Question about Sony DSC-T70 Digital Camera
Cannot get the option to turn flasher back on
    Problem Solver:
  • 11 Answers
Maybe just after you turn the camera on , click on Disp. on the right down corner and then click where it says "Normal", it will show you all types of options when you're going to take pics. also the flash option on the right middle part.
I wish I helped with something.
Posted on Jan 21, 2011
Yamaha vstar 650 2007 turn signals stays solid on and does not blinks after front turn signal replacement to led's.
flashers work buy a set current flow
flasher bulbs are 20 watt or better
by replacing the bulbs with LED ( virtually no current flow ) the flasher will not get enough current to make it flash
you have 2 options
go back ti normal bulbs
get an electronic controlled flasher unit that compensates for the lost current
best talk with an auto electrician as to what you need to fix the problem
Oct 07, 2016 | 2007 Yamaha V Star Custom
Everlasting turn signal flasher or relay location on a club car
Turn signals have never been a factory option on any standard carts. Only on models like the villager 8 passenger. Most likely behind the dash.
Feb 16, 2014 | 1998 Lincoln Town Car
69 Camaro Turn Signals not working
check relays and turn signal-flasher. flasher for turn signal is separated to the hazard flasher.
Oct 31, 2012 | Chevrolet 1969 Chevy Camaro Z/28 1/18
Where is the signal flasher can for a 1997 sonoma gmc?
For 1997 GMC Truck Sonoma 4WD 4.3L SFI OHV 6cyl the Flasher is located:
* Front seating area, driver side, passenger side ofsteering column, under dash, mounted near cigarettelighter. Optional mounting location is under dash,on driver side of steering column
Application: Hazard flasher
Application: Turn signal
Hope helps (remember to rate and comment this).
Oct 02, 2010 | 1997 GMC Sonoma
My turn signals wont work. i changed the fuses and checked the lights
Change the flasher unit, it's a cylinder type object, either blue or silver in color, usually in the fuse box, just pull it out and push in like a fuse.
The emergency flasher is the same shape, so don't cunfuse that with the turn flasher. To get the right one, turn on the 4 ways, put your finger on both of them, and whichever one you don't feel clicking is the turn signal flasher.
May 08, 2010 | 2003 Pontiac Grand Am
Pm0418000does not charge. the muffler has a hole toward the generator and it probably overheated the field poles.the black box unit in the back of the generator has a burst what it looks like a turn signal...
That "Turn Signal Flasher", sounds to me, suspiciously like a Capacitor, especially if it has "Blown" I think your "Black Box" has taken a hit & is stopping the output. I would think replacement is your only option.. well unless you can replace the parts and fix it?
Feb 03, 2010 | Coleman Powermate Powermate 5000W...
Where is the location of the turn signal flasher?
I have a 94 Sonoma and to locate the turn signal flasher, inside, under dash, on left side is a plastic sound protector, mine had 3 screws holding it up, drop this down and straight in you will see a 1" round thing - this is the flasher.
Jan 08, 2010 | 1995 GMC Sonoma
Where is the turn signal flasher on a 99 alero
THE TURN SIGNAL AND FLASHER ARE TIED IN TOGETHER.YOUR FLASHER SWITCH IS ON THE DASH.ITS A ROUND RED BUTTON WITH A WHITE TRIANGLE ON IT.WHEN YOU PRESS THE RED FLASHER BUTTON ON DASH.IT WILL MAKE YOUR FRONT AND BACK SIGNAL LIGHTS BLINK.WHEN YOU WANT TO TURN OFF FLASHER THEN YOU PRESS THE RED BUTTON.IT WILL TURN OFF FLASHERS.
Aug 10, 2009 | 1999 Oldsmobile Alero
1995 F150 the turn signals do not work, but
Look in the fuse panel and the turn signal flasher is the big round most likely yellow or silver in the corner of fuse panel. The emergency flasher is in the back side of fuse panel right directly behind the turn signal flasher.
Remove the emergency flasher and install it in place of the turn signal flasher and see if this corrects the problem and if so get a new flasher. If this does not correct it problem will most likely be the multi-function switch.
Mar 13, 2009 | 1984 Ford F 150
Blinkers stopped working
Your F--150 has 2 flashers, emergency and turn signal. Both are mounted on the fuse block under the dash. The turn signal flasher is mounted on the front of the fuse panel, the emergency flasher is mounted on the rear of the fuse panel. so replace the turn signal flasher should solve the problem. Let me know how it goes.
Oct 20, 2008 | 1996 Ford F150 Regular Cab
Sony DSC-T70 Digital Camera Logo
27 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
