The focus screen assembly is broken. I need to find a replacement
  • dayanclan Jan 06, 2011
    We own a toshiba cinema series model #TN50V71. A repair man came out to my home and said the focus screen assembly is broken and needs to be replaced. Toshiba no longer makes this part. I need to find another toshiba cinema series tv and get the part from that tv OR find the part somewhere. Do you have any leads/connections on finding this part for me?
    Thank you.
  • dayanclan Jan 15, 2011
    Thefirst expert recommended I buy a new focus screen assembly part. However, Toshiba no longer manufactures this part for this tv (model #TN50V71). I need to find another cinema series tv in this model and get the part from it. I was hoping you all knew of or had connections with other repair technicians who would have this part in their shop, so to speak.
  • 4,889 Answers
Sure thing. I assume this is a CRT rear projection tv. Please get me the make and model number of the tv so that I can find you a replacement .
Posted on Jan 15, 2011
    Top Expert:
  • Televison & ... Master
  • 74,473 Answers
Hello
Focus- screen assembly can be bought seperately. its overall resistance is important when buying a new one. It is easy to reconnect also. If its resistance [measured in MOhms] goes less, the unit will heat up and won't get proper focus and screen voltage out, resulting poor quality picture. It will damge the LOT [Line Output Transformer] also. There will be a number marked on it, indicating its resistance and seperations. After replacing it, you have to adjust both focus and screen voltages to get a well defined picture.
You haven't given any details about your TV, so I can't give you furthermore information in this matter. If you wants more assistance, feel free to get me through Fixya. OK.
Posted on Jan 04, 2011
  • The Knight
    The Knight Jan 16, 2011
    Hello
    Focus Screen assembly will have four lead connections out from it. You can see the two controls are marked ouside, very near to its adjusting knobs, as Focus and Screen as the controls works. Out of these for out connections I said above, two of them will ba apart at th to and bottom, and other twos will be in the middle in two rows. The top one connection, which are one amoung the distant connectons, is meant to input the focus voltage from the Line Out put Transformer. Just connect that wire to it. The other connection, which is one amoung the apart at the bottom must be connected to negative, otherwise calles as earth.
    Out of one connection emerges very near to the foucs knob if meant for foucs voltage out and the other left is meant for screen voltage out, and must be connected to the respective connection to CRT base board.
    NB: When switch on the TV for the first time after connecting the screen focus pack, the secreen controlknowb and the focus control knob on the screen focus packe should be adjusted to its minimum, ie extreem left side of you. After connection is over, set it to needs. OK
How to replace I pad 2 broken screen
Is the screen broken or is it just the digitiser? There are many excellent videos available which take you through the process of replacing all parts of your iPad.
However, it is not something that can be fixed easily and you need to exercise great patience in dismantling your broken iPad and replacing the damaged parts.
Make sure you have plenty of space in which to work and place all the parts of the iPad around your working area so they are easy to reach.
Good Luck.
Mar 01, 2015 | Apple iPad 2
The hood release handle under the dash is broken and I need to replace the complete hood release cable assembly
Long at the base screw next to the handle.
You need to make space on the handle end to pull the latch off.
Jan 19, 2014 | 2001 Ford Focus
Ford focus rear window cable broken need diagram
You need to replace the regulator as an assembly. No diagram needed. Regulator bolts to door and window, motor bolts to regulator.
Sep 27, 2009 | 2003 Ford Focus
Ford Focus rear screen washer pipe diconnected at
Ir should just be a rubber hose. Just slide it back onto the fitting again. If the plastic tail has broken off the nozzle you will need to get another from Ford to replace it before hooking it back up.
Aug 30, 2009 | 2003 Ford Focus
How to replace passenger side power mirror assembly on 2001 focus
remove the interior trim from behind the mirror and undo the three screws broken bit comes off and the wires are behing the interior cover
Nov 12, 2008 | 2001 Ford Focus
Camara not focusing/ zoom not working
Its an error code and shows problem of Lens mechanism.
Lens focus / zoom motor is stuck that's why camera gives out of focus image.
You need to replace Lens Assembly and it would cost you more then camera worth.
Oct 26, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Out of focus
Focus motor in lens assembly of camera is jammed and needs to replaced, you can get complete lens assembly from Sony if you wish to repair it at your own. Error code 61-10 shows focus problem in lens mechanism.
Sep 01, 2008 | Sony DSC-T7 Digital Camera
Samsung Rear Projection Problem (not convergence)
The tv has 2 focus adjustments for each tube, mechanical and electrical.
1. Mechanical focus is set by looking at screen from back (through inspection plate on back of most samsungs) and rotating the lens assembly on CRT. loosen wing nut and turn lens assembly to go through focus and back to best position.
Put convergence pattern on screen and manually misadjust bottom red and green lines convergence so they can be seen through inspection hole.
With back cover of TV off you can usually reach your hand up beside the lens assembly to loosen the wing nut then rotate to adjust. Green is in the middle. The focus will be obvious when you rotate and look
When you are finished make sure the foam dust protector is not over any of the lens assemblies and the wing nut is tight.
2. Electrical focus - located at front of unit. the front grille/speaker cover is removed and maybe a cover over the front crt inspection hole.
In the inspection hole there is a black plastic "Focus/screen adjust Assembly" with 2 rows of 3 controls.
One row is focus and the other is screen. The middle controls are for green with R/B on either side. Usually the controls are labelled as "focus" and "screen". You want to adjust the focus controls, one for each color. Look for the focus or screen label imprinted in the plastic. Don't play with the screen settings.
With the same misadjusted convergence pattern you can see a red, blue and green line. Adjust green focus and watch green line for best focus. Do same for other 2.
Screen adjustments are very exact and delicate. The easiest way to deal with them is to turn color off in Customer adjust menu. Put any color tone adjustments in the middle (low, med, high, put at med).
You should have a b/w picture if there are no crt or other color related faults. If it is close to B/W leave screens alone.
If the pix is too green, then the green screen setting must be reduced a small amount. Do not play with these adjustments as most TV repairrers have a difficult time adjusting them.
If focus adjustments don't help then focus control or CRT may be defective. Needs expert to determine.
easyab
http://calgaryconvergencerepair.weebly.com/convergence-ics.html
Jun 24, 2008 | Samsung HCM4216W 42" Rear Projection...
Blurred Picture in the shooting mode
one of the possible cause of the said problem can be a defective or broken flex ribbion cable carrying signal to the focus motor. the replacement of the flex will solve the problem. othe may be friction in the focus assembly. cleaning of the same will do the job. but in both the cases you will need the help of repair shop.
Sep 13, 2006 | Canon PowerShot A75 Digital Camera
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
