Question about Garden
Craftsman 32cc weed trimmer will not stay running when trigger depressed after start & warmup ... Bad gas? Plug gap? Choke adjustment? Suggestions?
    Brigadier General:
  • 4,088 Answers
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Plug gap should be 0.020". Bad fuel usually means poor starting and idling as well as poor high speed running. Try setting the H jet needle CCW somewhat to increase fuel input to the engine. It should 4-stroke lightly at speed, then 2-stroke immediately when the line is cutting. Be sure to use a modern synthetic saw oil in the fuel (available at home centers, hardware stores, and saw dealers) and be sure to shake the container thoroughly just before filling the tank each time to prevent oil starvation. Hope this helps!
Posted on Jan 04, 2011
  • 173 Answers
Check the air cleaner and make sure it is clean.if it is then tou will have too clean and rebuild carb or replace it with a new one.
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    I push primer on craftsman 32cc weed wacker trimmer and gas just runs out carb all lines are hooked up properly any suggestions
    its supposed to,thats where the gas goes when you prime it,hold it up or choke it to start
    Apr 17, 2015 | Craftsman Garden
    I need a trigger for a craftsman weed eater
    Go to http://www.searspartsdirect.com/
    Select model number and her your model to look-up the part number and you can then order the part from them or some other dealer using that part number.
    Oct 16, 2014 | Craftsman Convertible 32cc Gas Line...
    Weed eater troubleshooting
    Check the ground wire from the switch. The kill switch uses ground to kill the engine.
    Aug 20, 2014 | Craftsman Convertible 32cc Gas Line...
    17" 32cc gas weed wacker
    Hi pmbaugardne...
    Please take time to rate me
    Sep 19, 2011 | Craftsman Garden
    I have a craftsman 32cc weedwhacker trimmer and its brand new and it hasnt started from day one it isnt getting any spark at all
    If you have spark problems, remove the wire and then remove the plug, reattach the wire and ground the plug to the engine and pull the string, you should see arc and hear it pop, if not, take the plug to another piece of equipment and remove that equipment's plug wire and attach it to the plug from the weed ******* and then ground it and test it. If still no spark, then plug bad, if plug then the weed ******* has a problem with the spark plug wire or the ignition coil.
    If you have spark at first test, then the problem with the weed ******* is somewhere else.
    Aug 09, 2011 | Craftsman 25cc Gas Line Trimmer
    I have a Craftsman 32cc weed trimmer, can't give gas, it stalls
    Usually the diaphram is wore out. It is a relatively inexpensive part. Does it run better with a little choke? If the answer is yes chances are it's the diaphram. Also sometimes the adjustment screws can move. There are two, one for low speed, and one for high. With the engine warmed up make small movements on the screws (some are marked low, and high) in, and out adjust til the engine runs at its optimum.
    Hope this helps!
    May 04, 2010 | Craftsman 25cc Gas Line Trimmer
    Garden Logo
    302 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
