomtom will not reset after using paper in reset hole tried several times
  • rizwin18 Jul 26, 2008
    i cant find de reset button
  • 515 Answers
How to get my tomtom one N14644 to turn on
First, make sure that your TomTom battery is (fully) charged. Then press the ON/OFF power button ... to turn it on. If it still doesn't turn on, try to RESET it ... using a "pin" (e.g. paper clip) to push up the RESET hole at the bottom of the device.
Jul 01, 2014 | Tomtom GO 700 GPS Receiver
When I turn on my TomTom XL it first asks me to put in the settings, i.e. voice, what signals it wants me to read out, etc. it gets to a certain point then just freezes and turns off. Its done this about...
Is the unit fully charged ? If it is try a hard Reset to restore to factory defaults the "Reset" hole in the case can be actived by inserting the tip of a paper clip
Feb 16, 2010 | Tomtom ONE XL GPS
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
TomTom Go720 cannot boot up/frozen screen/no response. Need repair
Try resetting it. Use a pin or straightened paper clip to push the reset button thru the hole marked "Reset" on the bottom. hold the reset for 15 seconds. then push and hold the power button for 5 seconds to complete the reset. Good luck.
Oct 27, 2009 | Tomtom GO 720 GPS Receiver
How do i reset ? don't know model number
Hi pennimasi if you have a tomtom one like pictured below, you reset it by using a paper clip to insert in the reset hole on the bottom of the gps "remove your sd card first before trying to reset it"..
depending on which tomtom one you have, it will not have an sd card....you can click on the picture to see detailed instructions if you need to.
bill
Oct 01, 2009 | Tomtom ONE GPS Receiver
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
Jul 23, 2009 | Tomtom GO 910 GPS Receiver
GPS Won't work
Try to see if there is a pin hole reset button on the unit. if there is use a paper clip and reset the unit to factory defualts.
Apr 22, 2009 | Tomtom ONE GPS Receiver
Tom tom go 710 wont switch on
Press the tiny reset button...
You'll need the pointy end of a paperclip or a pin.
Turn your TomTom upside down and look at the underneath, with the screen facing away from you.
Starting at the back and moving towards the screen, you'll see a small traingular-shaped piece of rubber, then a plastic area with a small hole to the left, then the circuit board with all the little gold connectors.
It's that small hole that's the reset button, push your paper clip or pin in there. Your TomTom should reset straight away, but sometimes it takes a few tries for various lengths of time.
Enjoy your newly restored TomTom!
Oct 29, 2008 | GPS
Tom tom go 500 wont power up
Press the power button for 15 seconds and your tomtom will turn on with the drum sounds yor tomtom will now reset but nothing will be deleted off it and it will now hope fully work.
Bye
Apr 27, 2007 | Tomtom GO 300 GPS Receiver
GPS Logo
129 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
