Question about Maytag Appliances Over-the-Range Microwave Oven
The turntable inside the microwave will not turn. I microwaved something large and heavy and was not quite centered on the turntable and ended up not allowing the table to turn. I heard a couple of popping noises and found out the the table turned freely with the microwave off. After some more investigating found out that the spindle that turns the plate comes out easily and is broken. Is this easy to replace and where would I find a replacement?
    Brigadier General:
  • 8,909 Answers
Replacement is through an authorised dealer.
Browse the manufacturer for a list in your area or try ebay, espares etc.
Hope that helps.
Posted on Jan 03, 2011
My microwave turntable stopped turning but the microwave still heats up and works, otherwise.
You didn't say what model microwave you have, but most that I have seen have two separate circuits inside. One operates the magnetron (which makes the microwaves) and the other operates the other things like the turntable or the inside light etc.. It is quite possible that you have a problem in that second circuit. This allows the heating without the turning. To fix this type of problem, if indeed that is the case, requires some skillful trouble shooting inside the microwave which I don't recommend your try unless you are a skilled technician, because of dangerous voltages. Go ahead and post the brand and model number and I can be more specific as to what action to take.
Dec 24, 2015 | Microwave Ovens
Microwave starts then quits, turntable doen't turn
At this time we recommend you locate an authorized service center using the below link. www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 03, 2014 | Panasonic Microwave Ovens
Phillips microwave oven vt255/bl tuntable does not rotate
HELLO.
The turntable is the unit in the center of a microwave that you set your food on. It rotates during the microwave cycle, making sure all parts of a dish are properly heated. These are typically made of either hard glass or microwave-safe plastic.
Your microwave turntable may not turn due to one of these problems explain below
(1)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properl on the turning mechanism.
(2)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable.
Most microwaves have different settings that the user can select with the press of a button, like a "Defrost" setting or a "Popcorn" setting. Certain microwaves may stop the turntable from turning during certain pre-programmed selection modes. Stop your microwave and don't use a pre-programmed mode. Instead, just specify the time using the number pads and start your microwave to see if your turntable begins to rotate again.
(3)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
FOLLOW THESE STEPS TO REPLACE THE FAULTY MOTOR.
THINGS NEEDED.
* screwdrivers
* replacement motor
* specific microwave information and part number
1 Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3 Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4 Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5 Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6 Reinsthall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Thanks.
Oct 01, 2011 | Whirlpool Microwave Ovens
Phillips whirlpool microwave turntable not turning
HELLO.
Your microwave turntable may not turn due to any of these problems explained below.
(a)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properly on the turning mechanism.
(b)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable.
(c)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
follow these steps below to replace the faulty motor.
1. Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 .Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3. Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4. Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5. Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6. Reinstall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Thanks.
Oct 01, 2011 | Microwave Ovens
The turntable on my GE Spacemaker Microwave JVM1640BB does not turn.... I can turn it by hand, but does not turn during cooking.
HELLO.
THINGS NEEDED.
* screwdrivers
* replacement motor
6 Reinstall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Hoping to help on more problems.
THANKS.
Sep 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave turntable no longer turns. Microwave still heats, but turntable has stopped working. What are likely causes? And is this something I can attempt to fix myself?
This is a common problem the turntable motor has failed, it can be replaced.. but Microwaves are VERY dangerous. Due to the enormous energy stored in the main Capacitor, this MUST be discharged to earth B4 attempting any repairs. apart from that though should be easy enough. I do recommend a reputable service center/man tho.
Jan 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable doesn't turn
remove bottom panel,< screws along front and tips down > the turntable motor is in the middle. Unplug motor and use multi-meter< insert probes into plug end > run short cycle with something inside of unit," glass of water ", if you have voltage here then the motor is bad and needs replaced. If not then mother board most likely problem.
Apr 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable mechanism is not working
you will have to take it off the wall. There should be three screws in the cabinet above the unit . 1. unplug unit 2 place a large towel under unit to protect stove or cabinet 3 have someone support unit while u remove threee phillips screws 4 the back will hang on the wall rotate down lift and remove. the turn table is usually ran by a rubber belt and motor. Hope this was helpful please rate me
Jan 12, 2009 | Sanyo EM-S8000 Microwave Oven
Microwave Turn Table
This could be a failing turntable motor, but more likely your turntable support has gotten bent. That's an easier and cheaper problem to solve. Excessive heat can sometimes make the legs of the support bend so that the center is raised up far enough that it won't always make good contact with the motor. You can test this by running the microwave empty for a few seconds. It may hesitate to turn or stutter. Next try it with a bowl with several cups of water in it. The extra weight may push it down so it makes good contact and runs without a hitch. The way I fix these is to use a stove burner or a torch to heat up the legs and bend them up a bit. Then I quickly set up or clamp the support so it's held in the proper position for a few minutes until it cools. One way to hold the heated support in position is to place an object under the end of each leg and put something slightly heavy on top of it in the middle. If you need a new motor or just want to see helpful exploded views of your model, see the GE or Sears parts Web site: http://www.geappliances.com/shop/prts/ http://www3.sears.com/
Dec 23, 2006 | GE JES1851 Microwave Oven
Sharp r-1610 microwave
It could be the turntable motor, the turntable support (with built-in coupler) or a problem on the control board. I would first look at the 3-legged turntable support with built-in coupler to see if it got hot and warped. It should be flat across the top from the center to the end of the legs. If the support's legs are pointing a bit downward, it will prevent the coupler from making contact with the motor shaft. I've held bent ones a few inches over a gas burner to heat them up where the legs meet the center hub, then set something a bit heavy on it to hold it in place while it cools. If it needs a new one, it is part # FROLPB025MRK0 and it runs $19.50 retail at Tritronics. A quick (but not necessarily definitive) test of the motor is to grab the shaft gently with pliers and gently try to turn it. If it moves slowly and makes a high-pitched whining noise, it's likely okay. If it won't turn or grinds, it is bad. The number for the new turntable motor is RMOTDA264WRZZ and it retails for $8.87. Please note that you may need to look under model R1600, R1600, R1601, R1601, R1610, or R1612. They are all mostly the same. Tritronics is at http://www.wehaveparts.com The service manual for the R1610, R1611, R1612 can be downloaded at: http://www.microwavedisplay.com/R1610.pdf There may be a grommet bewteen the mtoro and turntable support. Don't lose that! Be safe!
Dec 03, 2006 | Sharp R-1610 Microwave Oven
Maytag Appliances Over-the-Range Microwave Oven Logo
91 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
