Question about GE PSS25SGNBS Side by Side Refrigerator
Water does not work. Possibly frozen line. i keep
Water does not work. Possibly frozen line. i keep adjusting the settings to the recommended Tag says, fridge should be 37, i set it but keeps going back to 32 and many items freeze. the freezer should be at 0, but keeps adjusting itself to #2 Any suggestions? Thank you, Donn
    New Friend:
I have a GE PSS25SGNA no ice no water freezer side is reading -2 refrigerator side 25 everything is freezing help
Posted on Jun 13, 2013
2 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: fridge works but doesn't isn't cooling
I will help but you need to confirm your model number. Is your model the one listed above your post? Let me know, Sea Breeze
Posted on Jun 20, 2009
Water dispenser not working ice maker okay water line to valves okay appears line in door frozen
GE has a fix for frozen water line in freezer door. WR49x10173 is a heater kit that is installed in the dispenser area. It uses a minor amount of energy, but enough to keep the area warm. You have to pull off the dispenser board, remove the 4 screws to remove the dispenser cradle and unplug the wiring. Then follow instructions to crimp on the heater wires. Allow about 3 days for frozen water line to defrost. .
Jul 15, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge keeps FREEZING food in my fresh food pullout drawer!
temperature sensor is not working
this part to control the temperature in the fridge
Nov 28, 2017 | Whirlpool Gold GI0FSAXVY 19.8 cu. ft....
Inside door water dispenser not working and a couple items inside fridge are frozen. The water started working again and now it is not anymore. I turned off the water line to the fridge because I am afraid...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 05, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
Water dispenser does not work on kenmore side by side refrigerato
remover the water tube from the lower section of the freezer door at bottom you will see this tube and a tubing connector,push and release the tube the line should drain out from the freezer door if not its most likely its frozen,use a hair dryer on the freezer door to defrost line and then reconnect line.
also adjust the freezer setting ti 3 no lower or higher..
nbcrca:)
Apr 11, 2009 | Kenmore Refrigerators
Cold water tap not working, house heating not as strong.
Okay let's trouble shoot this problem. The Hot water issue may just be that your Temp. control is not set as high as it was before it was replaced. Find the control on the water heater and check the setting. You can adjust it hotter from there, but it is not recomended to set it all the way to HOT. Just increase it at small adjustments and see if the water gets hotter. The Cold Water Tap issue.....Turn off the Cold and Hot water supply lines to the faucet. Remove the Cold water tap. VERY SLOWLY TURN ON THE COLD WATER SUPPLY and see if you get water coming out of the line. If you get water, then your line is okay. Inspect the valve to see if there is any debris in or on it. Clean and reinstall both taps and turn back on the water. It should work. Now if you turn the water on SLOWLY when the Cold water tap is removed, and no water comes out, Then you know you have an issue with the line going to the cold water side. (Frozen Line, Debris in supply line valve, Broken or Leaking Water Line) I hope this assists you........Joe
Jan 16, 2009 | Plumbing
Water not coming into my HE5 washer
Check that there is water coming from water supply, if not lines can be clogged or frozen.
If water is coming to the machine, but not entering into the drum, then it is a faulty inlet valve, or a faulty control, have parts tested and replaced.
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
2 things i want you to try before you call a tech out first under frezer door there is a connector where the 2 lines connect disconect both off now actuate the water at door if you get water out the line that means your line inside door is frozen 2 if you don't get water that means your water reservour is frozen so to solve problem cheapest way is to derost it by unpluging it for maybe 2 days and if it was frozen it should go back to normal and this time keep your temps in right settings refrigerator section at 37% and freezer from 0 to 4 % at all times that will keep lines from freezing
Oct 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
No water to door
Did you change any settings resently or move the fridge? Water line could be kinked. Could be a frozen water line. If the ice maker is set on rapid ice, turn it off. You could turn the temp setting down for a day to see if that helps. Do you have any leaks behind or under the fridge? Check the filter again, make sure you pulled the shipping tag off and that it is seated properly. Freezer temp could be set too cold. Make sure the freezer door closes properly and that there isn't anything hendering it.
Jul 07, 2007 | Kenmore 56722 / 56724 / 56726 / 56729
Open Questions:
GE PSS25SGNBS Side by Side Refrigerator Logo
100 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
