Question about Emerson 025806092806 Microwave Oven
The plastic cover on the window of the door is peeling. iIs there any danger in this? Other than that the microwave is working perfectly. Does this cover or the microwave have to be replaced?
  • 472 Answers
As long as there is no metal or metalic surfaces the unit will be fine.. if you have scratches in the paint or metal becomes exposed the unit will start to spark.....
Posted on Jan 03, 2011
    Brigadier General:
  • 8,909 Answers
The plastic cover on the door stops food particles and steam entering the inside part that is not easily cleaned.
That's all.
It is like thick selotape.
  • Kate Oct 18, 2011
    Where can I get a replacement plastic cover?
Is my microwave safe to use if the inside of the oven is pealing?
Most likely if the metal screen in the door is intact. That screen and the metal cover on the back and sides surrounds the insides of the oven reflect the microwaves back into the oven. Just be careful about the peeling plastic inside.
Jan 26, 2015 | Microwave Ovens
Samsung microwave oven model smh9207st shows 5e
Try heating up touchpad with blowdryer , if that doesnt work replace touchpad.... On the smh9207st remove plastic cover from the back of the door . Remove 4 screws and 1 screw at the top of the door . Unplug two connectors Gently. ... Peel off front touchpad . Install is reverse of removal . Be safe .....part was $45 @ repairclinic.com
Jan 21, 2012 | Samsung Microwave Ovens
The plastic film inside the window on the door is pulling away from the glass. Does this consttute any danger. Does it or the micrwave have to be replaced? Other than that the microwave works perfectly.
The film stops food particles and steam from entering the part of the door that is difficult to keep clean. That is all it does.
No danger just difficult to clean.
Jan 03, 2011 | Emerson 025806092806 Microwave Oven
On the inside of the door of my microwave front window is an adhesive plastic covering that if you pull it off there is a black mesh screen exposed. is that clear sheet suppose to be removed.
The metal mesh is a filter screen to keep the microwaves in the oven while letting you see the food. The plastic sheet that's peeling off is meant to keep that screen clean. It's not supposed to be removed, since then food can get into the holes in the screen. A buildup of foods can lead to overheating and burn the paint and possibly damage the door. It should be replaced.
The part number is WB36X10068. A Google search turned up several sources. Here's one, but there are others. The new sheet has the adhesive applied, you just peel off the protective film and stick it in place. Clean the door inner surface first so the new sheet will stick firmly.
Good luck with the repair, and thanks for using Fixya!
Oct 17, 2010 | Hotpoint RVM1435 Microwave Oven
I have an older microwave oven and the plastic
i wont worry about it. it is for grease ewntrapment
Aug 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Leaking Microwave door seal (between grated and back of door)
I think that you can get the plastic wet, ie sponge, or lick.
Jun 26, 2009 | Microwave Ovens
Splatters between the screen and the glass on the microwave door
You can find helpful exploded view diagrams for most brands by entering your full model number here.
Those diagrams should show if the screen is glued onto the glass, etc. If so, it makes it harder to clean.
Nov 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Small tear on plastic lining covering the inside of the door
That clear cover (sometimes called the inner door screen) is very important.
It protects the metal mesh / screen from debris and corrosion. The metal screen allows you to see "what's cooking" (*grin*) but prevents microwaves from leaking out of the door due to the precise size of the openings in the mesh.
If the mesh rusts or gets grease or food on it, it can arc, and this can damage the screen, then microwaves can leak, causing a burn or fire hazard. (No "radiation" threat, though)
If no arcing or other damage has occurred yet, you can clean the area squeaky with alcohol, then dry it completely and use the smallest possible amount of clear Scotch tape or packing tape to cover the tear and make sure it's flat.
If this fix doesn't work, or it's too big an area, you will have to replace the sheet, which can be ordered.
You'd have to heat it up with a hair dryer, peel it off slowly, then clean the area with something like acetone, then peel and stick the new one.
If you need to or prefer to order it, I would need your brand and model number to help you further.
Oct 05, 2008 | Microwave Ovens
How do I replace the door handle on microwave?
Once you follow the youtube instructions to remove the inside cover you are ready for the next step.
Remove the six small screws that are adjacent to the window. After this the front plastic is held in only by plastic clips to the metal door. The plastic clips and the screws together hold this together.
Remove the entire door by lifting up and move it to a flat service. If the top vent cover prevents this just remove the two screws on top of the microwave and pull the vent cover off.
With the door lying flat you can pull the plastic frame out on top and bottom and see how the clips work. Now just work you way around the frame until it separates.
Install handle and reassemble in reverse order.
Sep 03, 2008 | GE Advantium 120 Convection/Microwave Oven
Emerson 025806092806 Microwave Oven Logo
230 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
