Question about Garden
DeWalt DW744 Table Saw, Motor Runs, Blade won't turn. Almost a brand new saw, has only been used on less than 10 times. I have tried to call Dewalt customer service, the machine said they are closed for the holiday. Their service center number also is no being answered. Please help!
  • 520 Answers
The only help i can be is to have you go to this link. it has a parts diagram so you can see what may be causing the problem. you will have to get hold of their service dept for warranty.
jobsite
-table-saw-parts-c-1009_2657_2778.html">http://www.ereplacementparts.com/dewalt-dw744-type-jobsite-table-saw-parts-c-1009_2657_2778.html
Posted on Jan 03, 2011
Testimonial: "very quick with response!"
  • lmsmalley Jan 03, 2011
    Thanks for the info, I have a copy of the parts diagram, hope to get it running again tonight, if not, Lowe's may have the pleasure of dealing with it, after they give me a refund.
    Thanks again for the help!
  • mike42353 Jan 03, 2011
    i am not a big fan of direct drive table saws. i think it is too much stress on the motors. i would rather have an old belt driv over a new direct drive.
The motor sometimes starts right away and at other times I have to use a wood stick to spin the blade and it starts
the brushes in a dw744 have a ledge when they get too short that hangs up. replace the brushes and you should have no problem. the brush holder comes right out with a little coaxing with a screwdriver after the end cap is removed. it just plugs right in.
Dec 22, 2010 | Dewalt DW744S 10" Portable Table Saw with...
Raising and lowering the blade is really tight.
what I do is turn it over and using compressed air blow out as much of the dust as you can and then find a dry silicone type lubricant to thoroughly spray the threads and the slide portion of the saw. let dry and then move blade up and down a few times, you might have to repeat this but it works.
May 23, 2010 | Dewalt DW744X 10" Portable Table Saw
How can i get a guard for this table saw the dw 746
You can order them at www.dewaltservicenet.com.
The DW746 and DW744 use the same guard assembly, if you're talking about the hinged guard over the blade.
Mar 29, 2010 | Dewalt DW746 10" Woodworker's Table Saw
Dewalt dw744 motor runs slow and smokes, what parts need replacing?
probably whole motor, if the bearings started to seize up it could have caused the armature/field to burn or if you overloaded the tool the same thing would happen. Does the tool have a burnt electrical smell, if so the motor is burnt and the cost of parts might outweigh getting repaired, You can go to Dewaltservicenet.com and find out the prices and also you might want to call a Dewalt Factory Service Center and ask them about the MAX repair rate on this tool and they will fix everything for that price, no matter what.
Oct 12, 2009 | Dewalt DW744X 10" Portable Table Saw
The saw has stopped I know the circut it is plugged into is live is there a reset button or built in breaker located on the saw? Dw744 10 inch table saw
NO reset or circuit. You can try and unplug tool and blowing into all the exposed areas of the bottom of the saw. WEAR safety goggles. Then what I would do is check the brushes and if you have a volt ohms meter check the continuity to the brush tubes. Start at the cord looking for a break in wiring and go from there. Let me know if you need more help, but I am going to thing brushes or switch
Jun 27, 2009 | Dewalt DW744S 10" Portable Table Saw with...
DW744 table saw
Balde movement up and down? If so, that would suggest worn bearings in teh gearbox. If they are worn there then they might also be worn in the motor. If this happens the armature will float up and down causing it to rub against the stator. You may be able to get the bearings sorted without needing any new motr parts. I beleive this saw uses an induction motor so beware if it does need replcing you might want to be sitting down when you get the quote.
Oct 19, 2008 | Dewalt DW744 Factory Reconditioned Heavy...
Garden Logo
361 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
