Question about Sony KDS-R50XBR1 50" HDTV
My KDS-R50XBR1 will power on with picture for approx 1 second with the power light in green, then shut down automatically and the lamp light blinks 4 times. Is this a bad lamp only? Thanks! Mike A.
  • 10,594 Answers
If Lamp light blinks then it is lamp that is near to end of its working life.
If standby light is blinking then it is some thing else, when did you replaced lamp in tv last time?
Thanks.
Posted on Jan 03, 2011
W KDS-R50XBR1 50 in. HDTV Television standby light blinks red 3 times
Something you might want to look at:http://sites.google.com/site/sonylcdrptvproblems/lamp-overheating-issue
Apr 06, 2012 | Sony KDS-R50XBR1 50" HDTV
The lamp LED blinks 4 times and repeats, I replaced the lamp but the lamp led is still blinking 4 times and repeats and I have no picture
4 times blinking light indicates problem with exhaust fan in KDS-R50XBR1 and possible causes are as follows:
-Fan 1-4 power is not supplied. (ASU board)
-Fan connector is not attached securely.
-Fan caught wires or harnesses.
Please check exhaust fan in tv, it is located at lower right of tv looking at rear of tv.
Thanks.
Feb 04, 2011 | Sony KDS-R50XBR1 50" HDTV
My sony kds r50 xbr-1 ...picture shuts off and blinks a green light (standby) 50+ times. comes on then goes out again ....again...again......... while out I can hear the audio through my sound system. we...
Hmmmm! i suspect the INVERTER that drives the lamp, or it could be the power supply check for swollen capacitors on the board inside, and last it coul be a overheating component (is it wors after it's on for a long time)
Dec 30, 2010 | Sony KDS-R50XBR1 50" HDTV
I have a sony kds-r50xbr1 and the problem is that it takes about 1 min to turn on and the screen appears for a bout 1-2 sec and then shuts off to a black screen where the power/standby blinks continuously...
Its time to replace lamp in this tv because existing lamp has reached to end of its working life span and causing problem. If lamp got broken, you will see lamp light lit on tv front but weaker lamp cause above symptoms.
Lamp replacement procedure is easy and written in user manual.
Buy Sony original lamp for good and bright picture in tv.
Thanks.
Jul 23, 2010 | Sony KDS-R50XBR1 50" HDTV
Sony SXRD-KDS-R50XBR1
Light Engine Call Encompass Parts Distrubtion
1-800-638-3328 and Call UED 1-800-648-6657 Just see which one has the lowest Price.
Dec 31, 2009 | Sony KDS-60A2000 60" HDTV
Sony KDS-R50XBR1 50 in. HDTV picture cycles on and off
It is clear symptoms of weak lamp in TV, replace lamp to correct that problem.
Lamp replacement is easy and written in user manual of TV.
Please buy Sony original lamp for TV safety.
Thanks.
Nov 17, 2009 | Sony KDS-R50XBR1 50" HDTV
Power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Jul 19, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52 times
Just replace its Lamp and procedure is written in user manual of KDS-R50XBR1
F93087600 XL-5100 LAMP BLOCK
Lamp is available in Sony Accessories and price is $250
Always buy Sony original lamp for good picture in TV and avoid aftermarket / cheap lamps that can cause damage of TV circuits.
Click Sony Support to download Instruction Manual copy, if you want it.
Apr 22, 2009 | Sony Video Cameras
KDS-R50XBR1 5 red blinks
If you are positive that the fan is still running and that it isn't an over heating issue, I would venture to say you need a new dlp lamp. Your model uses a Sony XL 5100 dlp lamp. You can grab one over at DLPLamps.com.
Feb 15, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R50XBR1 50" HDTV Logo
165 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
