Question about Tama Iron Cobra HP900RSW Rolling Glide Double Bass Pedal
I need a diagram for putting my tama iron cobra double bass pedal together. Do you have any suggestions?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • 63 Answers
It may not be a diagram, but sometimes, videos work wonders!!!
Here's how to put it together.
Hope that helps!
Posted on Feb 12, 2011
I want to build an amp that will deliver a bass drum sound for the stomp box I built.
As a 40 year guitarist and repair technician I had to laugh at this until I thought about my younger days of starting out. What I see here is that you made a momentary trigger out of a stomp box that apparently had problems, that you think you can build an electronic bass drum to play it with. Is this correct? See, the amp only gives a bass drum sound ONLY if a bass drum sound goes through it. Amps only provide audio power to the input signal. Where to get you bass drum sound is what you need to find. I believe you are thinking of a sample. A sample is an actual recorded sound of a bass drum that you could actually trigger by stepping on that button. You could find this on most cheaper casio, yamaha, emerson, radioshack, keyboards or drumpads or any of those amateur toys. Most of them allow a trigger pedal to be plugged into it and operational. Now, after you find something with a bass drum sample that you can trigger with your pedal, that device should allow you to plug it into an amp to amplify it. I hope I didn't confuse you much and had a close perspective of what you tried to describe. Please let me know if I can help further.
Mar 10, 2014 | Music
Im having problems attaching my Gibraltar Intruder Direct-Drive Double Bass Drum Pedal  to the bass drum
Does it hit the drumhead?
I guess you need to read the instruction manual, because double pedals usually have special way of attaching and tightening mechanism because it's larger.
Mar 03, 2014 | Gibraltar Intruder Direct Drive Double...
Hooking up two amps together
Yes. There could be big issues depending on how you want to "hook" them together. If you are wanting to simply run them at the same time (play through both at once) you can get a cheap signal splitter from GC or Radioshack and run your bass to the input, then output 1 and 2 to the respective amps. That is your best bet.
Setting up two amps parrallel does not nessesarily add power. That is to say that your 150 and your 350 "hooked" together does not give you 500 watts. In addition, there may be some issues with running a powered signal from the first amp into an input that is not designed for powered signals. Try the splitter or an old fashioned AB box. Safe and a cool trick. You can also use a stereo chorus pedal and let the signal chorus between amps. Makes the bass sound huge! Try it and good luck.
Jun 17, 2013 | Fender Music
Alesis dm6 bass pedal
There's a tiny switch on the back of the module "kick type" try switching that
Sep 22, 2012 | Alesis DM6 Electronic Drum Set
My double pick up Dean edge quit working while playing. I checked the wiring and all looks good, but three is s a black wire coming from hole to center of body attached to nothing. Looks like it never was....
Make sure you have two wires soldered to the output jack on the bass. having a wire lose is not purposely put like that, for no sound from the bass then that wire is either from the pickups and connects to the pots on the bass or on the output jack. I would suggest taking it to an authorized dean dealer to inspect the wiring.
Jul 13, 2011 | Dean Edge 4 Bass Guitar
I have an EDB 600 here and some of the wiring is detached; I would love to find some sort of diagram of the wiring so I know how to put it back together!
Try here for a 2004 EDB600. Newer years don't show up but they are probably pretty similar.
http://www.ibanez.com/support/wiringdiagrams
Jul 04, 2011 | Ibanez Edb600 Electric Bass Guitar
My ludwig L315FP bass drum pedal keeps bouncing and i have loosened the spring all of the way. I still cannot get it from multi hitting the bass drum. Help?
Go to YouTube and search for "Bass pedal" There are many videos. Select and view ones on "setup" and also view "technique". These will solve the problems you are having.
Apr 02, 2011 | Ludwig L315fp Accent Custom Single Bass...
My speed cobra double pedal has alwyas been fine but i think i must of set it up wrong or maybe damaged it because now the slave pedal beater won't touch the bass drum head, it's like a couple of cm's...
There are MANY adjustments and some may have slipped. The clamp of the beater to the shaft would be the most suspect. At each of the universals there is the possibility for loose setscrews. Also see if the chain on the slave could have SLIPPED one cog !!!
Feb 27, 2011 | Tama HP910LWS Speed Cobra Double Bass Drum...
Hello Tech, I beg your wisdom. My keyboardist and I love the Yamaha S80 but are stumped with an operational problem. The club blues internal 039 C07 patch sends an anoying ride cymbal strike with every...
I'm not familiar with this kind of keyboard, but it is almost certainly that you have 2 parts (2 instruments) layered together. In this case a bass and a cymbal. This is a feature, not a malfunction of every multitimbral keyboard. Multitimbral means you can play more than one instrument at the same time. This is good as you can create some nice fat sounds, but put the wrong instruments together and you'll have the problem you're experiencing. My suggestion is that you read what the manual says about layering or mixing parts. There you should find instructions on how to turn one of the instruments off. You can also try to google the words "how to parts layer (or sound layer, or combine sounds) on the Yamaha S80". Good luck.
Dec 16, 2009 | Yamaha Full-Size Keyboard
Tama Iron Cobra HP900RSW Rolling Glide Double Bass Pedal Logo
254 people viewed this question
Top Tama Music Experts
Michial Gueffroy
Are you a Tama Music Expert? Answer questions, earn points and help others
