Question about LG 37LG30 37 in. LCD HDTV
Speakers had a buzzing/vibrating noise. had them replaced. still making same noise. happens on very low and loud volume. any idea what it could be? possibly the sound board?
  • 65 Answers
Maybe just poor speakers.....had a similar problem with an old sony. Replaced the speakers twice and always had a noticeable buzzing. Try running external speakers (computer speakers will work) at low volume to see if you hear it in those. If so, you may have sound board issue.
Posted on Jan 03, 2011
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Emerson tv problems
If you are using a cable or satelite box, the problem could be from mismatch of the volume level between the TV & the source. This is solved by properly adjusting the 2 volume levels to eliminate the buzz.
The issue could also be either your speakers or Input/Output PCB.
Also be sure it is coming from the speakers.There have been some issues of buzzing caused by vibrating transformers on circuit boards,
Jul 24, 2014 | Emerson LC320EMXF 32 in. LCD TV
I have a pair of JM lab Electra 905 speakers, running through a DNM amp and power amps. When powered up, the left speaker makes a very loud humming noise. This has happened recently. I haven't changed...
Hello
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
Apr 10, 2011 | Jmlab Electra 905 Speaker
Makes loud buzzing sound when first turn on then fads to a low noise after about 5min have disconect all apps turn all of tele still buzzes
This is a Switchmode transformer, a Choke, "Buzzing" this is happening because something is "Ringing" and causing the windings to vibrate and thus produce an audible signal, this usually happens prior to a unit faulting and is caused by too much current, or the incorrect oscillation frequency, overloading it, and it makes a noise due to it. You need to get this attended to, as it may, fail, and cause a fire or an explosion, or both.
May 09, 2010 | Televison & Video
Buzzing noise while making a call
This happens at many phones due to the speaker which buzzes because of the waves made by the conversation. For example try calling someone and be near a desktop pc speaker or radio and you'll hear the same buzzing noise
Feb 19, 2009 | LG Dare VX9700 Cell Phone
Loewe Articos 55 HDTV loud buzzing noise
sorry cant solve it ,i called all the loewe service agents and they all said the same thing, put up with it. a new engine/colour wheel cost around $2500,
Aug 27, 2008 | Loewe Articos 55 55" Rear Projection...
Samsung 7178 buzz noise
Is this buzz from the speakers?
Is this buzz from the set itself when the sound is turned down?
Is this buzz a low pitch sound?
Is this buzz a high pich sound?
Does this buzz vary in loudness with the volume control?
Does this buzz change in level from time to time?
You should post the details and the circumstances of use in order to give some idea of the conditions.
Jerry G.
Apr 16, 2008 | Televison & Video
Vizio speakers make a buzzing noise
It's not the speakers. I usually hear of this problem when hooked up to an HD cable box. You can adjust the volume on the cable box and also on the TV. I'll bet you don't have this problem when watching a DVD.
If the problem is what I think it is, your HD Cable box is set at a really low volume while your TV is set to a rather high volume. Try setting the TV volume to around one-third, then set the volume on the cable box until it's as loud as you'd ever want to hear it. With the TV at such a high volume, you're actually amplifying any stray electronic signals that the wires might be picking up, and the above solution will fix that.
Good Luck.
Mar 08, 2008 | Vizio L37 Television
Loud buzzing noise
Bad connections or faulty wires check the wires and the connection of the wires, usually the buzz is a bad earth
Nov 16, 2007 | Acoustic A-5640 Computer Speakers
Very loud fan or vibration noise
Listen from the back of the TV and locate the source of the noise. There may be fan with a bad bearing. The noise will lead you to it.
Nov 06, 2007 | Soyo Dymond DYLT037A Television
LG 37LG30 37 in. LCD HDTV Logo
635 people viewed this question
Computer Repairing
Computer Repairing
