Question about Maytag PTB1551GR Top Freezer Refrigerator
I have a Maytag PTB1954 . Freezer above fridge. Purchased in 2002 and still under warranty . Has 10 year Parts and Labour on all parts of the refridgerant system. Repair man tells me that the refridgerant is low and that it is from a slow leak. He surmised it is on the condenser side and is looking to replace the condenser.I told him that for the last 18 months I have heard sort of a "Marbles in a box" sound when the compressor starts up or shuts down. He said it was not related. I didnt propose this to him but I feel that the compressor could have experienced cavitation and could be damage because of the lack of refridgerant. Is this likely? Should the compressor also be suspect? Also, how can I be sure he got the leak? Shouldnt he test for where the leak is, it could be in fitting or something..
SolutionGuy
  • 331 Answers
SOURCE: 'ice dam' on bottom of freezer, now problems with fluctuating temps
Kat, you only have 1 problem happening.And no this is not due to the original repair. (though I have to admit... replacing the filter/drier, starter and compressor is NOT part of routine maintenance and has me a little befuddled.) Your evaporator drain is plugged. Most likely with what we in the biz call "bio-gookus". This is normal, but must be cleared to keep the water from puddling and coming out your freezer door. With the evap panel removed and the drain hole exposed, pour 1/4 cup of HOT water into the drain hole. Use a small screwdriver or other small instrument to pick out the ice buildup. Once this is clear, use something like this http://www.azpartsmaster.com/shopazp/Gallo+Condensate+Blowout+Guns+(A66800).html to blow out the rest of the lines. After doing this, pour more hot water into the drain to verify free flow. This will take care of your leak problem. Now... the frost buildup. NEVER RUN YOUR FRIDGE WITH THE PANELS OFF! They are there for a reason, believe it or not. They direct air flow across the coils (both evaporative and condensing). Frost buildup is normal, though you may be experiencing higher levels of frost because of the panel missing...Your fridge utilizes an automatic defrost system. It'll initiate every 8 hours. This is controlled by a timer located in your fresh food section. The defrost heater RARELY fails on these. Fix the evaporator drain and replace all panels. This will solve your dilemma.
Posted on Aug 09, 2007
mikedurland
  • 481 Answers
SOURCE: Maytag MSD2651HES fridge not cooling freezer works find
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 06, 2008
kevin000
  • 1847 Answers
SOURCE: maytag side by side slowly getting warmer
I have actually been having the same problem. We have a Maytag MTB2156GEQ and it hasn't been cooling well at all lately. Temp in the fridge is about 52 degrees even on the highest setting. The freezer seems to be fine. I pulled off the back panel and vacuumed out the condensor coil and everything else under there. I then pulled out the control panel on the ceiling of the fridge. The channel between the freezer and fridge was almost completely blocked with ice. I cleaned it out by taking out the back panel of the freezer and pouring hot water down through the hole until it was clear.
that seem fix the issue.
Posted on Aug 10, 2008
tborn6
  • 700 Answers
SOURCE: I have a Maytag side-by-side MSD2756GEB that quit cooling.
sounds like either the fan motor or the compressor. go ahead and open upo the bottom baclk panel and see if the fan is running or if the compressor is. could be just a burned wire.
Posted on Feb 07, 2009
  • 4 Answers
SOURCE: MAYTAG SIDE BY SIDE FRIDGE FREEZER STAINLESS STEEL
The problem will come back in about a week once the coils frost up again. This seems to be a common problem with these refrigerators. I had the same problem a while back. Sounds like your defrost board is dead. part number is 12002104. You can find it at searspartsdirect.com
Posted on Jun 28, 2009
Every 2-3 minutes it sounds like something is trying to start and then the starter type switch stops, now freezer is starting to frost. It has been happening for about 3 weeks now but the starting noise...
Compressor problem. There are start components mounted on the side of the compressor, and should be removed and tested. The parts include the start relay, (start/run capacitor if it has one) and the overload switch.
To test these components you must have a working knowledge of electrical an use of a good VOM meter.
If not, remove the parts, and take them to an appliance parts house. They usually are happy to test them for you.
If they test O.K. you have a failed compressor.
