Question about Grundfos JPS4 1 HP Pressure Booster Pump
My pump cuts in and out when the tap is turned on but now does not seem to pump the water up and does not seem to be sucking. what can I do? is there a manual I can down load on how to do it?
  • Grundfos Master
  • 43,501 Answers
If you have not had the electric shut off to the pump then there is a good possibility that the foot valve has gone bad at the bottom of the well pipe....this allows the water to back nto the well adn then the pump gets air in it...then the pump will not pump water....you may be able to get it to go but it will require filling the pipe(s) with water and then purging the air from the pump...
Here is a tip that I wrote about how to do that...
Jet Well Pump Well Jet Water Pump
heatman101
Posted on Jan 03, 2011
How do I stop pump from running? Cistern connected pump does not seem to be pressurizing. Pump not cutting off, and getting hot.
Pump probably needs to be serviced. It probably pressurizes a tank and when that tank reaches a pressure the pump is turned off. But just guessing.
May 27, 2015 | Plumbing
No pressure for onga pump
check for water supply to the pump
If it is a bore pump then check for enough water in the bore, injection pressure to lift the water. It may be necessary to control the output from the pump to maintain the injection pressure. ( put a tap on the outlet side and turn partially off)
check for sucking air at pipe fittings
Mar 08, 2015 | Cars & Trucks
Return port of the intex pump is sucking in water at the top part of the nozzle
If the debris that is getting pulled in is floating, lower the inlet to about 3 to 6 inches under the surface of the water.
Mar 17, 2014 | Intex Above Ground Pool 12x30"" Easy Set...
What causes a pentax smart head to cut off and on during use of water
There's not enough water running into the pump this is why its cutting out , hope this helps
Oct 09, 2013 | Plumbing
Your machine does not suck water from the main tap. If the water supply is turned on, water is supplied under pressure to the fill valve which must open electrically to fill the machine. Your water supply may be turned off or the fill valve may be failing to operate
Jun 27, 2013 | Kenmore 22942 Top Load Washer
Triton t200re shower
Paul. Is it only the shower that the pump cuts out? i dont think we have these pumps in AU. Would bet that its a flow issue. Either remove the water saving device in the shower, if there is one. Pr turn another tap on just a dribble when you start the shower?
We have these issues with "smart"? controllers that think there is a leak
May 19, 2013 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
I have a submersible water pump It seems to suck ...
That is pretty much par for the course with a submersible pump. Eventually the pump will be damaged by running dry as it depends on the water to keep it cool. Can't you set it up a little on something so it won't **** dirt?
May 20, 2010 | Garden
I have a Whisperflow pool pump attached to a Polaris Caretaker in-pool cleaning system. When the pump is turned on it pumps a great deal of air through the cleaning system plus the system does not seem to...
there may be some debris at the pump lid oring that is allowing some air to get sucked in. sometimes everything seems to be operating fine until the system gets up to full pressure. perhaps the pump has run dry at some point and the pipe that threads into the front of the whisperflo pump has broken the seal. make sure the pipe is dry and then turn on system. you can use duck tape or squeeze silicon sealer into threaded area this will usually at least allow you to notice that less air is entering the system that way you dont have to cut and replumb parts you don need to. you may want to check any valves that are in the pipes that lead to the front of the pump it is possible that the flap at the skimmer throght where the water comes in at the pool wall tile/water line is sticking up and or is getting stuck which will stop the amount of water needed to enter thru the skimmer basket area once the pump is in full prime this then lets the water drop inside skimmer basket area and air gets sucked into the pump then the process repeats over and over until the flapper is freed or removed
May 09, 2010 | Pool & Spa
Problem with Convertible Jet Pump 3/4HP RedLion - drawing water 300' from lake to cabin - when the pump is on it holds 50# pressure by itself but when tap is turned on the pressure drops to 30# then you...
If I understand you correctly this is what you have:
- A pump that draws water from a lake 300 feet from lake to your cabin (I assume the pump is at the cabin)
- The pump kicks on to maintain pressure in a tank that distributes water to faucets in the cabin. The pump only turns on to pressurize the tank when water is being used (I am assuming).
- When you turn on tap, pressure in the pressure tank drops to 30 psi, then you hear water sucking from the tank to tap and flow stops at tap. Then the pump finally kicks back on and pressures tank to 23 psi.
- The pump is not used regularly.
If water flow stops when the pressure tank is reading 25 psi, then likely the real pressure is 0 psi and pressure gauge is reading wrong. If this gauge is tied into a switch that starts and stops the pump, then this is probably your problem. You may have partial blockage in your pressure gauge/switch that is causing gauge to move too slowly to keep up with the actual pressure changes when water is being used. Ore the pressure gauge/switch may be broken. Pressure gauges are notorious for reading pressure when there is none. If you can unplug the pump and disconnect the pressure gauge/switch and check for blockage in the ports you should start there. You mentioned that this worked good for the last two summers, if if sits unused for long periods, it could promote bio-growth, rust and/or sediment in the connection to the pressure gauge. If you find blockage, remove it and flush it out. Reinstall the pressure gauge/switch and try it again.
One other possibility is clogged strainer(s) / filter(s) in the water lines. It would not hurt to pull and check/clean any strainers / filters in the system including before the pump. I would even check at the lake for a strainer where the water enters the suction line to the cabin.
I would not assume that the pump is the problem yet.
Hope this helps.
May 01, 2010 | Plumbing
Grundfos JPS4  1 HP Pressure Booster Pump  Logo
105 people viewed this question
Top Grundfos Plumbing Experts
john h
Andrew Bugbee
Are you a Grundfos Plumbing Expert? Answer questions, earn points and help others
