Question about Rancilio Silvia Espresso Machine
Is there a repair manual for the rancillio silvia
    President:
  • 1,618 Answers
There is not a repair manual for the silvia, the most that can go wrong is the 3 resettable thermostat on the top of the boiler, remove the 4 screws on top of the machine for access. Unless you run the boiler dry. Then if the thermostats did not kick off in time then you will need a new boiler. You will notice a discoloration in the water out of the group or the steam valve.
Posted on Jan 05, 2011
3 Suggested Answers
JetJedi221
  • 25 Answers
SOURCE: Rancillio silvia
Could be several things.
Is it new and the right one?
Sometimes the gasket gets loose and comes down a little. Try pushing it back up with something that won't puncture it (such as the non-writing end of a Bic).
Make sure that the basket is pushed in the handle all the way.
Posted on Jan 08, 2008
SOURCE: Rancillio Silvia Steaming problem
Sounds like your Rancilio needs a service, this problem could be caused by the boiler not working correctly, possibly a leak from the boiler or a valve malfunction causing a drop in pressure.
Posted on Feb 25, 2008
I have a rancillio. The steamer works really well for about 15 seconds and then peters out???
Descale the boiler with citric acid.
  1. Turn off the machine and let it get cool
  2. Dissolve about a tablespoon of citric acid in the water reservoir.
  3. Turn on the machine and then pump about a cup of solution out of the boiler vent using the hot water switch.
  4. Turn off the switch. Close the vent
  5. Let the boiler heat up for about 5 minutes.
  6. Shut off the machine. Let the acid work for about 30 minutes.
  7. Check the level in the reservoir.
  8. Turn on the machine and then pump about a cup of solution out of the grouphead using the brew switch.
  9. Turn off the brew switch.
  10. Repeat steps 5,6, 7, 8, and 9 until the water runs clear.
  11. Wash out the reservoir.
  12. Turn the machine on. Pump a full reservoir water out the grouphead using the brew switch.
  13. Refill the reservoir.
  14. Have some coffee
Dec 02, 2012 | Rancilio Silvia Espresso Machine
I have a rancillio epoca dual head espresso machine, there are two gages on the front of the machine, steam is coming out of the top gage
You will need to get that manometer changed. Get a hold of a rancilio dealer and tell them you need a steam manometer.
Sep 29, 2011 | Rancilio Silvia Espresso Machine
How do I reset the thermostat on the Rancillio?
By removing the top four screws on the lid (with the water tank removed) and looking inside the machine you will see three (3) thermostats. The two (2) thermostats on the top of the boiler do not reset. Leave those be. The 3rd thermostat which is mounted on the side of the boiler facing the front near the switches is the safety thermostat. If you look closely you will see that in-between the connectors is a small circular button. Carefully push this in with something long and narrow (not an object that will conduct electricity) and the thermostat will have been reset. If this does not work and the button does not press in, you will need to replace the safety thermostat.
Jul 27, 2011 | Rancilio Silvia Espresso Machine
Temperature problem
Keep portafilter in the head with no coffee in it at all times, preheat portafilter and cup before you brew a coffee.
Apr 25, 2010 | Rancilio Silvia Espresso Machine
Rancillio Expresso Machine won't pump water through. Makes lound noise.
Hi There are a couple of things. 1. Your pump is not primed. Open the steam knob and push the middle switch. 2. Your intake hose is pinched or not connected to the pump, or your intake hose is not in the water tank.
Feb 21, 2010 | Rancilio Silvia Espresso Machine
Bad smell - like graphite, electric smell, water is not clear
check your metal hous from pump to tank maybe hous is old
Aug 29, 2009 | Rancilio Silvia Espresso Machine
Ground fault issue
This is not an unusual issue, but an unusual fix. When appliances that use water and heating elements use a ground fault breaker, it often thinks there is a problem to ground, since it is not the regular short to ground like an element. Move it to an area that has a regular outlet, and turn it on the first time. From then on, it should work right.
Dec 19, 2008 | Rancilio Silvia Espresso Machine
Rancillio and Verona commercial coffee machine spares
Espresso Dr. Located at Fortitude Valley. Ask for Michael.
Jun 30, 2008 | Coffee Makers & Espresso Machines
Rancillio silvia
Dec 07, 2007 | Rancilio Silvia Espresso Machine
Aug 02, 2006 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
873 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
