Question about Proscan 32LA25Q 32 in. LCD TV
I would like to know how to connect audio out from my Proscan 32" HDTV to a home theater system
  • 65 Answers
HDMI cable is the simplest solution.
Posted on Jan 03, 2011
I just bought a Samsung HD LCD 32 in TV and want to play it through my Home Theatre System. I set the TV to external speakers, put the HTS in aux mode, but I don't get sound. My old Samsung SDTV would...
If you do not have a manual for the machine down load one at http://www.samsung.com/us/support/downloads/LN32B460B2D
It will show you how to set up a Home Theater Connection
Connecting an Amplifier / DVD Home Theater
TV Rear Panel
1 Audio Cable (Not supplied)
Amplifier/DVD Home Theater
1 Connect Audio Cables between the
AUDIO OUT [R-AUDIO-L] jacks on
the TV and Audio Input jacks on the
Amplifier / DVD Home Theater.
When an audio amplifier is connected
to the AUDIO OUT [R-AUDIO-L]
jacks: Decrease the volume of the TV
and adjust the volume level with the
Amplifier's volume control.
Each Amplifier/DVD Home Theater has
a different back panel configuration.
When connecting an Amplifier/DVD
Home Theater, match the color of the
connection terminal to the cable.
Nov 29, 2010 | Samsung LN32B460 32 in. LCD HDTV
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
Is there a way to hook up the TV audio to a home theater system? Where is the audio out?
If you have a cable or satellite box, thats very easy to do, feed the audio from your box into the home theatre system. However, if your refering to just the audio coming out of the tv. Most Home entertain systems will allow you to plug the video line in with the audio line in, if your using basic cable, you have to use a VCR or DVR to access the sound, otherwise its impossible.
Dec 20, 2009 | Proscan PS32700 32" TV
How to hook up my 32" vizio lcd hdtv to my sanyo home theater
If your audio system doesn't have optical inputs you're going to have to use RCA (red and white) jacks.
I would suggest upgrading to a system in the future that does have optical inputs if at all possible. Excellent sound.
Jun 22, 2009 | Vizio VW32L 32 in. LCD HDTV
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Can't get the tv to play through the home theater
No they all are compatible with eachother no matter what brand tv,surrround sound. It is all in the hook up & without you stating how you have it hooked up,no way to tell because one siimple connection is all you r missing. You have it most way there if sound is ok on dvd.If you explain how you have it hooked up i can surley help you!!
Jan 23, 2009 | RCA L32HD31 32 in. LCD HDTV
No audio from tv to home theater
at the back off tv there is a connection labelled audio output you need to connect that to any available iput of your home theater receiver then use that for tv watching
Nov 12, 2008 | Vizio L32 32 in. LCD HDTV
No Audio Out through the Optical OUT jack
just press the DVD button on the remote contol and you will be ok.. :)
Jun 16, 2008 | LG LHT734 System
First and foremost when the chance comes along buy a Harmony remote. Your spouse will love the simplification. A couple of things, On the tv with the optical hose connected and the other end in your hand, do you see the light. Its not a laser and eye safe. Should be a red glow. If not, implies two things the tvs optical is bad or it needs to be enabled via tv menu audio settings. If you see the red glow, then its a protocol issue. Verify your tv is setup on the proper audio mode that your receiver is wanting to see. Probably PCM. I am not directly farmiliar with the tv, but using the dish receiver as a reference (you know its working) set the audio options on the tv similar to the dish receiver. IE pcm, dts, etc.. Let me know thanks
Jun 16, 2008 | Zenith C34W23 34" TV
Proscan 32LA25Q 32 in. LCD TV Logo
75 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
