Question about Cobra 29 LTD CB Radio
I turn on my cobra 29LTD BT and theres is no RF gain nose what so ever. I put a new coax on and still nothing. The RF gain is alll the way up.The RF gain comes and gose.
  • 391 Answers
Firstly check your antenna feed (coax) for short with multimetre if this is ok problem might be your audio stage in the radio might need to be replaced hope this helps
Posted on Jan 27, 2011
    Problem Solver:
  • 44 Answers
Check antina
Posted on Jan 03, 2011
My cobra 29ltd will transmit but want receive
three things you need to check the mic must be plug into radio, make sure that the radio is set to cb not pa,check your rf gain is turned all the way up and last of all check the antenna.Now that being said if the radio does not receive you might have to take it to a radio shop.
Jun 11, 2014 | Cobra 29 LTD CB Radio
I have a Cobra 29ltd CB with no sound coming from the internal or external speakers. So I went out and bought another Cobra 29ltd thinking that the old one was shot. Hooked up the new one and the same...
are you using the antennas that are installed thru the mirrors or the ones on the side of the truck. If you are using them you should make sure that they are connected to the coax. some just get thrown together ,antenna to mount then one end of coax to ??? so take a multi meter and set it on x1.Touch bottom of the antenna and the connector that come out of the dash. If you are connected you should get a reading. If you are not ,then you will have a problem hearing anyone because you are not connected to the antenna but the coax. If the connection is good to go then I would try running a ground wire to the chassie and maybe even a ground strap.
Mar 09, 2013 | Radio Communications
How to adjust the rf gain on a cobra 29
there is a knob on the front of the radio the says RF GAIN. Turn it all the way to the right and you RF GAIN is at its max
May 08, 2012 | Cobra 29 LTD CB Radio
New 29ltd army power in and all through radio but wont come on at all
This is not meant to be insulting but is CB/PA switch set to PA?
Squelch full counter clockwise?
RF Gain full clockwise?
Jul 30, 2011 | Cobra 29 LTD CB Radio
I have expanded my 25 ltd and want a rx/tx fine tune possibly using the rf gain control?
look at a schematic of a 29ltd to do that.. the 25 does'nt have it in there easily.. the 29 can be fixed to change tx/rx freq. with the delta tune
Feb 11, 2011 | Cobra 25 LTD 40-Channels Base CB Radio
I can't here people talking
There are some things that can cause this to happen that are simple fixes, and then others are issues inside the radio that need a tech's diagnosis.
I will give you the simple issues.
  • RF gain is down. turn it all the way clockwise.
  • Squelch is too high, turn it down until you hear fuzz, then turn it up until it stops.
  • You my have a problem with your mic. When there is a broken wire in the mic cord then the radio will not go into receive mode. Try a new mic.
  • You may have an antenna or coax problem. Make sure the antenna is tuned to the best SWR, and make sure there is no damage to the coax.
Hope this helps.
Oct 22, 2010 | Cobra 29 LTD CB Radio
I have a cobra 29ltd crome had echo board installed works good till i trun my la 900 on get feed back or squilling how do i fix
LA 900? I am guess that is a linear amplifier. If so are you running a power mic? You are probably getting RF feedback. You need to turn the gains on the radio and mic down.
Some things you can try. Hold the mic cord in your other hand in the center of the cord while you key it. some times this will shield it form stray RF.
You can also get a bunch of RF chokes from radio shack. They are little black things you snap onto wires that shield form RF. Put 2 near the plug, and 2 near the mic. That will help shield it from RF.
you will most likely still have to play with the gains on the radio and mic to find a sweet spot where it doesn't squeel.
Oct 06, 2009 | Radio Communications
Lot of fed back
Make sure the antenna has a good clean ground. I know it sounds silly, but here's what's happening: You're getting RF feedback. If you don't have a good ground at the antenna, some of the RF travels back down the coax and makes the whole radio "hot". Some of that RF couples back into the microphone input, and causes feedback.
It's also possible that if your amp is really big, you're getting RF feedback directly from the antenna itself due to the really strong field.
You could try moving the antenna further away from the radio, or if that's not practical, some snap on ferrite chokes (available at radio shack) around the mic cable near where it enters the radio will probably solve the problem.
Oct 06, 2009 | Galaxy Radios DX-66V Base CB Radio
When the antana is hooked up i get no responce
check your coaxe to make sure it is hooked up right and make sure your RF gain is turned up
Aug 09, 2009 | Cobra 29 LTD CB Radio
My cobra 29ltd classic turns on but nothing else works. the meter dose not move when I key it up, and no one can hear me
Hello jeffssmit909,
This is an indication of the final RF power amplifier malfunctioning. First if you have a background in electronics you can get the schematic and measure the voltage levels with a multimeter to determine if the RF power amplifier stages or bad, in addition I would check the power supply section to.
By the way is the audio work, in other words can you hear other CB's when you turn your system on? Please reply, it will help in the diagnosis.
This is a good starting point. let me know how this turns out.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 21, 2009 | Cobra Radio Communications
Cobra 29 LTD CB Radio Logo
155 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
