Question about Philips Medical
My Philips Envisor cHD ultrasound system is giving me an "internal error" message and won't allow me to scan images. How do I resolve this?
remt23c
  • 78 Answers
SOURCE: Out of paper :CDT009 Load mroe paper to continue scanning
on the admin utility go to the errors tab and remove the out of paper action, return error
the disadvantage of that is you have to click on the scan icon to start scanning.
Posted on Oct 15, 2007
SOURCE: Psp wifi internal error 80410a0b
I'd love to tell ya that there is an easy solution, but there is not. The error code simply states that the WiFi card is not working; you probably already figured that out! There are three possibilities: The WiFi card itself (most common), a resistor on the main motherboard (manufacturing issue, warranty), or the switch has gone bad (in which case you might be able to "short it out", but search on opening the PSP and you will see that this is straightforward for the very patient). The most expedient route is to (a) send to service or (b) get another PSP and test the WiFi before you leave the store. (And sell the faulty unit on eBay ??)
Posted on Jun 20, 2008
SOURCE: Can't scan to email for a Canon ImagineRunner C2550
You need to set the scan settings in copier settings 200dpi 300dpi color or black and white....
Posted on Jul 17, 2008
SOURCE: Using HpDeskjet f2280 All-In-One Printer,
You need to change the resolution on the scan to 200 dpi. I submitted this to HP and that is what they told me to do. It works. The steps to do it vary according to your HP Solution Center software version. Just find the "Scan to PDF" settings. In my case, I had to create a new "default" profile because it wouldn't let me modify the installed setup without saving it under a new name.
Posted on Jan 09, 2009
  • 92 Answers
SOURCE: canon image class mf5750 legal size paper
Hi ...
If you wish to print using a paper size which is different from the normal one A4, you need to specify the same to the printer else it will not recognize or will not accept the paper ...
Below are the steps that you can follow to:
1) Specify paper size
2) Specify paper type ..
Specifying the Paper Size At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [COMMON SETTINGS], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [PAPER SETTINGS], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select [PAPER SIZE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper size (LTR, LGL, EXECUTIV, A4, B5, ENVELOPE, or FREE SIZE), then press <Set>.
    black_dot.gif When [ENVELOPE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select the type of envelopes (COM10, MONARCH, DL, or ISO-C5), then press <Set>.
    black_dot.gif When [FREE SIZE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>. white_square.gif Use the numeric keys, or press <la.gif> or <ra.gif> to specify vertical and horizontal sizes of the paper in millimeters (mm).
    Available range in [VERTICAL SIZE]: 127 mm to 356 mm (5" to 14")
    Available range in [HORIZONTAL SIZE]: 76 mm to 216 mm (3" to 8 1/2") white_square.gif Press <Set>. Repeat the steps above to specify both vertical and horizontal sizes of the paper.
  6. Press <Stop/Reset> to return to the standby display.
Specifying the Paper Type [PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you can specify the paper type according to the following. Specifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
  1. Press <Menu>.
  4. Press <la.gif> or <ra.gif> to select [PAPER TYPE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper type, then press <Set>.
    You can select from the following paper types: - Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER] - Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1 - Transparency: [TRANSPARENCY] - Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1 - Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
    *2 A label that can be loaded in the cassette is a standard type (label standard card) only.
Please vote if this helps ... Cheers :)
Posted on Jul 27, 2009
I have philips envisor ultrasound.Is it possible to do echocardiographic calculation and measurment on an acquire image.
This is not done to often, it is called planimetry and is dependant on the skill of the cardiologist because most measurements are done during ultrasound. IT is also mostly used for Aortic Stenosis.
Sep 06, 2016 | Office Equipment & Supplies
Do not work philips envisor monitor
I have problem with my monitor philips 15'' there are seen three image
Oct 19, 2012 | Computers & Internet
My pc do not allow me to copy files and folder from one place to another and display error msg "Internal error 00000005" or "file integrity voilated".
It is an virus indication if you are using antivirus scan your computer it fix the problem automaticly and if no, so restore the system
Aug 02, 2011 | Computers & Internet
My hp scanjet 2400 stops at warming up then shows unexpected error. please help
Try connecting it on direct wall outlet.Not a surge protector or power strip
Try below solutions
An Unexpected Internal Error Has Occurred' Error Message Displays
Issue When attempting to scan, or, during the scanning process, the error message An unexpected internal error has occurred may display on the computer screen. There are three scenarios where this issue occurs. This document covers each scenario where this error may occur and provides links to the appropriate documentation for resolving each scenario. Solution one If you have multiple versions of HP Image Zone software installed on your computer, click here to download a patch that might resolve this issue . If you do not know if you have multiple versions of HP Image Zone installed, follow the instructions below.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Click Add/Remove Programs .
