Question about Frigidaire Dryers
Frigidaire Gallery Gas Dryer model fsg747ges1 spins and stops. will not restart until motor cools. happens on all temp settings. What's up? Where can I find a service manual, so I can see how tricky it is to replace motor if needed?
  • 3,037 Answers
Your service manual can be bought from this site => http://www.repairclinic.com/PartDetail/Service-Manual/948565
I can't give you a free one unfortunately due to copyright
The motor probably is shorted and so needs to be replaced which is why it doesn't work until cool. Let me know how this works out for you.
Benjamin
Posted on Jan 03, 2011
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire aeq7000eg0 motor doesn't run
Most of your fuses for a Frigidaire dryer are upper right hand side of the rear bulkhead. Here is a westinghouse dryer video I made In the video I look for failed components and show the various parts, explain their function, and location.
Frigidaire service manual
https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101
Jul 23, 2012 | Frigidaire Dryers
Dryer won't start until it cools down
motor bearings are going out. What happens is in the motor there is a thermal overload switch. This switch activates when the motor gets too hot to prevent fires. That is why you always see the "thermally protected" sticker on the electric motors. If the bearing are going bad or possibly windings in the motor the switch kicks in and will not restart until the temp. of the motor cools to a certain level. Take the model and serial # to an appliance parts supply for replacement of the motor.
Hope this has helped you
Dave
Jan 18, 2010 | Kenmore 73952 Gas Dryer
My Frigidaire gas dryer isn't hot. Otherwise it runs fine.
it could be either your ignitor(glow coil) flame sensor control, or a defective thermal switch telling dryer its at temp and shutting off gas supply before it even fires initially
Oct 17, 2009 | Dryers
Frigidaire Model FSE446RHS shuts off mid cycle
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00
Please let me know if I can assirt you further.
Vic
Jun 01, 2009 | Dryers
Unexpectedly stops
Lighten the loads.
Clean the lint from around and in the motor.
Replace the belt.
Check the rear drum support and front support guides.
If that does not correct the problem you have a bad motor.
Apr 12, 2009 | Dryers
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dryer not heating
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Jan 08, 2009 | Frigidaire Dryers
My Frigidaire Gallery front loading dryer does not produce heat any more. It is model number FSG747GES1 and was purchased in March 1998. I don't know if it needs a new heating element or a vent cleaning.
Check to make sure you have 220V. Make sure you have no blockage of air flow (lit glogged up). Unplug dryer, Check your thermostats. If they are good check your heating element and take it out and visually inspect it.
Jan 08, 2009 | Dryers
Dryers Logo
203 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
