Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony pre-LCD 32" receives power and directly
  • kidtechbg Jan 04, 2011
    Thanks for the added layers of information + sadness, although (like most electronics) they have shorter lifetimes. Is there anything I can repair on my own or reasonably hire a technician? Back engine of TV is totally enclosed.
  • kidtechbg Jan 06, 2011
    For a minimal investment and maximal pain, having to anticipate replacement is another chapter. Judging from the response, spending a fortune to repair the unit is silly if a flat-screen replacement, of the same dimensions, is necessary. **Somehow, I think there may be some A/B unit & hookup interference with connected devices. With my amateur expertise, it's possible to disconnect some wiring to know if wattage problems, using Verizon FiOs may be contributing to "no picture" problems. Thanks...
    Brigadier General:
  • 8,909 Answers
You have a regulator problem in the power supply. Possibly capacitors, (tuning).
As a company, I cunducted research on the average life time of a TV.
Rental sets, around 5 years.
Owned sets 6-7 years, before they become uneconomical to repair.
Hope that helpsw.
Posted on Jan 03, 2011
    Genius:
  • 1,126 Answers
The reason the picture is thinking is because the power supply is dieding, if you remove the back and look on the power supply module you will see a couple of electrolytic caps that is bulged, and need to be replace, or just buy a new power supply module and change it out and it will be fix.
Posted on Jan 05, 2011
How can I get Dynex TV out of "protection mode"?
the protected mode kicks in when there is a safety issue with the receiver. This usually comes from an overload to the system via a short in the system or perhaps a surge in power. Your receiver shuts down, and you'll need to shut the entire system down to fix it.
In some older homes, some of the wiring doesn't deliver the "cleanest" power, delivering minor power surges to the items you plug directly into the wall. If your receiver is plugged directly into the wall, purchase a surge protector to stop this
Read more: http://www.ehow.com/about_5516888_problem-sony-receiver-protected-mode.html#ixzz2ZYa9W0Mi
God bless you
Read more: http://www.ehow.com/about_5516888_problem-sony-receiver-protected-mode.html#ixzz2ZYZm8THG
Jul 20, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
Westinghouse 32' flat screen tv wont work with cox cable receiver
Hello
You haven't stated the type of signals that comes with your co-axial cable; analogue or digital. Anyway, you have to retune the TV after connecting it properly with Cox-Cable receiver with TV.
Feb 23, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
How can i connect my 32" sony bravia?because the
Route the television audio directly through a stereo receiver. Connect the audio outputs of the television to the audio inputs of the receiver, using digital (coaxial or optical) or RCA (left and right audio) cables. Connect the left and right stereo speaker to the corresponding terminals on the receiver. Be sure that the positive and negative terminals of each speaker and the receiver are correctly lined up
Use a cable box. If your television doesn't have audio outputs, as many older TVs don't, use the outputs from a cable box to route your sound to the receiver. Proceed with a digital or RCA connection as described for the TV
Use a VCR. If you don't have a cable box, run the cable from the wall outlet into your VCR and then instead of outputting the audio to the TV, output it to the receiver so that you'll get sound from cable programming through the receiver and to the speakers, rather than to the TV. Connect the video output from the VCR directly to the TV for the easiest setup. You will then need to control your television programming with the VCR.
Change the program mode on the receiver to the input category you used to input the audio; for example, "TV," "Cable" or "Aux" are common options. You should now be able to hear audio from television programs on your speakers.
Mar 01, 2011 | Durabrand 5.1 Surround Sound Computer...
I would take your A/B switch out of the line. And get yourself a good reciever to channel every thing.
Jan 04, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
We do not receive picture or sound, get "No Signal" message on screen. Receive static sound. Have tried resetting per instructions on Sony assistance
Tries unplug,replug tv and pay boxes back like about an hour later.Now tv and cable or satalite boxes are resetting itself back to the tv factory setting and cable or satalite boxes by rebooting and those pay boxes and updating it softwares.Now the the tv should work right again.If not call ur pay tvs providers get a another pay signals boxs.
Dec 11, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I just got verzion fios and I have a sony tv no signal
are you using an HDMI cable? verizon has a thing with hdmi connections to samsung for sure, cause i have the prob my self, and i'm sure the tech said sony too. if you have a usb port on it, you can update the firmware and that may help
May 01, 2009 | Memorex MLT3221 32 in. LCD TV
Connecting sony bravia to direct tv
select the correct scart socket used go though the av channels until you find the correct input[scart]
Apr 30, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Verizon Fios connection issue with RX-V663 Receiver
I had the same problem with RXV3900, was told by verizon and yamaha it's a software issue with the box. Verizon is suppose to be working on a new update, but no time frame for now. I'm using component to receiver, and hdmi to tv with no issues.
Mar 15, 2009 | Yamaha RX-V663 Receiver
No play back from HDTV to threater system
Do you have set-top-box or antenna-cable directly to TV?
You have connected TV with received via HDMI, but that won't work in this direction - TV has HDMI INput only, not output.
You can use HDMI to connect HDMI-out on DVD player for example to HDMI-in on receiver and HDMI-out of receiver to HDMI-in on TV.
But to get sound from TV to the receiver, use spdif optical or coax cable if TV supports that - this way you will get surround sound.
But also your connection via analog white/red RCA plugs should work, but only for stereo sound.
Jan 25, 2009 | Sony STR-DG520 Receiver
No picture, blue screen
Use the TV input selector to select the right channel, that should fix it.
Jan 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
604 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
