Question about Zanussi IZ161W Front Load Washer
Does not start and shows error E40 - Zanussi IZ161W Front Load Washer
What does error E40 mean
Zanussi Washing Machine E40 Error Fault Code
Electrolux Time Manager How to Fix Error E40
E40 indicates a problem with the door lock circuit in the appliance.
It could be as simple as a faulty door lock or it can be a faulty main control board.
Jul 16, 2017 | Washing Machines
Built in machine. It show error e40. What does it meant
Hello Monica, thank you for your post!
Based off the information you have provided your Electrolux washer is displaying an error code of “E40”. I am showing that an “E40” error code means this could be an issue with your door swicth or main control board. I would recommend performing a reset on your washer and you can do that by disconnecting the power cord for at least ten minutes. If you continue to receive the error code once power has been restored you may need to seek assistance from a professional technician for a proper diagnosis. Hopefully this information is helpful to you. –Matt
Mar 23, 2016 | Electrolux Washing Machines
Electrolux ewf1074 error e40
I've just bought one of these machines, and the manual says the E40 warning means the door is not properly closed. Seems like that would be obvious if it were true, but maybe check that it is closing completely.
Apr 09, 2009 | Electrolux Washing Machines
Error codes E40 andE70 showing on model zwf1640s(zanussi)
E40 is an error from the door locking mech (interlock).this is the bit behind the port hole door frame at approx 3 o clock pos,where the door striker pin goes through hole.
Held on with 2 screws and you need to remove plastic clamp from door gasket to gain access.
Check the Door Switch/interlock or the WIRING for failure in this case and repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 06, 2009 | Washing Machines
E40 on my washing machine
E40 is an error from the door locking mech (interlock).this is the bit behind the port hole door frame ,where the door striker pin goes through hole.hope this helps you.held on with 2 screws and you need to remove plastic clamp from door gasket to gain access.
E40.door not locking.door interlock faulty or triac faulty on pcb
hope this helps pls do let me know
Feb 20, 2009 | Zanussi ZWF1430W Front Load Washer
Washing Machine does not work and shows error code E40
E40 is a door related problem. Possible causes are faulty door interlock or door circuit triac on the main PCB.
Most likely cause is the door interlock.
Nov 14, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi zjd1219
Hi
Machine is showing E40 ERROR
Sep 07, 2008 | Zanussi ZJD1219 Front Load Washer / Dryer
RE: ERROR E40 ON ELECTROLUX ZANUSSI JETSYSTEM 1200
hi there e40 fault could either be your door interlock or main pcb
Dec 11, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi IZ161W Front Load Washer Logo
47 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
