Question about Yakima SkyBox 18
My skybox will not open. i'm not sure if it's jammed. if it is, how do I open it?
The box keeps searching for channels
hello,silly question is the aerial connected, also if you've got s skybox make sure it's connected i'e the aerial is in the skybox and a lead from the skybox to the tv
regards
shaun
Oct 24, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Tip
Dispensing Problems
I have just replaced a rack in a Skybox and did some disassembly to see what I could find. On the backside of each rack is a hub in which the drive motor mounts. Inside that hub is a card with two sensors on it which the white ribbon with the 4 wires connects to. One sensor is for the "Home" position which the dispensor goes to if it is empty. The other sensor reads a small piece of metal embedded in the flap which tucks up under the dispensing drum. It is not the flap which is just about horizontal as you you look into the machine. This piece of metal is sensed and tells the machine whether the flap has returned signalling if the machine is jammed. Ensure that this flap moves freely and move it around to see if the jam disappears. This is likley why many jams disappear if you open the door and close it firmly.
on Jan 17, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
My skybox will not dispense. When a button is pushed, all indicator lights flash. All conpartments are full. I have removed all cans from the machine to check for jams in each individual compartment and...
I had this exact same problem and it was the door sensor for the flipper where they come out. I used a door alarm contact and it fixed the issue. $5 to fix it and get it up and running again.
Sep 12, 2010 | Maytag SkyBox MBV1976A Beverage Dispenser
The jam indacator lights are on but there is no jam
un plug for 5 min start over and it may be ok and if not the prosseer has ffailed . mm
Aug 20, 2010 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox beverage dispenser. will dispense one can
I had the same problem. Found the cover where the beverages dispense to be rusted and not resetting. After the can dispenses, just push the cover back into position and this should help.
Jun 09, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Jamming dispencer for my skybox maytag.
You may not have a dispenser problem at all, but rather a build up of frost and ice. The evaporator is embedded in the interior wall directly behind the two middle dispensers. The dispenser effected most bt the ice build up is the second one from the bottom. Unplug the unit and leave the door open for 24 hours. Then plug it back in, reset your thermostat at the 11:00 position and close the door. If the problem is still present, the next step would be to remove the dispenser assembly and search carefully for a disc shaped magnet about the size og the leter "O" on your keyboard. There are 9 of these magnets in the SkyBox. The dispensing cylinder has one built in, as does the flap at the end of the dispensing row. When the cylinder moves to dispense a beverage, a reed switch detects the magnet. Next it looks for that flap at the end to open when the beverage falls down. Finally, as the beverage comes out in the door another reed switch detects the opening and closing of the flapper door. If the board does not see the signal from any of the reed switches, it assumes there is a product stuck someplace.
I hope this helps.
Feb 25, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Removing compressor from skybox
Maytag never offered a replacement compressor for the SkyBox units. It was not a cost effective repar to make. If you are sure the thermostat is supplying 120VAC to the compressor, you can install a Supco URCO410 relay/capacitor/overload kit. This part should only be installed by a qualified service technician.
Feb 22, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox
For the soda name tags, I pulled logos off the internet and printed them the correct size on 20-pound paper. Different paper gives different translucence, so you might have to experiment to get the right amount of light coming through.
PS: thanks for the part no. on the relay
Apr 21, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox Beverage Dispenser/Refrigerator
TroJo, Try PartSelect.com for Skybox parts. I ordered a part on Monday night and installed it on Wednesday night. The parts are not that hard to find. Appliance repair services can replace your compressor or add freon. Be sure you have plenty of ventilation behind your machine. Jonmon
Mar 23, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Yakima SkyBox 18 Logo
353 people viewed this question
Top Yakima Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Yakima Winter Sport Expert? Answer questions, earn points and help others
