Question about Fisher and Paykel Microwave Ovens
Is there a cutout switch on the wastemaster as the machine will not go when the wall switch is turned on.
  • pamandtomrya Jan 03, 2011
    Very Helpful. Mich appreciated
    President:
  • 2,468 Answers
Not sure if fixya has you labeled for the wrong category,or if this is truely a microwave???or If its a Garbage Disposal,then look under the bottom side for a "RED" square reset switch and push up on this red switch to reset the motors power,but be sure the disposer is NOT jammed by any foreign material,such as silverware,food bones,etc.,if it wont turn,then use the units reversal hex wrench(supplied with most disposers) to back it up and with power OFF clean out the disposer sump,then with a LOT of fresh water try to start it and see if this does the trick
Posted on Jan 03, 2011
MICROWAVE WILL START THEN TURN TABLE STOPS LIGHT GOES OUT AND STOPS HEATING THEN COMES ON AND OFF ANY SUGGESTIONS
Check the door switches. If they are good check the thermal cutouts. Check the connections on the control board.
Nov 12, 2014 | LG Over-the-Range Microwave
Remove trim kit to get to microwave
feel your way around with a fine blade
Mar 29, 2014 | LG Microwave Ovens
My keurig coffee maker displays TCO open. what does this mean and how do I fix it
That stands for "thermal cutout open" in other words the thermal switch activated because the thermostat did not turn off the heating element and it got too hot.
To fix it you would need to replace the TCO, and the thermostat...if you can even find the parts....they are not common parts that fail and will be very hard if not impossible to find...then add to that the time to replace them and you will be better off buying a new machine...
heatman101
Jul 01, 2011 | Microwave Ovens
We have a r-1406 power to outlet nothing at microwave is ther a fuse or reset in machine
No reset, and if it's totally dead, it may be the fuse, the magnetron's temperature fuse, or the cavity thermal cutout.
We have the service manual and have uploaded it to our site here to help you.
The fuse should be accessible just behind the grill.
At our Web site, we have a video available showing how to remove a typical over the range grille and/or control panel assembly in under 5 minutes.
Accessing the oven cavity thermal cutout will require you to remove the oven from the wall, then remove the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
The installation instructions are included in your owner's manual.
If for some reason you don't have yours, you can download it from our site here.
Jun 19, 2011 | Sharp R-1406 Microwave Oven
Came in today; our spacemaker ge microwave xl 1400 would not light up, turn table would not turn, no date or time or anything registering on panel
  1. Check the circuit breaker.
  2. Verify that the outlet to oven has power (plug in a trouble light or other small device).
  3. If you have power there, take the oven off the wall, remove the top cover and check whether you have power at the controller board. (If you don't know where to put the voltmeter leads, take the oven to an appliance tech to perform these tests.) If you power at the low voltage transformer, the board has failed.
  4. If not, check the three thermal cutouts and the fuse. One thermal cutout is located on top of the oven, most likely under the light bulb cover. The next is fastened to the magnetron, and the last is down near the bottom just behind the controller module. If any of these is open, the oven will not work. If the fuse is blown, look for a short circuit before replacing it (check the varistor on the controller board first). The varistor is listed as a separate repair part; don't get soaked for a controller board if this is bad.
Jan 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
There is still power but it will not turn on
It may be a bad fuse or a bad magnetron thermal cutout or oven cavity thermal cutout.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some parts (such as the thermal cutouts) will require you to pull the oven from the wall and remove the cover.
You can download GE owner's manuals and installation instructions here.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Dec 11, 2009 | GE Microwave Ovens
Microwave shuts off after 10 to 15 secs and does not heat up. Would the inverter or magnatron be faulty?
The following List of things would cause that, you can test each one till you find it or drop it at a service center...
-oven fuse
-thermal cutout
-door interlock switch or monitor switch
-thermal cutout
-fan jammed or faulty
-diode
-circuit board, triac or magnetron
let me lnow if you want any further instructions...
~chuck : testamonials appreciated!!!
Oct 31, 2009 | Panasonic NNT995SF Stainless steel 1250...
Ge Spacemaker fan won't turn off
The fan may need to be replaced, and or the drive circuit to the fan has a fault condition.
Jerry G.
May 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Bosch hmt9626 gb 1000w microwave cuts out after 20secs
ur mag netron is faulty the reason for cutting out is thermal cutout switch change magnetron
Jan 20, 2007 | Bosch HMT9626GB Microwave Oven
Microwave Ovens Logo
57 people viewed this question
Top Fisher and Paykel Microwave Ovens Experts
William Miller
William Miller
Are you a Fisher and Paykel Microwave Oven Expert? Answer questions, earn points and help others