  3. In the list of programs that displays, look for the following entries:
    • HP Image Zone
    • HP Photo and Imaging Gallery
  4. If there is more than one entry listed, then there are multiple versions of HP Image Zone software installed on the computer.
  5. Click here to download the patch. Follow the on-screen instructions to download and install the patch.
  6. If the issue persists, try the next solution.
Solution two Clicking Scan picture or image in the HP Director software results in an unexpected internal error or causes the computer system to stop responding. Click here to resolve this issue (c00369826). Solution three When accepting a scan from the HP Scanning preview window, the scanner may start to scan and then lock up with the lamp approximately ½ way down the scanner bed. This results in an unexpected internal error or causes the computer system to stop responding. Click here to resolve this issue (c00373192). Solution four When accepting a scan, the scanner completes the final scan and the lamp returns to the home position; however, when the image is being processed or sent to the receiving application (that is, HP Photo and Imaging Gallery), an unexpected internal error occurs. Click here to resolve this issue (c00373192). Solution five Immediately after clicking Scan Picture from the HP Director when using an HP Scanjet 3970 with v2.2 software, an unexpected internal error occurs.
Try also this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00259434&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=297430
I hope you issue should be fix to lessen your frustrations.You can do it
Regards
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | Office Equipment & Supplies
When i try to scan, it gives me the following message "Undefined error occurred. (0x8021001F) A probably cause is that the system is unstable. Reboot the system. If this does not resolve the...
check in your scanner panel if there is any error showing like U 1 or any other message.if not then your scanner is perfect and check your system
Mar 21, 2011 | Fujitsu ScanSnap S510
Scansnap Scanner stops suddenly when scanning multiple pages and "hangs" for a little while, stating that it's scanning the same page, before giving an error message saying that it is offline. ...
I had this problem happen also and found that it was related to Acronis True Image Home 2011. When this program was uninstalled, the problem went away. I had even rebuilt the Windows 7-64 bit OS and the problem existed until Acronis was again removed.
Nov 11, 2010 | Fujitsu ScanSnap Manager
I am doctor who specializes in ultrasound. My problem is that the current DVD recording system we are useing to record our ultrasound studies have imperfect resolution. Can you recommend one that will...
I am sorry to ask you another question, but in order to give you the appropriate answer, I have to know your exact needs.
You want to record the images and cine loops and currently use a video/frame grabber to capture these signals into a computer.
If you are a specialized Ultrasound doctor, why don't you use the DICOM standard for storage and archiving? There are great free software packages out there you can use for this! It will give you the best medical solution for this purpose and if you need after exam measurements etc, all the image display information (pixel info etc.) is already available in the DICOM information. Any DVD recording will give you a limitation in these functionalities.
If you want to proceed with DVD recordings, please be aware that the average Ultrasound pixel resolution is 512 x 512. Besides this, Ultrasound is always noisy and kind of "blocky"..The DVD will never increase this quality and can only downgrade it if incorrectly setup.
If you need more help or information about DICOM use, please let me know and no, I will be obliged to provide you with more information about this great standard.
Nov 07, 2009 | Philips TV Tuner Video Capture PCI Card -...
Image not saving after scan
HP has an excellent online support site with access to troubleshooting solutions for your printer. I recommend you go there by clicking here and type the exact error message you are receiving into the question/keyword pane to get specific instructions for correcting this error.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 08, 2009 | HP PhotoSmart C4385 All-in-One Printer
My computer gives me an error message when i attach my MP3.
Go to Philips website
Get the updated Philips Device Manager for your model (rather than the one that came with the CD)
Once you have installed the updated Philips Device Manager, open it, and click on the Update button - it will update your player's firmware, which should resolve your issue.
If you are, instead, getting a message that says "File System Error" - return your mp3 player to the store or call Philips and see if you can get an in-warranty replacement.
-Tha Mp3 Doctor
Mar 06, 2009 | Philips SA3025/37 Flash MP3 Player
Medical Logo
259 people viewed this question
Top Philips Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a Philips Medical Expert? Answer questions, earn points and help others
