Question about Whirlpool Dishwashers
Water keeps shooting out of air vent when draining
  • 472 Answers
You have a blockage in the line ...will have to remove line under sink and clear obstruction....
Posted on Jan 03, 2011
Why does water in the fridge keeps accumulating
It is most likely that the defrost drain is blocked in the freezer causing the water to drain through the air vents into the fresh food area. You will most likely have to remove the rear panel in the freezer and pour hot water in the drain trough until the drain clears up and the water drains down the drain tube. You may want to place a small tub in the top shelf to collect all the water that will pour through the vents and have some towels. it can get very wet.
Some models have a drain collector in the control panel assembly at the back and this runs into a drain grommet. this collector can plug up. You will have to remove this and clean out the collector tube.
I have found that some Frigidaire and some of the Kenmore refrigerators made by Frigidaire have a problem with water droplets accumulating in the air duct and when it defrosts thee droplets run down and drip into the fresh food section.
Aug 15, 2014 | Refrigerators
Hi there.my split system-less than 2 years old-keeps dripping water from one end inside the house.
This means that your main drain is stopped up. It is a very common problem. What you will need to do is take an air compressor to shoot air or water inside the outside drain for the unit. Be careful not to shoot too much as you don't want to create a mess inside. Do it in squarts. If this solves the problem you will see allot of **** come out. If not then you will have to open the inside unit and clean the tray of the evaporator. Once you do this then you will need to clean the P trap in the drain as it will be stopped up.
That will solve the problem.
Jan 28, 2011 | LG Heating & Cooling
What
The drain that runs the condensation from the unit is plugged or trapped...the condensation then blows out the front...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 19, 2010 | LG Heating & Cooling
I have a quantum toilet that flushes normally but then syphons the water from the bowl Possible problem?
Look for your main plumbing vent that goes out your roof, is it pluged with a nest or something? When your drain system drains, it needs outside air from the vent to keep the system from vaccume lock. Same as vapor lock in the gas line on your vehicle. If the system is'nt getting air it will **** the water from the traps in your drain system like it is doing in your toilet. You may have to have a professional drain cleaner or plumber correct your pluged vent.
Feb 27, 2010 | Mansfield Plumbing Products Mansfield...
BURNERS WIL NOT LIGHT UP AND THE RED LIGHT FLASHES 3 TIMES INDICATING THAT SOMETHING IS WRONG WITH PRESSURE SWITHC
Check your vent termination and air intake for obstruction or debris. Inspect the vent pipe for sags that could keep water in the pipe and not allow it to drain back to the unit. Check for water in the inducer fan as well as any tubes to the pressure switch and to the condensate drain. Last thing to look at is the air filter, make sure it is clean.
Nov 30, 2009 | Goodman GMS90703BXA Heater
Vessel sink drain causes poolin of water.
YOU ALSO HAVE A VENT ISSUE, THE VESSEL SINK DOESN'T HAVE THE LITTLE HOLE IN IT LIKE A VANITY SINK, THERE FOR THE WATER IS GOING DOWN THE DRAIN BUT THE AIR CAN NOT COME OUT, YOU NEED TO INSTALL A STUDOR VENT OR AN INLINE VENT INTO THE DRAIN BETWEEN THE WALL AND THE TRAP CUT IN A TEE AND BRING A PIPE UP TO THE BOTTOM OF THE COUNTER TOP AND INSTALL THE VENT, USALLY HAVE TO PUT A FEMALE ADPT ON THE TOP OF THE PIPE THE VENT COMES WITH THREADS DO NOT GLUE IT IN PLACE, THEY HAVE A RUBBER FLAPPER THAT OPENS WHEN THE WATER IS GOING THRU THE DRAIN AND ALLOWS IT TO PULL IN AIR THEN THE FLAP CLOSES WHEN NO WATER IS RUNNING TO KEEP THE SEWER SMELL OUT
May 28, 2009 | Ultra Max Eden Bath Black Ultra Zen...
Window unit air conditioner
Sounds like a full cleanning job or the drain line is plugging up. First , check for A 10* lean toward the back of the unit for proper drainnage, 2- check for good air flow thru the front coils--(dirty filter --dirty coil and last ,add some clorox bleach all across the front coil while off>)
Aug 24, 2008 | GE APN10AA Portable Air Conditioner
Rv air conditioner leaking
I have the same problem....it is a negative pressure problem holding water inside the unit until it overflows the pan and runs into the duct system. why this occurs....I don't know....I cant find a problem with my air return, but as soon as you turn in off, the water comes gushing out the drains on the unit. I resolved this....temporarily....by twisting up a paper towel into a wick, and placing one end up into the drain tray, with the other end lying well out into the exterior case. This lets the water wick out and keeps the tray drained. I don't understand the problem and don't know what the permanent fix will be, except maybe cutting a hole and placing an intake vent directly below the unit.
Jul 16, 2008 | Dometic Rooftop RV Air Conditioner
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
