Question about Dryers
Winterize the dryer with a steam option - Dryers
WHIRLPOOL DUET GAS DRYER WGD87HEDW1
Unplug for 1 minute. Plug back in. Check status
Apr 17, 2016 | Whirlpool WGD87HEDW Duet WGD87HEDW 7.4 cu....
I ran the perfect steam option on my Electrolux dryer and ran the program but now the water continues to spray inside the dryer. How do I shut it off?
Thank you for your post, Travis!
I see that you are having a continuous spray of water inside of your Electrolux dryer from the Perfect Steam option. It appears that you could have an issue with your water valve or control panel. I would recommend performing a reset on your dryer and you can do that by flipping the household circuit breaker off for roughly ten minutes. If this does not correct your issue I would suggest having a professional technician for proper diagnosis and repair. This will help you avoid any future issues. Best of luck! -Matt
Mar 15, 2015 | Electrolux Dryers
How to turn off steam option from spitting out water?
You turn the water supply to it OFF! It's not pulling water out of its but. Lol.
Feb 22, 2015 | Kenmore Elite HE4 Electric Dryer
Samsung Steam Dryer has power but only displays a flashing smiling person. The dial will not turn and will not start cycle??
Maybe you press lock button, simply unlock it again try this one
? What is the "Child Lock" function?
• If you press the "Child Lock" button (Spin+Option button) longer than 2 sec during operation, this
function is selected.
• If once this function is selected, no change can be done until the end of laundry.
• Press the "Child Lock" button (Spin+Option button) longer than 2 sec to cancel the function
Jan 19, 2015 | Samsung DV419AEW 7.4 Cu. Ft. Electric...
How do I winterize the dryer
That's a great question, friend!
Your question is labeled under Electrolux dryer model EWMED7. I was able to locate your Use and Care Guide and there are no steps to directly winterize your dryer but you would need to disconnect the water line and verify no water has been left inside of your dryer. I hope this has been helpful. If you have any additional questions please feel free to reconnect. -Matt
Oct 06, 2014 | Electrolux Wave Touch 8.0 Cu Ft ELECTRIC...
I was drying my clothes and the steam feature would not turn off. How do I turn off the steam feature ?
Hi friend, thanks for your post!
I understand that the steam feature on your Electrolux dryer is not turning off. I would recommend a reset and you can do that by disconnecting power to your dryer for ten minutes. I hope this helps. -Matt
Sep 21, 2014 | Electrolux Dryers
Whirlpool cabrio dryer
Could be many things. Thermistor, water valve, steam generator, UI board. Need a model number to be further asisstance
Jan 27, 2014 | Dryers
Do I need a water line hookup for the steam dryer?
only if you intend to use steam option .l
Jul 25, 2008 | Samsung Dryers
Whirlpool Cabrio Electric Dryer with Steam option
yes the steam dryer is basic dryer with spray nozzle in rear wall to inject a fine mist of water..to be honest don't believe the stem option is all that great ..just take clothes and sprinke at kitchen faucet probably would have same effect
Jun 24, 2008 | Dryers
Dryers Logo
221 people viewed this question
Top Dryers Experts
