Hello, My Pioneer PD-Z560T Twin Tray CD unit will play discs, but usually plays Track One for around 30 seconds, them skips back to around the 15 second mark. It then carries on playing up to around the 30 second mark again, then skips back to 15 again. This is pretty consistant with different discs!!! It may be up to 40 seconds, then back to 25, but you get the idea i hope. If i skip to track 4 (for example), it may start playing, but will usually then skip back to track ONE, going through the same skip-play-skip-play routine as described above. I have gently cleaned the lens with pure alcohol, but it makes very little difference. It cannot be damaged discs, as it does it will loads of proven OK ones, but hte skip-play skip times vary slightly from disc to disc I do notice that "Edit Mode" is permanently lit in the led panel, cannot get rid of it. is this normal?? (i have no instructions, but do have a remote control). Thanks in advance, Andy Can vyou pls advise
  • clerical Jan 03, 2011
    Thanks for the reply about skipping discs on the pioneer pd-z560t
    If you or anyone can add any more info or help, i will add that it was playing fine up to a few years ago when machine was safely stored until yesterday. it was then delivered to me via a 100 mile car journey.
    Could the trip or the lack of use for a few years affect the lens, or could you now suggest something else vplease?.
    continued thanks in advance.
    Andy
  • 6,993 Answers
how long have you been using this player? Was this player playing Cd without skipping previously?
This problem is more or less like a lens problem. When the lens of a player becomes weak, it begins to skip discs. Though it might not skip all discs but that doesn't mean its not a lens problem. Also, cleaning the lens with an alcohol cannot revive a weak lens. It only solves the problem of a dirty lens.
I think your player needs a brand new lens for it to play CD's without skipping them.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all discs again.
Good luck.
Posted on Jan 03, 2011
  • Walesarumi
    Walesarumi Jan 03, 2011
    not using the lens for a long time may affect it because a lot of dust and other particle may have affected the lens.
    Since the player hasn't been used for a long time, you can service it by disassembling the player, use a paint brush and alcohol to clean the board. Make the internal part of the player clean and dust/curb web free.
    You might end up replacing the lens as I stated in m first post.
    Take care.
CD player skipping
Make sure the unit is mounted level and not to secured that its pinching down on the unit
Jul 23, 2012 | GE 7-5295 Undercounter DC /Radio Combo -...
I Have a Pioneer PD M602 6 disc changer, and I just bought it used. And I cant get it playing. Sometimes say "no disk" ( but the tray is full discs applyed as it schould. It loads one disk after...
To my surprise, CD cleaner disc did it for me. It's a very old Philips one with a bit of furry stuff on the track side. I was amazed it even played, but it did and after letting it run for 20 secs, tried proper discs and it works fine. And this Pioneer PD-M603 is at least 15 years old!Looks like it would be hard to clean the lens manually because it's a long way inside.
Jul 27, 2011 | Pioneer PD-M603 6-Disc CD Changer
I have model PD-F407-- It will not play past disc 5. I can not get it to manually play any disc past 5 and it won't roll over from disc 5 to 6. If I punch in to play disc 9 it flashes disc 5 on the...
Check that no CD's have dropped behind the load tray. The same issues happened to me and I found 3 discs that had fallen out and were blocking the mechanism from going past disc 5
Dec 24, 2010 | Pioneer PD-F407 25-Disc CD Changer
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM and others.
Feb 18, 2010 | Pioneer PD-M603 6-Disc CD Changer
Have a pioneer cd player model number PD-Z560T. Has started making my cd's jump while i'm playing them.Have tryed cd lens laser cleaning disc but still no good any ideas?
My cd unit on the pioneer pd-z560t also jumps. I also tried lens cleaner, with no luck.
It was suggested to me that cleaner is only any good for a good - but dirty - lens, but no good if the lens has actually deteriorated and become weak.
I would be curious to know how a lens could actually deteriorate pls.
plese try to reply to: clerical@live.co.uk
Thanks
Andy
Nov 01, 2009 | Audio Players & Recorders
Pioneer PD-F100 Constantly Skips to Next CD
the problem is not the laser, but the cable that connects the laser to cd board, it is cracked..and will break connection when moved out from its home position, i have replaced a lot of cabes for this model..i know it well
Jul 05, 2009 | Audio Players & Recorders
Pioneer pd-m406 cd changer magazine style
The Pioneer component 6 CD magazine changers only play normal store bought CDs, not CDs you make yourself.
sorry.
Nov 03, 2007 | Pioneer PD-M406 6-Disc CD Changer
IT is Pioneer PD-M430 6-Disk CD changer
turn the cd, the silver side must be look down
Sep 16, 2007 | Pioneer PD-M406 6-Disc CD Changer
Text Display Memory - Again
try replacing the internal battery
Oct 11, 2005 | Pioneer PD-F1007 301-Disc CD Changer
254 people viewed this question
 Grubhead
Grubhead
