Question about Bosch 23 in. SHU303 Built-in Dishwasher
Aggravating loss of power
We own a Bosch dishwasher that started having problems when it began to slip out of the built-in space. Now, the dishwasher will start just fine, but will mysteriously shut down mid cycle on a regular basis. I can get the cycle completed only by opening the door, letting the dishwasher cool, then re-locking the sytem. It will start again where it left off.
Is this an electrical problem or is the dishwasher broken?
    Master:
  • 555 Answers
It sounds like a heat sensor is being tripped (or shorted)
Posted on Jul 09, 2008
  • Matt Jurach
    Matt Jurach Jul 09, 2008
    Can you try a cool wash cycle to see if the washer still shuts down midway? If it does not, that clearly indicates a heat sensor issue.
White power residue all over dishes and dishwasher
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Jul 17, 2011 | Bosch SHX46A01UC Built-in Dishwasher
My Bosch dishwasher was not installed with an "
From an internet posting ::
The purpose of the air gap is too prevent back-flow and siphoning, and newer dishwashers (past 20 + years) have back flow preventers built in and looping the drain hose (not a circle, but an upside down u to the top of the cabinet or behind/side of dishwasher) prevents siphoning. Aside form being ugly space wasters the cheap air gaps have a tendency to spit and cough water out.
Read more: What is the purpose of an 'air gap' for dishwashers? ' Answerbag http://www.answerbag.com/q_view/92208#ixzz1ACnxhxz3
Jan 05, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher does not complete cycle
The problem is the timer/control. I checked for a recall but your model wasn't on the list. Many of these had a recall for the control, they were a fire hazard. Heres a link to help install the timer/control http://appliancehelponline.com/dishwashercontrol.html. When you remove the front panel there will be to plastic hinge covers be sure to reinstall these they help keep it quiet. They just slip over the hinge. The rest of the removal will be the same.
Jun 02, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
Jan 13, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
Bosch Dishwasher will not power on
I saw my repair man do the following, which you might try...
Open the door and simultaneously press & hold down the power button with the 2 buttons used on your model to "Cancel & Drain." If the unit comes on it now is in self-diagnosis mode. Release the buttons and close the door. The unit should start to fill with water. Press the power button to exit the mode.
Jun 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch dishwasher wont drain
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Feb 22, 2009 | Bosch 24 in. SGI43E05GB Built-in...
Bosch dishwaser
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Hope this may help;
DON'T FORGET TO RATE;
Aug 14, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Latch stuck on bosch dishwasher
We removed the front door. Where the latch is located, there was a white piece with a pin sticking out and a cross bar that was held in place by the white piece. We used a screwdriver to open a space in the white piece so that the cross bat could slip out the bottom of the white piece. Then, we could push from behind on the metal part that had the pin. The metal part rotated and released the latch. We then replaced the cross bar into the white piece. Be careful -- the solution worked to unlatch the latch, but our diswasher still doesn't close well during the wash cycle.
Jun 16, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch 24in SHU43, 3 years old
Un plug it for about an hour and  try it again.Its probably built a static problem on your circuit board.
May 25, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 23 in. SHU303 Built-in Dishwasher Logo
195 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
