Question about Seagate FreeAgent Pro 1TB External USB 2.0/eSATA Hard Drive
What does the flashing white lights mean on the Hard Drive along with a beeping noise?
    Genius:
  • 1,325 Answers
Hello
go to this link, select the OS you work with and get some information to help you with this issue
http://www.seagate.com/www/en-us/support/troubleshooting_assistance
Posted on Jan 03, 2011
Hard drive beeping noises
Never heard of a Harddrive beeping before, but I'll take your word for it.
The beeps you hear are BIOS Beep Codes.
The computer's way if telling you something is wrong, and an area to look into for it.
The beeps are a pattern, or Code.
For example; 1 Long beep, a pause; then 3 Short beeps.
One Short beep, pause, Short Beep, pause; and repeating over, and over.
So....................in your own words Eric, tell the jury where you were on the night in question?
Do you have any alibi's?
WHAT? !O_O!
I mean................what is the beep code you hear?
Plus what is the Product Number of the HP desktop computer?
This can be found on the back of the computer, in the white Service Tag.
P/N = Product Number
Post back in a Comment.
Regards,
Ol' whats-his-name
I mean joecoolvette
Mar 08, 2013 | HP Computers & Internet
WD Myworldbook white strip flashing
The 'blinking' light simply means the unit needs tending to. Once acknowledged, via config, the flashing light will stop. Sometimes your anti-virus program will block you from getting into config. So you might have to turn your AV off.
Sometimes the blinking starts because the drive is over 95% full and sometimes it means one of the drives inside is failing or has died.
Run the WD Discover Tool, go into to "configure", & acknowledge that over 95% of the drive is used if that's the problem. Once you do that, the blinking light will go away & work like it did prior to the blinking light.. If a drive is failing then you might need to RMA it.
Jun 10, 2012 | Western Digital My Book World Edition II...
Please help, this beeping noise want stop and I hope I haven't lost all of my pictures, pleases help
The noise you can hear is not a good one, it is a seek error which means the drive is dead, there are companies who can recover the data but it is not cheap.
Mar 10, 2012 | Seagate Freeagent Goflex Staa500108 500 Gb...
When plugged into USB slot, Beeping annoying sound to begin with, followed by light flashing and Hard drive not being detected. Thanks
This issue is related to the hard drive, Have you dropped the hard drive at any time recently? If so then you may have lost your data. Since the hard drive is makeing a beeping noise then the head has died meaning the hard drive is dead hope this helps.
Apr 08, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
ChMy maxtor hard drive is making beeping noises when connected to my computer. It does not come up at all, it does beeps and stays beeping. Any suggestions?
step 1
Check the power to the hard drive also check all the connections on the hard drive .
Step 2
you need to get Spinrite HARD DRIVE DIAGNOSTICS and burn it to a CD and boot into BOS to run the CD and check the hard drive for errors, The beeps mean that the hard drive has a big problem.
if the problem is still there let me know.
Jan 23, 2011 | Maxtor Hard Drive
1st, my desktop (dell Dimension 5100) had been not used for several months. When turned on, the green error code lights 3, 4 and a flashing battery appeared, along with a beeping noise. I read up on the...
I assume your new computer has IDE controller on the motherboard.
Yes you can install your old hard drive into your new computer as a Slave hard drive.
If the old hard drive is installed on the 2nd IDE controller and it is the only device on the controller then the jumper and be master or slave, but connect the hard drive at the last connector on the IDE cable.
Oct 18, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Hard disk not recognised
When a hard drive makes a clicking noise, it is faulty. The clicking noise is the heads swinging back and forth. This hard drive is dead and the data is lost. If you desperately need to recover your data, there are companies that can recover and copy your data from faulty hard drives BUT it will cost you an arm and a leg for their services.
May 15, 2010 | Hitachi 120GB Hi-Speed Mobile Disk USB 2.0...
Red dot and beep
The problem is in most cases the Power Supply given is of too low of Wattage, at 1.5. After some time, it will no longer provide the drive the needed power, thus the red light.
Try another similar power supply of higher Watts (my Maxtor has it at 2.0 watts.
Try getting Higher power Supply from Radio Shack. Store Tech will Help you.
Lastly, inside the enclosure is simply a typical Hard Drive. Remove it and Slave it to your PC.
Jul 06, 2008 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
Packard Bell
Check out the following link:
http://support.packardbell.com/uk/item/index.php?i=topic_02437&pi=platform_storeandsave3500&dhepn=C050890000
It includes the following:
Beeping noise and flashing LED
dot.gif dot.gif Situation dot.gifWhen I turn on the Store & Save, it makes a beeping noise and the LED flashes continuously. dot.gif Details dot.gifThese symptoms indicate that the AC adapter is not providing enough power. dot.gif Solution dot.gifThe AC adapter will need to be replaced. I hope this helps, Bob
Mar 24, 2008 | Computers & Internet
Seagate FreeAgent Pro 1TB External USB 2.0/eSATA Hard Drive Logo
1,167 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