P.S. If this machine is under 5 years old, the compressor is under warranty, (some have an extended 10 year warranty). if the warranty is in effect, do nothing. Call the dealer who would handle the warranty. You would have to pay for replacement of the start components, but having it serviced by an authorized warranty station will keep the balance of the compressor warranty in effect. Hope this helps... Jack
Oct 31, 2009 | Maytag MFD2560HES Bottom Freezer French...
Not cooling - part replaced 2X - happening again
Yeah, buy a Kenmore next time. I have one of these JUNK Maytags and less than 5 years the compressor is shot. The 15 year old Kenmore in the garage that has never had the coils cleaned is still going STRONG.
Sep 03, 2009 | Maytag MSD2651 HE Side by Side...
GE PFS22MISBWW is a piece of junk
One doesnt like to hear it but possibly cut your losses and look for a less complicated fridge with minimum electronics.
Jul 21, 2009 | GE PDS22LBN Bottom Freezer French Door...
Not getting cold, staying around 48 - 50 F
Check the condenser coils. These are located at the rear, behind the panel. There should be frost all over the coils.
If not, and the frost is just on the first section then this indicates a slow refridgerant leak. I purchased mine in 2002 and it came with a 10 years parts and labour warranty on all parts of the refridgerant system. So hope you hung onto all your documents.
Jun 25, 2009 | Maytag PTB1954GR Top Freezer Refrigerator
Compressor bad on my freezer. can this be fixed
The compressor can be replaced but it's often not worth doing. If it's under a year old it should be fully covered under warranty. If it's under 10 years old, the parts may be covered under warranty. In that case the labour is probably worth paying for. If you have your manual check in there for your warranty information. Good luck!
Apr 27, 2009 | Refrigerators
Maytag MZD2766GEW side-by-side - one side is not cold
WE JUST HAD THAT SAME PROBLEM AND IT WAS THE DEFROST BOARD. $50.00 REPAIR...
Jun 15, 2008 | Maytag MSD2436GR Side by Side Refrigerator
Sub zero 650 fidge holding at 53 degrees
Most likely you have a leak in the evaporator. Subzero warranties the parts for 12 years. Call them to find out what they will cover. They are agreat company and will be fair with you.
Jun 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Temp
I've had my Samsung RS267 LASH side by side for almost 2 years now and the coils froze recently. The temperatures displayed - relating to the refirgerator side - bounce around when the coils freeze. My freezer thank goodness is still working properly. The repairman indicated that the heating element for the refrigerator coils was bad. Unfortunately he had to order the whole unit (coils, heating element, etc.) since he couldn't replace just the one part. Samsung takes their time sending the parts - we've been waiting for 10 days now. The Samsung warranty covers the compressor, evaporator, condensor, drier and connecting tube for 5 years parts and labor so we should becovered. You might be covered as well - depending on when you purchased your refrigerator. I did purchase a separate extended warranty from Lowes when I bought the refrigerator and I'm glad I did. My extended warranty included $250 in food spoilage covering our food loss due to the breakdown. Hope this helps......
Jun 06, 2008 | Samsung 26.0 Cu. Ft. Side-by-Side...
REF AND FREEZER STOP COOLING
We had a repairman come out, said it was the compressor, bad news...$650 if he repaired...good news...compressor under manufacturer's warranty for five years so you may want to call Maytag. It will be less expensive if the part is covered and you only have to pay for labor. Hope this helps. Bought our fridge 12/2004 so it was covered.
Feb 03, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag Ice20 refrigerator
Thanks, Solution #3, for the phone number ((800) 688-9900)! We, too, have the Ice2O refrigerator, and the HV Board started the disco light show last night. Followed instructions above to disable it, which temporarily solved the problem. Was on the phone with Maytag (Whirlpool?) this AM, and their initial response was that they wouldn't cover anything since we are out of warranty. I had to be extremely firm with my expectation that all parts and labor would be covered. Sent the rep back to her supervisor several times until they agreed to cover both. If you find yourself in a similar situation, don't give up until everything is covered. This is a design issue that should NOT be impacted by an expired warranty!
May 21, 2007 | Maytag MFD2560HES Bottom Freezer French...
Maytag PTB1551GR Top Freezer Refrigerator Logo
74 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
