Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
My Dyson DC15 Ball is not picking up at all properly. Awful! Investigated - it looks like the pipe system when you use your foot to make the cleaner go from upright to push along cleaning position, is not fully engaging and matching up with the pipe that connects to the beater bar....so there is a gap and loss of suction......hence hardly any pick up! Help, please someone. It's 5 years old in May 2011. V disappointed. Never had any luck with Dyson. : (
SOURCE: Dyson DC07, too much suction...?
have you checked that the roller is turning when the vacum is not in the upright position as ther are 2 belts 1 from the motor to the clutch and 1 from the clutch to the roller if the clutch belt breaks you will find it hard to push because the roller is stopprd.... lie the machine down on its side with the vacume in the open position not upright and check if the roller turns it should only stop when in the upright position. PLEASE MIND YOUR FINGERS.
Posted on Jun 27, 2007
chrispurs1
  • 372 Answers
SOURCE: no suction when vacuming floors
Hi.
There are 2 types of Dc07 one is clutched & has two belts the second has only one belt going from motor to brush roller.
Lay machine on its side pull back handle as if you are to vac carpet switch machine on look to see if brush roller is spinning.
If it is not spinning unplug machine from mains supply & remove the sole plate by turning the three plastic screws to unlock position, Lift sole plate away if you have non clutched machine you will now see the brush roller with A belt going from this to the motor shaft belt may have snapped or come off so replace it.
If your Dyson has A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front.
It should rotate to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive.
If you still have no brush rotation after doing all this then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
There are service manuals available for these repairs at this site
http://dysonmanuals.llc.nu/index.htm
Posted on Jul 05, 2008
SOURCE: Dyson won't go back into upright position to engage suction
The dyson.com website had a solution for this particular problem. Just press in a button in the area around the right wheel while lifting the rear of the vacuum up. This allows the base to roll forward enough to go back into the upright position. I did this and it worked. All fixed.
Posted on Jul 09, 2008
DAZ4161
  • 7 Answers
SOURCE: the beater bar/brush won't turn
HI THERE,
FIRSTLY, REMOVE SOLEPALTE BY QUARTER TURNING THE 3 COLOURED STUDS,THEN CHECK TO SEE IF THERE IS ANYTHING OBSTRUCTING THE BRUSH BAR OR IF THE BELT IS WORN OR SNAPPED. IF ALL SEEMS WELL PUT THE SOLEPLATE BACK ON AND ENSURE CLUTCH IS ENGAGED TO AUTO AND TRY IT AGAIN. IF NO JOY THEN PLEASE COME BACK TO ME.
REGARDS
DAZ
Posted on Dec 13, 2008
  • 8 Answers
SOURCE: beater bar on Dyson upright won't turn when handle is lowered
you need a new belt and maybe a new brushbar.
Posted on Dec 23, 2008
How to repair a Dyson dc15 blows instead of sucks
Hi there, it's Jack at Dyson.
If dirt seems to be coming back out of your DC15 rather than being deposited in the clear bin, it's likely your machine is blocked. The filter may also need a wash. To check for blockages, please run through each of the steps shown in our online Support guide: http://www.dyson.co.uk/support/dc15/dc15-the-ball-all-floors/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/wand-suction
It's also a good idea to give both parts of the pre-filter a wash - we recommend doing this at least once every 3-6 months in normal use. Use cold water without detergent, and allow at least 12 hours for both parts to dry completely before replacing them:
Following each of these steps should resolve the issue. If you would like any further advice from our experts after giving this a try, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 03, 2014 | Dyson DC15 All Floors - The Ball Bagless...
Dc15 manual
Hi Jean, it's Jack at Dyson.
You can download a copy of the Dyson DC15 User guide directly from our website: http://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc15_uk_manual_120710%20pdf.pdf
If you're looking for some help troubleshooting an issue, our online Support pages should come in handy: http://www.dyson.co.uk/support/dc15/dc15-the-ball-all-floors
If you'd prefer to speak to our experts directly, you can reach the Dyson customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 23, 2014 | Dyson DC14 Bagless Upright Cyclonic Vacuum
My dc15 is not picking up,how can I fix it
check the changeover valve is working ok from floor to hose settings
Dec 06, 2012 | Dyson DC15 All Floors - The Ball Bagless...
Where is the plunger located on a Dyson DC15 all floor model
I'm not sure which part of your DC15 All Floors you're describing, but if you take a look at our Support page for this model, you should be able to find the information you're looking for:
You can also download a copy of the user guide for this machine here:
http://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc15_uk_manual_120710 pdf.ashx
I hope this helps - if you'd like any further assistance or advice, please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 12, 2012 | Dyson DC15 All Floors - The Ball Bagless...
Picture of reset button on dyson ball
The advice on resetting your machine will depend on which model of Dyson Ball you own. If you have a DC15, you can reset the machine by following the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=866&product=DC15-SY-STD
If this is not the machine you own, please visit www.dyson.com and click 'Support', then select your model from the list.
If you'd like any further assistance or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Feb 11, 2012 | Dyson DC15 All Floors - The Ball Bagless...
The wand handle is jammed in my dyson ball
Sorry to hear you're having difficulties with your Dyson DC15. It's probably best if you get in touch with us directly so one of our experts can talk you through the process of releasing the jammed wand. You can call us free on 08002980298 (UK), or 1866MYDYSON. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Aug 04, 2011 | Dyson DC15 All Floors - The Ball Bagless...
Dyson ball not picking up properly and very noisy
Is the beater brush spinning? Is the sole plate that is removable and covers the bottom side of the beater brush housing installed properly such that there are no gaps between it and the housing? Is the hose that connects the beater brush housing to the canister connected or have any holes in it?
May 26, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Where can I find a dyson service center. my dyson
On the side of the machine somewhere should be the telephone number for the Dyson Helpline.
Give them a call and they'll point you in the right direction.
Nov 07, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
189 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
