Question about Whirlpool Duet GHW9150P Front Load Washer
My washer is stopping in the middle of a cycle and then displaying f21 on the display screen what does it mean?
  • Whirlpool Master
  • 1,902 Answers
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Posted on Jan 03, 2011
Flashing display 7 mins into cycle. Water drains away and eventually display goes blank. Help?
Do you get an F21 code or some other code.
An F21 code means the water is not draining away properly. There may be plugged pipe.
Here are some tips to help you:
1. Check to make sure the washer's drain pipe is draining properly.
2. Check the drain hose to see if there are any kicks or clogs in it.
3. Check the washer for excessive subs. Sometimes excessive subs can also keep the water from draining.
Of course, the above tips are useful only if you have a F21 code. If you have other error codes, you'll have to look at the manual that came with the machine.
Feb 22, 2013 | Washing Machines
What does it mean if the washer is not draining and has a flashing f where the time shows?
I have the manual for this machine. Under "Code 21" it says the following:
"F21" (Drain Problem) Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Is the drain hose kinked? Is the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96" (2.4 m) above the floor? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service.
For "SUDS" code, the following:
"SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
Here is some more information that may help you as well:
"F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
I hope this is of some help to you, Please rate and comment, Thank You
Joe
Sep 07, 2011 | Kenmore HE2 Plus Front Load Washer
What does F21 mean on the digital screen?
Hi
Error F21 means F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Kenmore Elite 45986 Front Load Washer
My washer stops in the middle of the cycle and displays F-1 and after I have to set it on the rinse / drain cycle to complete. Today for the first time it also displayed 5d at the end of the cycle.
5d or Sd means too much detergent was used. Try the following
Run the unit through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Jun 29, 2010 | Kenmore HE2 Plus Front Load Washer
Error code f 21, what does this mean?
The error code F-21 refers to Long Drain. The washer has sensed that it has not drained out completely and cannot go into further cycle.
If yours is a HE 2 washer, afer few minutes, Sd error will be displayed and then after couple of minutes F21 error code will appear. Water valves will be turned off and stops running.
If yours is a HE front load, when drain time exceeds 8 min, F21 error will be displayed. The water valves will be shut off and pump will stop running.
Generally, by re-storing the power to washer, it may fix the problem.
You may press the pause or the cancel button twice to clear the display.
You may have to double check the drain hose to see if there are any kink, clogs.
Also, you may unplug your washer, turn the circuit breaker off for 1-2 minutes and then plug it back in to check if it works. After this, check to see if the washer drains.
May 18, 2010 | Washing Machines
Gives me an OE on the display
It's the pump motor -Plug your machine and run a test cycle and check for some grinding noise. Pulled the pump out from under the washer instead of taking the whole thing apart much, much easier.
Apr 10, 2010 | Asko WL6511W Front Load Washer
My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F21 showing on screen
Take the bottom panel off of the washer and there should be a instruction guide in the washer that will tell you what the error code indicates.
Apr 01, 2009 | Washing Machines
Kenmore elite washer problem
LD stands for long drain, you probably have a bad pump or the pump is clogged with lint etc.
Jan 15, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite front load washer
I HAVE A KENMORE ELITE WASHER AND IT STOPS IN THEN MIDDLE OF THE CYCLE AND DOESN'T RISNSE. THE DISPLAYS SHOWS F21. CAN YOU LET ME KNOW WHAT THIS MEANS?
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
