Question about Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon efs17-85mm image stabilizer lens
When shooting with my 17-85mm lens,and it is set all the way at 17mm dark shadows cut the top right and bottom left corner of the image.
  • 3 Answers
Agreed with what Chris suggested. The lens hood must sit in properly at fully locked position. Need to use Canon orginal hood; other brand might pose a problem. Please bear in mind that a dark shadow will still appear at the bottom center if using build-in flash when shooting at 17mm; which is normal. When using 17mm, always use external flash or remove the lens hood when using build-in flash.
Posted on May 14, 2009
  • 36 Answers
This is called "vignetting". To me it sounds like your lens hood isn't mounted correctly. If you don't turn it on all the way, exactly this will happen, because the longer "leaves" on the hood shadows the edges of the frame.
So, try to turnt the hood all the way on. You might have to use a little bit of force, as the hoods can be hard to turn sometimes.
Hope this helps!
/Chris
Posted on Jan 19, 2009
I droped it =( 1- when i start the camara , i hear a shake or rarel in the zoom 2- in the digital view finder i see the image shaking 3- than it finally stops the image shaking right to left very...
Sounds like your image stabilizer got damaged by the fall. You'll have to get your camera serviced by an authorized Nikon service center.
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Nikon COOLPIX P90 Digital Camera
Hello,when i use it at wide end (17mm) the AF on a landscape (infinity) is very unstable. 50% of pictures are out of focus.This can be seen also on the distance scale: at one shoot it is at 3m , at second...
With landscape photography, especially with a wide angle lens, there is often very little visual contrast for the AF to lock onto. Try using MF for these shots.
Oct 01, 2017 | Canon EF-S 17-55 f/2.8 IS USM Lens
Lens will not change aperture setting.. it's stuck on F4. Should be able to change to F2.8 Michael
You'll notice that the maximum aperture is specified as f/2.8-4.0. The lens has a maximum aperture of f/2.8 only at the 17mm focal length. At the 35mm focal length, the maximum aperture is f/4.
Does the lens open up to f/2.8 when you zoom out to 17mm?
Feb 17, 2011 | Sigma 17-35mm f/2.8-4.0 EX Aspherical HSM...
Shadow on image yet nothing in front of camera. It is in the middle at the bottom edge of the image. It only appears when I set the lens so that it is all the way in at 17. I have a canon ef-s 17-55 f2.8...
Most likely it is dirt/dust on inside the lens. If it is in the bottom of the picture, the dirt will be on the top edge of the lens. If it is inside the lens, you will probably not be able to clean it your selves.
Apr 08, 2010 | Canon EOS Rebel XSi Digital Camera
Jammed Lens
take a look in this web.....maybe helps
regards
german
http://doekle.nl/canon_17_85_IS_repair.html
Apr 03, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Focus hutning with Canon EF-S 17-85mm f/4-5.6 Image Stabilized
I had this problem too, then my camera started getting Error 99 (there is some problem) and not working.
If you look at this website and follow the steps under Update 2
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
I think you will fix your problem. The connections between lens and camera probably have a little dust in them, use a soft rubber eraser to clean them. Make sure no dust or pieces fall into the camera or lens when cleaning!
Jul 28, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon EF-S 17-85mm - Stuck Zoom
this lens has a design shortcoming in it's aperture's ribbon cable ,the cable will rupture after around 1 year using, this problem taken place in more than 60% of owners with this lens. Canon has no respons with it problem and ask you send to their quick fix store for repair.
Jul 05, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Uneven flash
Look carefully at your images taken with flash... on the horizontal image is the lower part of the image slighty darker and have a rounded fall off at the edges? Is the vertical image dark side a straight hard line or is there a rounding to the top and bottom?
What we are looking at is if you have a very wide angle lens with the lens shade attached to the lens, then the built-in flash catches part of the lens shade and make a shadow on your subject... take the lens shade off and try the same shot and see if that makes a difference...
Have a great day...
Ed
Apr 03, 2008 | Nikon D40X Digital SLR Camera Digital...
Image reduced by dark edges
An adapter tube has to flare out at the end or it will cut the corners off at the wide angle setting. Telephoto should be ok though.
Dec 04, 2007 | Canon PowerShot A620 Digital Camera
Canon EF-S 17-85MM F/4-5.6 IS USM Lens Logo
247 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
