Question about Samsung HCM4215W 42" Rear Projection Television
Samsung hcm4215w turns on and off again. Why? How can I fix this?
  • 39 Answers
Hi there
Try resetting the TV by unplugging everything, and wait 3 minutes, then plug in the power lead only, and turn it on.
Hope this helps
TV_Doctor
Posted on Jan 03, 2011
I have a Samsung hcm4215w you can hear samsung turn on chime but no picture.Please any advice would be appreciated.
Ur video backlight board is dead,not get power to the board to get picture,must replaced the backlight video board.
Another prob.u could have.
U have tv show sound,but no picture?
Ur inverter board it dead.
Oct 24, 2009 | Samsung HCM4215W 42" Rear Projection...
Samsung 42'' HCM4215W image looks like it's in #D
Ill have to look up the part numbers , but it is a common problem caused by the convergence board at the back of the device. replace the TDA*** for the color that is faulty and the problem should be solved.
After replacing the TDA*** you need to adjust the convergence again and perform an auto-fucus and convergense adjust again
Jul 08, 2009 | Samsung Televison & Video
Blinking power light after replacing convergance board.
Your chips are most likely bad or you bridged the soldering.
For all others with similar convergence problems
This is a common problem.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 06, 2009 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM 4215W when on, no picture timer blinks & chirp sounds
Sounds like a shorted component in the power supply or the high voltage circuit.
Time to call a professional.
Apr 10, 2009 | Samsung HCM4215W 42" Rear Projection...
Red Convergence Issue( Samsung HCM4215W)
Bad chips or faulty soldering.
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Dec 23, 2008 | Samsung HCM4215W 42" Rear Projection...
Red Convergence out on right side of the screen only
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Dec 08, 2008 | Samsung HCM4215W 42" Rear Projection...
HCM4215W SAMSUNG TV TURNS ON AND TURNS OFF AFTER ABOUT 5 SECONDS
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 29, 2017 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM4215W
Unplug the power.
Remove largest plug from convergence board. Plug in TV, see if it starts. If it does, then a convergence IC is are shorted.
Repair convergence
easyab
Jul 28, 2008 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM4215W,shuts off.
Sounds like a short in the power wire, it takes about 10 to 15 minutes to warm up then shorts out and when it cools down you can watch for 10 to 15 more minutes before it shuts off again, you need to take it in and have the powercord replaced because this is very hard to do from home and one mistake can make the whole tv not work.
Feb 27, 2008 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM4215W pink/green and wavy
Practice visual acuity technique!Check signal PCB for CRT coolant leak.Cleaning circuit board may restore normal operation,but one or more leaks will cause problems to re-occur.Change leaky CRT(s).
Dec 19, 2006 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
77 people viewed this question
Jerry Greenberg
Jerry Greenberg
