Question about Thermador SC302T Electric Double Oven
Oven light will not turn off - Thermador SC302T Electric Double Oven
  • Thermador Master
  • 2,605 Answers
Welcome to FixYa.
Does the light shut off if you push the door closed slightly ? Or if you push the door switch closed manually. It is located on the grill of the oven...i.e.
Let me know, if so the door hinge needs adjustment. If not, it may be a control issue.
I'll watch for your reply.
Macmarkus :)
Posted on Jan 03, 2011
  • Janie Cushing Dec 24, 2012
    I have the same issue and it still does not turn off when you push the switch manually. We've also tried to 'unplug' it and when you turn it back on, the light is still on... HELP!
How to change light in oven westinghouse florentine
Turn off the power to the oven. Grip the glass light cover and turn anti-clockwise. I think the lamp then unscrews.
Replace lamp, turn on power and check if lamp lights up, replace cover twist clockwise to fasten.
Jun 29, 2014 | Ovens
Oven light stays on all the time even when oven off.
Does your oven have a switch on the front panel for "oven light" or "light" ? If so, pushing it may turn the light on and off. Also, there may be a pushbutton on the oven's front edge where the door fits. The button comes out when the door is open and turns the light on. If you have one of those, the switch could be broken or defective. If the button is missing or damaged, it could leave the light on all the time.
Mar 22, 2014 | GE Monogram® ZET1PLSS Dual Single Oven
Did you try the light switch on the control panel? If it's turned on, the door plunger will not turn the light off.
Oct 01, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
I cannott get oven to turn on, asssume it is with the timer as light & grilll work. Model no 6381902
Light and grill work. I assume that the oven indicator wont light when you turn the oven on. If so the timer is probably in automatic mode. Set the timer to manual mode and the oven should work. If the indicator light is coming on at the moment the oven element is probably faulty.
Feb 11, 2011 | Ovens
Oven light
This is done to regulate the temperature. Higher heat settings will let the element stay on longer, while lower settings will turn it off sooner. Even on high, the elements may turn off periodically because there is a switch called a temperature limiter. Its job is to keep the element from overheating.
Aug 11, 2008 | Dacor MCS130 Millennia Electric Single...
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
Oven Light does not turn off
The problem is due to a faulty door switch, this is part of the door lock mechanism. The reason is that the oven thinks the door is open , this puts on the light and stops some of the oven functions ie the fan the fan element and probably the bottom element.
The answer is to fit a new door lock mechanism.
Mar 08, 2008 | De Dietrich DOP390 Pyrolytic Electric...
Magic chef oven wont turn on
yes oven ignightor to confim this try broil if it lights then its bottom oven ignightor get back wit me ill outline procedure
Dec 29, 2007 | Ovens
5 year old Jenn Air double oven
the door switch contacts are stuck closed causing the oven to stay on.if you can access the door switch try to wd-40 on it.if that doesnt help you need a door switch.
Aug 16, 2007 | Jenn-Air JMW9527C Stainless Steel Electric...
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
211 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
