Question about Microwave Ovens
Hello where I can find a replacement engine for techno wind hood type DTA01 I'm located in the US
  • 8,197 Answers
Email the range hood store at sales@rangehoodsstore.com to have the part ordered for you.
Posted on Jan 07, 2011
I have a Rangeaire Stove Vent/ Hood. I am having a hard time locating the model #. It was probably made around 1982. Ideas how to find the model # as I need replacement parts. Please & thanks!
I reckon it will be in one of two places. At the place where the mains wire goes in (rear), or under the hood where the filter or light is.
Jul 05, 2016 | Microwave Ovens
Microwave VENT fan keeps running
I would say you replaced a good hood thermostat (or "TCO" / thermal cutout) with a new thermostat of the wrong type.
The oven cavity TCO and the magnetron TCO will read zero ohms continuity when tested.
They are "normally closed" devices.
But the hood vent exhaust fan's TCO is a "normally open" TCO or thermostat, so it should read open or "infinity" on a continuity check.
If the temperature under the microwave gets too high, the hood TCO opens, which turns on the vent fan until it cools back down.
I would bet that only your fuse was blown.
May 18, 2013 | Microwave Ovens
Microwave turntable won't revolve
Hello
Inspect the turntable base wheels and guides. If they are gummed up with food or other gunk, they will not turn and the turntable will not rotate. Clean as needed.
Remove the microwave case by unscrewing the casing screws with your screwdriver. Locate the turntable motor which will be directly beneath the oven floor.
Inspect the belt that connects the motor to the rotating table. If the belt is broken, replace it.
Touch the probes of a continuity tester to the electrical contacts on the motor. If the tester lights up, the motor windings are good, which means the motor is functional. If there is no light, the motor needs to be replaced.
Check the wires leading from the cord to the motor itself. Look for any breaks in the wire, or a wire that has been pulled off of any electrical connection. Any connection that has been compromised can be soldered back into place, but if the cord is damaged at all, it needs to be replaced.
Attempt to spin the motor by hand if the continuity is good and the belt is in place. It should spin freely, but if it is difficult or doesn't move at all, you will need to lubricate the bearing. Either apply spray or bearing lube to the motor axles to solve this problem, and allow the motor to spin freely once again.
Oct 04, 2011 | Microwave Ovens
I have a KitchenAid 2004 Microwave (Microwave hood combo). I was heating up some water....there was a snap...a puff a smoke and then everything went out on the microwave -- no lights, no numbers, no...
Hello & Welcome to FixYa
The problem is with the fuse or the high voltage transformer that is bad and needs replacement. Replacing the fuse will cost you under $100 from a professional and getting the transformer replaced will cost you around $200. As the unit has very high voltage inside so we don't recommend that this should be done by the user. Please get back to me if you have any other questions.
Kevin
Jun 27, 2011 | KitchenAid KHHS179LSS Convection /...
Tecnowind DTA01 motor not working
Check the motor for free running with an external voltage, check if the motor is jammed, if so remove to free with lubrication with light oil.
if not the motor is faulty or there is no power from the control board. It can be failure of the driver/relay to the motor.
Apr 27, 2011 | Microwave Ovens
Hello... i have a GH4184XSB-1 microwave/hood-oven combo. I was removing the light bulbs --- which were broken off from the glass to the metal bottom --- and the unit's electricity blew. Breaker is...
there are some other fuses on some circuit boards inside the oven.Try finding them,one is located on the control panel PCB.Perhaps that is blown!
Aug 23, 2010 | Whirlpool Microwave Ovens
Cooks Model 2115 microwave oven will not power on when connected to the 110v outlet. Can this be a fuse problem? If so, where is the fuse located?
Yes, is probably the fuse. I have fixed several microwaves with this problem and the fuse is almost always located just inside where the power cord enters the unit. Just remove the skin (usually screws on the back and BOTTOM also) test the fuse with a micro meter. If no contenuity, replace with same size, type and rated fuse. Most microwaves are 20amp fuse.
Jan 19, 2010 | Microwave Ovens
Whirlpool microwavewave hood comination mh3184xp
My Whirlpool MH3184xps is shooting a spark when in use with the rack. When the rack is removed the oven works fine. I am guessing that some of the coating on the rack has cracked and peeled and is exposing some aluminum. Has anyone else had this problem?
Feb 04, 2008 | Whirlpool MH3184XP Microwave Oven
Fans do not work properly
If the hood fan is not working at all, it would be due to a bad connection or other problem on the control panel (circuit board) or an open thermal or winding in the hood fan motor.
If you or a friend want to troublesoot this, I can give you some tips.
We have critical safety and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 04, 2007 | Sharp R-1870 Convection/Microwave Oven
Need replacement bulbs for over-range hood
These are 20W 120V bulbs with what's called the intermediate base. The new Panasonic part number is ANE6030540AP and you can get them at Tritronics at http://www.wehaveparts.com or Vance Baldwin at http://www.vancebaldwin.com You should also be able to get them at local appliance parts stores, Lowe's (or similar) or even a large grocery store. You can also use Sharp part # RLMPT0003YBE0 from either of the above sites.
Dec 13, 2006 | Panasonic NN-2505A Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
