Question about Kicker CompVR 05CVR84 Car Subwoofer
Wires keep breaking
I have 2 Kicker CVR's and the wires from the coil to the connector keep breaking. I had 2 previously with the same problem and lucky for me the guy at the store where I bought them replaced them. But now same issue with these two new ones. I tried replacing the wire with regular speaker wire but that lasted about a day. Any suggestion on a good wire I can use so I don't keep having this problem?
According to a shop around my neighborhood, Kickers are known for the wires breaking, even on the new Kickers.
Hell yeah dude havin the same prob. here do u know where i can take mine to have them fixed????
gausa103@hotmail.com
Posted on Dec 15, 2008
I have 2 different subs in one box, a 12" MTX thunder and a 12" Kicker CVR. the kicker is a dual voice coil while the MTX I dont believe is. Can I use one amp for this set up? And how would it be wired?
im guessing both speakers are 4 ohms ..mtx 4ohms and kicker dual 4ohms..now if your amp can go down to 1 ohm wiring the kicker dual coils in parallel (2ohms) and the mtx connected together (4ohms) should leave you with a final impedance between 1 and 2 ohms ...i suggest you use one or get another
Oct 08, 2013 | MTX Car Audio & Video
How do i wire a single 12" kicker cvr dual 2 ohm
Simple power fom amo to power on sub. Ground on amp to ground on sub
Feb 28, 2013 | Car Audio & Video
I just bought a cvr kicker 10' sub, hooked it up in my car replaceing a polk audio sub. The kicker keeps blowing my fuse. i have checked the wireing. i have an 800watt sony xplode amp. Please help
i am assuming that you bought this sub used? their could be a problem with your voice coil. the voice coil moves the cone of the speaker in and out. the problem with the voice coil is that it has become lose and is doping the impedance of the sub. A lose voice coil can be cause by over powering the sub. this problem is not fix able.
Aug 01, 2011 | Kicker 01C8VR4 Car Subwoofer
How do i wire a kicker cvr if it has two reds and blacks
the sub is a dual voice coil, and depending on how you wire them, gives you different bass response as it drops the ohms in your amp. it can be wired for 2 ohms one way 4 ohms another way or 1 ohm depending on what ohm the coils are. to learn more about this got to rockford fosgate.com, click support, then click woofer wiring wizard, this will answer all your questions about dvc subs.
Feb 10, 2010 | Kicker CVR15-4 Car Subwoofer
How to connect dual vouice coil to amp
Hey well your gonna need to give more info. is the sub dual 2ohm dual 4ohm. if you have a dual 2 ohm you wire one + to one- (like a jumper wire)and then your other +.- go to your amp as 4ohms, if you have a dual 4ohm model and your amp can handel 2ohm stereo then wire your +to+ to +on the amp and the same for your -. it will bring a 4ohms to 2 ohms by connecting pos. to pos. and neg.to neg. then to your amp.
Jan 18, 2010 | Kicker CVR12 Car Subwoofer
Logic soundlab cpx1400 need to wire to a kicker cvr 15
Hello discrete01,
The Kicker model number 07CVR122 has dual 2 ohm voice coils, and can be wired for either 1 ohm or 4 ohms. Model number 07CVR124 has dual 4 ohm voice coils and can be wired for either 2 ohms or 8 ohms.
Kicker's wiring page is here: http://www.kicker.com/dvc_wiring
If you have the version with 2 ohm voice coils, you want to use the 2nd diagram for a final load of 4 ohms to the amp. The 1 ohm load is too low for the amp and will cause it to overheat and possibly fail. If you have the 4 ohm version, use the wiring shown in the 3rd diagram which is a perfect match for the amp.
Hope this helps.
Aug 11, 2009 | Kicker CVR12 Car Subwoofer
I have 2 12 in kicker cvr tryna drop to lower ohm
http://www.colomar.com/Shavano/dvc_spkr_wiring.html
Use the above site for several wiring schematics on dual voice coil speaker hookups. It will show how to wire for different impedance.
Also, I think the CVR 12's come in 2 ohm and 4 ohm impedance. See if you can check yours to determine which you have....
Jun 28, 2009 | Kicker CVR12 Car Subwoofer
How to wire 2 kicker cvr woofers for 2 ohms
Asuming they are 4 ohm voice coils and only one per woofer then just join the +'s together and the -'s together.
Mar 05, 2008 | Kicker CVR12 Car Subwoofer
10 inch cvr kickers
Option 1 (series/parallel) = 1 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 4_2ohm_dvc_1ohm.gif
Dec 17, 2007 | Kicker CVR12 Car Subwoofer
TROUBLE WIREING SPEAKERS
Lots of info here; http://www.the12volt.com/Default.asp? You have to register, but its free. Best of Luck.
Sep 24, 2007 | Kicker 01C8VR4 Car Subwoofer
Kicker CompVR 05CVR84 Car Subwoofer Logo
97 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
