Mitsubishi vertical problem
Cs40507 no vertical at all
  • Tonymaryba Jul 09, 2008
    I found r943 open and we have no info on it and none is available I think it is 4.7 3 watt. the chip is la7833 and I changed a few caps that go bad on these.
  • 2,326 Answers
Have you done any work before using a soldering iron, multimeter, capacitance meter or oscilloscope?
I would suggest to check the vertical section of the TV and you will more likely find a defective vertical amplifier IC.
The part markings should LA7837 or 38.
Let me know if you need further assistance.
Posted on Jul 09, 2008
Mitsubishi 52" gray vertical lines appeared then
no 200v for video line open low value resistor for the 200v
Oct 17, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Vertical failure
It could be the vertical output IC but based on the model it could be solder issue caused by dripping CRT coolant which has a tendency to drip on the vertical circuits in certain mitsubishi models.
Aug 04, 2011 | Mitsubishi Televison & Video
I have lines like vertical hold is off but can't find ajustment
Thank you to "TheScreenGuy". He replied with an answer that says the vertical sync is automatic and that I need to replace the SSB. Thanks!!!
Mar 23, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi tv 40" cs40307 vertical shrink problem
thats problem is only a lose connection,if you know how to used a soldering iron ,solder the vertical section of your tv.
Dec 21, 2008 | Mitsubishi CS-40307 40" TV
Mitsubishi Television - Model CS40507
I would replace the cable and connectors to include the wall plate and connectors on both sides of it as well if this is duplicated on another set at the same location. If it is not some TV's will allow you to use both sides of the port. Most however have a side for digital and a side for analog signal and some will not allow the use of both sides.
Hope this helps you.
Sep 03, 2008 | Mitsubishi Televison & Video
Flay back tv mitsubishi model cs40507
Mitsubishi has offices in Brazil. Apparently, they are out of the consumer TV and consumer entertainment business for a number of years now.
With the phasing out of CRT television sets, I have my doubts you will find a flyback unless you can find a scrap TV of the same model as yours. You can also try eBay or others like that to see if you can find this part.
Jerry G.
Apr 14, 2008 | Mitsubishi CS-40507 40" TV
Mitsubishi VS 50607 Problems
Vertical output IC most likely needs to be re-solderd. However this model is famous for the CRT leaking coolant in the area of the Vertical output IC and corroding the solder. Check for a sticky residule near the Vertical IC indicating a leaky CRT seal.
Apr 09, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi cs40507 blown zener diode
It should be at the back cover, just where the model number is. If you have the TV open, it may also be found inside, maybe on or around the tuner area.
Feb 22, 2008 | Televison & Video
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
