Question about Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet front loader is leaking water out the bottom during wash cycle
1- check the drain pump.
2- check the connection between control board and power board.
Posted on Jan 03, 2011
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer leaks during use; rinse cycle?
Check the water pump hose connections and the water pumps housing bolts themselves could have loosened from vibration. more likely the hose connections on the pump itself though. Hope this helps.
Feb 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water is pouring from bottom of washer during the entire cycle
The grey rubber around the door which is called a Door Bellow might have a hole in it. It is the most common problem for front loader leaking water. Check this first, pull it and use a flashlight to check the back part. I found this out last week, I had a leak and had 5 holes in the bellow. Here is a link to the part. You can get it cheaper here for $70.09 plus$5.95 for shipping or you can check ebay for the part number 8181850. If this is not the problemt follow the link below to check other items.
http://www.fixya.com/support/r3576656-washer_leak__front_loader
Jan 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water coming out of the botton during spin cycle
Take the bottom panel off the waher, put water in the machine, and watch to see where it is leaking. If you don't see a leak during the regular cycle, put the machine in drain and spin mode, and watch for leaks there. You should find your leak during one of these cycles so you will know what part you need.
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool duet sport front load washer is fairly new (2008) now it has started dripping water during the cycle under the front of the machine. any suggestions would be helpfull.thank you
check tub boot for any tears in lip that seals to door zippers etc. can tear this.also sometimes water can leak from pump cleanout.you would need to remove bottom panel to check this
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool fron loader washer leaks at the door
The water should be able to come up to the door level without leaking. Chances are you have build up on the bottom side of the glass on your door. If so take a razor blade and scrape the build up off. Your door will quit leaking.
Aug 12, 2017 | Whirlpool Duet GHW9150P Front Load Washer
I have a front loader whirlpool duet #ghw9100lw2
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Apr 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from Washer during cycle
you can remve a few screws(3) across the bottom of the unit.( just above your "add-on" drawer. 3 torx 20 screws and after removing the acess panel youll get abetter look as to where exactly you water is coming from
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WhirlPool Front Load Washer Leaking
to richhardh..
did u try holding the "End of Cycle Signal" button for 3 ?
May 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Front Loading HE (GH9400PW4) washer is leaking! Hellllp!
remove the bottom acesss panel and run through drain/spin cycle youll see where the leak is then. perhaps debis has puntured drainline hose or pump housing is leaking
Mar 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
141 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
