Question about Kyocera wild card Cellular Phone
My phone keeps saying "This
When i try to send a message/text on my pantech p7000 it keeps saying message sending failed. what do i do?
the best thing to do is take out the sim and reinsert it as your phone might have lost some configuration to send/receive a text message. If that doesn't work then your phone company might have erased txt messaging from your plan. Contact them.
May 04, 2011 | Pantech Cell Phones
Multiple texts sending when i only send them once!
it could be because you didnt have enough service to send them wit
Feb 18, 2010 | Cell Phones
My Nokia e51 wont send txt msg's, it used to be
there is a service center number in your message setting. if it is edited your messages wont go . correct service center can be taken from your service provider. if that is right the reset your phone once it will start working fine.
Aug 27, 2009 | Nokia E51 Smartphone
My Nokia N73 phone keeps saying 'memory full delete data' when i try to send txt - but there is no data to delete, txts , images etc are empty. And memory details say there's plenty of memory. What's...
you just have to reset your phone press*#7370# this will reset your cell phone and then it will ask for the code then enter your code thats all
Jun 08, 2009 | Nokia N73 Cellular Phone
N95 NOT SENDING TXT SAYS MEMORIES FULL
Probably a virus.. setting it back to factory settings will not work most of the time, got the same issue but on my older nokia 6600, try a hard reset.. press #7370#.. this will erase everything in your phone... contacts.. old messages..images.. i mean all.. back up first before doing this.. =)
have fun
Aug 20, 2008 | Nokia N95 Cellular Phone
Mobile phone been charged
same to me!
there appers no way stop them. whatever how many you top up, they still took you money away for txts, call.
i tired to remove it, but it didnt work
now i am going to change my sim card! dont believe this again, how silly we are!
Jul 19, 2008 | Cell Phones
Security Code problem
hi,
The default security code for Nokia is 12345.
You can recover the password. The best way is to download a file manager to your phone. I use Best Fileman for my N70, from http://www.smartphoneware.com/ It’s for series 60and 40. The trial version should be enough.
In the file manager (when installed on your phone) you’ll find under- C:\System\mmcstore -the file you’re looking for, you have to rename the file- mmcstore.txt -then send it to another mobile (best way) or your PC via luetooth or USB, open it on the other phone and your password will be revealed.
Rename that file- mmcstore.txt -to just- mmcstore -there might be another file named- mmcstore.txt -to view your password rename one or the other- mmcstore1.txt -one is for your phone PIN number the other your MMC card. If you reset (format) your phone you will lose all the data stored on it. Resetting sometimes gives negative results. You can reset it through your menu, if you can switch the phone on of course.
Using the reset code is not recommended,so keep it the last chance.
Try this for hard format:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
THANK YOU!!..
Jun 29, 2008 | Nokia 6300 Cellular Phone
No pic/video txt can be rec'd or sent out
try master resetting the phone and master clearing it , if that does not work then call you mobile service provider for them to assist you
Sep 28, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Kyocera wild card Cellular Phone Logo
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
DROPNDEAL
DROPNDEAL
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
