I have a le40c530f samsung lcd tv and i am unable to turn the tv on with the remote by any means even with the slight touch power and volume contols on the tv itself (they are located at the bottom right of the tv were the standby light is) i would like to know if i am able to fix this problem myself or am i going to have to replace the sensor
  • 2318 Answers
SOURCE: LCT32HA36
Check the capaciotors in the power supply for bulging conditions.
Click here to have an idea how they might look like.
Good Luck.
Posted on Jul 12, 2008
SOURCE: Power on problem for My Syntax Olevia LCD TV 23"
As suggested in another post, w2power has provided this solution. It is the only thing that has worked for me thus far. While it is a pain, I can at least consistently get my set to turn-on when using this USB cable method with logged-in PC attached to Olevia's service port (I have the 23" version)
From w2power:
"I think this model has a timer on it, it seems to go when the warranty runs out, not proven but Mine went out about a month ago. My only fix is to plug my tv (via the service port which is COVERED) to the usb port on my computer using my BlackBerry usb cable, in other words the Mini USB. Seemingly I must be logged on to do so and wait for the Chime form my pc, a balloon will pop up for new hardware not recognized (vista) then press the power button and then it turns on, unplug the usb cable and make sure the source is set to tv / video or else it will power back off and you will have to start all over. Theres NOT A PERMANENT fix yet but this is what I do every time I want to use the TV, I have a laptop so I use it as the Monitor just to watch movies. If you have a desktop I recommend keeping the cable handy BUT DO NOT LEAVE THE USB CABLE IN FOR LONG USES. THE SERVICE PORT IS COVERED FOR A REASON!!!
w2power_@_yahoo!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!_._com
Posted on Oct 09, 2008
SOURCE: samsung lcd tv power problem
Because the Samsung LNS4051D would not turn on and the power LED would blink 4 times and the relay would click and this would repeat again and again. I replaced power supply board parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors, three had their tops bulged up slightly that I missed on initial visual inspection. After seeing the reports of problems with these caps on http://www.fixya.com/support/t1336881-will_not_turn_or_off , I replaced them with Radio Shack part 272-1032, 1000 uf, 35v. They are slightly bigger, but fit OK. TV is working fine now. Cost was 4 x $1.59 = $6.36 plus the time. I saved between $100 to 300 in the process of either replacing the board or getting the unit serviced.
Posted on Dec 27, 2008
  • 3 Answers
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Posted on Dec 31, 2008
dsacco86
  • 1077 Answers
SOURCE: The tv will not turn on with either the remote or
Hi, I own the same TV and had the same problem. It's the #1 plaguing issue with flat panel TV made by Funai corp. Emerson is made by them. Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board.
The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can'tactually look at the tv over the internet. I can only make guesses with the symptom. I'm willing to bet you have the same problem like mine. One of six Inverter Transformers when bad on my Power/Backlight Inverter Supply Board. I replaced it and it works fine again.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual at Tvtechcenter.com; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $6. And most cases the new part cost less than $15. The service manual at the site is under LC320EM82S.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 13, 2009
Please help me - unresponsive remote?
that being a universal remote as i was reading means they have to be paired .
turn tv off .
go into program mode , hit sumpin on remote till it turns on your tv . hit save .
its something like that always but for your remote i don't find the exact instructions.
maybe if you give us the remote model number. we can find it.
Jul 25, 2014 | Samsung UN55F6300 55-Inch 1080p 120Hz Slim...
Comcast tv codes, samsung
Its quit simple to code search using the comcast controller.
Hold the setup button untill it flashes
Press 9 9 1 ...wait a second...press 1again.
Next hit channel up on the remote untill the tv turns off and this may take some time. When the tv turns off press setup to save the settings and try to power the tv on with the comcast remote. If you find that the controller will work the volume and turn the tv off but will not turn the tv on you are on a slightly wrong code and you may need to code search again.
Aug 08, 2010 | Samsung UN32C6500 32 in HDTVReady LCD TV
My tv is block and i dont know wat to do. how can i unblock it?
Don't use the remote control the signal it block.Go to ur manual contol on the tv right side.Push the power button to turn tv on.Push button Menu now U in the tv Menu,Use the volume + or - button move the Menu function to OPTION,now use the Channel + or - go down to the word said Operation lock out(ON) Now push manual contol button said INPUT.Now the word said Operation lock out(OFF).Now remote control is relase,u can use the remote control now.Tell me this work ok.This is how i unlock the Sharp Aquos tv.
May 09, 2010 | Hisense TL1700 17 in. LCD Television
I just connected a new Samsung LED/LCD TV. I am
programm the remote to your tv by pressing the TV button till all lights light up at the top then enter your 3 digit tv code ( samsung codes are 738, 516 or 680 then press pound. this should enable you to controll power and volume, be sure to press sat to operate you dish recvr.
Oct 07, 2009 | DISH Network Televison & Video
Only vizio light on
Dec 30, 2008 | Vizio L32 32 in. LCD HDTV
Only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
BEKO TRW325 TV. Frozen on chanel 1.
I turned the TV off. I held in all of the (4) buttons on the front of the TV and turned the TV back on again....this seemed to free up the remote control access and I was able to work the TV normally. The four buttons were the channel and the volume controls.
Dec 25, 2008 | Beko 324250WN 28" TV
The volume control is stuck
you didn't mention even using the remote. any way if it does not control even doing manualy or with remote control contact the dealer of you tv and discuss the problem. This could happen now a days LCD tv's has a program to operate. i suspended the program of your tv has reset.
Mar 26, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Televison & Video Logo
213 people viewed this question
Top Televison & Video Experts
Electro Med Services...
