Question about Nikon L35 AF-Beautiful point&shoot 35mm camera Film Camera
I have a Nikon L35 AF film camera and when I press the shutter button down it doesn't immediately come back up. Is this a permanent problem or is there a solution to fix it?
SOURCE: nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
Posted on Jun 01, 2008
SOURCE: Nikon one touch zoom 90 camera
I bought this camera at Value Village for $1.99. It came up with an E. I assumed this was an E for empty. I loaded a film and it is fine. frankvos@sasktel.net
Posted on Aug 20, 2008
SOURCE: Good day, I have
You are correct, there is a setting. Press Monitor, then Menu to get to the menu; go to the thitd menu option (looks like a pencil), select option 4 (AF Activation) and set it to ON (Shutter/AF ON). This will solve your problem.
Posted on Dec 31, 2008
  • 138 Answers
SOURCE: Nikon D40 will not focus when shutter pressed 1/2 down
has the lens stuck up? put it temporarily on 'M" and try to turn the focus ring. this should be freely turning;
otherwise you may want to check the camera body to lens electrical contacts (silver).. a small dab of alcohol to a q-tip.. make sure its not that wet..then try to clean the contacts.
Posted on Feb 09, 2009
SOURCE: Nikon L35, changing the ASA
turn the front ring around lens. It is bit hard but it will click as you turn
Posted on Feb 23, 2009
My Nikon L35 AF's shutter button won't pop back up when I press it down.
Hi Broderick,
You have some (dirt/ dust/ sand) clogged around the clearance between the shutter button and the camera body. If you are a DIY type of person, you can check and clean that dirt, other wise take it to a repair shop for proper cleaning.
Jan 14, 2016 | Nikon Cameras
I just bought a Nikon DX ...and I have used it twice on "self-timer" mode...but when I attempted to use it today....when I pressed the button down, it just wants to focus back and forth ant the...
When the lens moves in an out it is TRYING to focus. In some conditions the auto focus gets confused. Move your field of few and press the shutter button down half way to lock in focus. Then move it back (to original view) and finish taking the photo (pressing down the rest of the way).
Dec 21, 2017 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Just bought a nikon af l35 camera. Is it just a point and shoot camera? Wondering what the little switch on the front is for left hand side top as you look at it and the little switch on the side of the...
The self-timer lever is on the front of camera, to the left. The switch on the side of the lens is the backlight compensation lever.
You can download a copy of the manual from
http://butkus.org/chinon/nikon/nikon_l35_af/nikon_l35_af.htm
Feb 11, 2011 | Nikon L35 AF-Beautiful point&shoot 35mm...
I have turned camera on and set up to take a photo and the shutter release button will not press in to take the photo. I used the camera yesterday and it worked fine!
Turn the camera on and look into the view finder while you try to press the shutter button. Check the information in the view finder to see whether you are getting an error message. If you see an error message in the view finder, remove the lens cap and proceed to take a photograph but, instead of pressing the shutter button this time, press the button near the top of the camera on the back which says "AF/AE. If the camera takes the photo it means you have somehow initiated the auto focus/auto exposure lock which the camera will not override when attempting to take a photo using the shutter button. When you use the AF/AE button, you override this system. To remedy this issue, when you get the error message try pressing the shutter button again. Also, remove the lens to see if the shutter inside has frozen in the "locked" position. If you find this to be the case you will need to contact Nikon Customer Support. The link for Nikon Support is below. The numbers are half-way down the page.
http://support.nikonusa.com/app/answers/detail/a_id/238
Oct 31, 2010 | Nikon D40x Digital Camera
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
How do you load film into the Nikon N8008S
http://www.butkus.org/chinon/nikon.htm
Open back, insert film cartridge, pull leader to red mark, close back, press shutter button.
See above URL for a downloadable manual. For the N8008s you're better off with the F-801s manual.
Sep 16, 2009 | Nikon N8008 AF 35mm SLR Camera
Nikon 18-55mm AF-S/ VR lense shudder?
I believe you're hearing the VR in the lens adjusting. Try turning the VR off and see if you hear the sound. If not, then you have a normal operating lens.
Sep 01, 2009 | Nikon D5000 Digital Camera
Loading the N8008 camera
1. Set the film speed manually or DX to do it automatically by holding down the ISO button and turning the command dial.
2. Slide the camera back lock releases toward each other to open the back.
3. Insert the film cartridge on the left.
4. Pull film leader over to the red index mark on the right.
5. Close the back, making sure there's no slack in the film, and the lock releases snapped close.
6. Lightly press the shutter button. The film icon will appear in the LCD panel.
7. Fully depress the shutter button to automatically advance film to frame 1.
You can download a manual from http://www.butkus.org/chinon/nikon.htm
Mar 23, 2009 | Nikon N8008 AF 35mm SLR Camera
Feb 12, 2009 | Nikon L35 AF-Beautiful point&shoot 35mm...
Shutter won't open and film won't advance
You might have a dead battery. Check that.
Philip
Sep 28, 2008 | Nikon FE 35mm SLR Camera
Nikon L35 AF-Beautiful point&shoot 35mm camera Film Camera Logo
333 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
