Hi there Im afraid your TV is not going to be digital, which means you will need a convector box to receive the digital channels. Hope this helps TV_Doctor
The need depends on what country you live in. In the US,Canada,and Mexico there are no longer any analog TV signals Everything broadcast over the air is digital. A digital to analog converter is available so older TV's without a built in digital tuner can be used.
Some flat screen tv's have two inputs, one for digital and one for analog reception. If your local public television station is analog, then you'll need a signal input on the analog input.
You might try temporarily moving the input from the digital to the analog then doing a new channel scan to see if this picks up the PBS station. You'll have to rescan again, when you move your antenna lead in back to digital.
A digital comb filter is not a tuner. It helps improve the appearance of digital content by splitting the luminance (brightness) and chrominance (color) of a digital video signal (DVD, or other set-top box). This filter is only needed when digital content is going to the TV over RF (coax) or composite (analog) inputs. http://electronics.howstuffworks.com/tv-buying-guide18.htm has some details on the filter,
Please provide the model number of the TV for additional information about the tuner. Normally the tuners will be listed as NTSC (analog), ATSC (digital), Clear QAM (unencrypted digital cable) in the US. In other countries you have PAL (analog) or DVB-T (standard definition digital terrestrial) or DVB-C (standard definition digital cable) signals.
did you switch the TV's incoming signal to digital antenna? For the cable box it was probably set to cable antenna or analog inputs, not all TV's have automatic switching for antenna feeds. My Mitsubishi has 1 digital and 1 analog antenna input and the cable box will only work through the antenna input if it's the analog antenna input and it's tuned to channel 3 or 4, -(or through a seprate HDMI, PROSCAN, SVCR,or a yellow RCA plug input)- and when the analog antenna input is selected the TV will tune all analog cable channels that the cable service offers if a box is not used. likewise the TV will not tune any channels at all if it's set to digital antenna inputs. It will tune all local channels only when set to digital antenna inputs.
Yes it should work, connect the RCA video out (yellow connector DTV Converter) to the RCA video in (yellow connector TV set). Then connect the RCA Audio out (Red-Right White-Left DTV converter) to the RCA audio in (Red-Right White-Left TV set).
Then setup your converter box according to the manufacture's instructions.
Sounds like you've lost your red video signal (chroma) somewhere along the line. This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. The analog has all your inputs on it, except DVI and RGB which go straight into the digital board. The digital scales (upconverts) the signal to HD (1080 or native) and sends it to the DMD or light engine. See which inputs are distorted. If only DVI is clean then you problem is the analog board. If you menu and everything is distorted then suspect the DMD board. If you run component or DVI through the resolutions (480i, 480p, 720p, 1080i) you can get an idea between the digital board and dmd. The menu is generated on the digital board. Somewhere red is getting lost.
For a Durabrand DWT 1304 Owners Manual, access TV Manuals Online here. You can easily download it. The manual is in .PDF format and showed exactly what I needed, how to delete a channel from the list.
I realize this query was posted a long time ago, but perhaps somebody else looking for the information will benefit from it/
First of all component inputs are analog as the only digital inputs are the DVI or HDMI inputs on a TV. You might have color adjutments in the menus somewhere that allow you to compensate for color weakness on one or more colors. If not you most likely have a bad digital board.
