Question about Refrigerators
We have a Whirlpool refrigerator, model ET1FHTXMQ04, with a water dispenser insode the refrigerator (not through the door). The water dispenser is now slowly dripping water onto the top shlf on the door. Is ther a gasket, o-ring or similar item that needs to be changed? Thanks
3 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: built in water dispenser drips/leaks (fridge model
It is very possible that the water control valve on the rear of your refrigerator needs replaced. It would also be a good idea to install a pre-filter before the water gets to the water control valve. I believe the side of the valve that controls the water dispenser is stuck open slightly allowing water to drip. You can test by disconnecting the wires to the dispenser side and see if the drip stops. When you press dispense water the dual water control valve opens completely on the rear for the water to flow. If the seal inside is defective it will leak. Here are a couple places to finds the Dual Water control Valve
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Just enter your part number or model number or click on the photo on the second site listed. They are both good suppliers. Let me know if this is helpful or if you need more help Thanks, Sea Breeze
appliancepartsoutheast@live.com
Posted on Aug 10, 2009
  • 105 Answers
SOURCE: in-door water dispenser drips water
replace water filling valve as it probable has dirt between valve seat
Posted on Nov 21, 2009
Water dispenser hose broken
Hi;
you would have to remove the door(and front kick panel) turn water & power supply off first. Unclip water lines and electrical connector on top of fridge. You will require food grade water pipe 6-8mm, this will slide thru the hole, have patients when doing this
Jul 06, 2010 | Whirlpool GC5THGXL Side by Side...
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
In-door water dispenser drips water
Nov 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
How to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Feb 18, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
