Question about Vacuums
I purchased one of your fans and installed in the summer, no problem and I am satisfied. After seven months one of the energy efficient bulbs has stopped working. I am no tree hugger, but energy bulbs good for seven years sorta made sense, but for seven months? I got in touch with the bulb people but they dumped it on you. Fan 20169-380, 14 watt bulb-0924235. The fan was purchased at home depot in Willow Grove PA. My name is Mark T. King, 1012 Lansing Street, Philadelphia Pa. 19111. e-mail-markthomasking@msn.com. Your immediate response would make me a happy camper. Mark T. King
reddevil6
  • 1673 Answers
SOURCE: KIRBY G4 FAN ASSEMBLY ORDER
First put the gasket on the spacer, thin end to to out, push it down all the way on the motor shaft, then put the nylon washer on, then the fan, metal washer and then the pulley, just snug it, (don't tighten too much just beyond hand tightening). Put the casing, top and handle back on.
Posted on Feb 05, 2008
reddevil6
  • 1673 Answers
SOURCE: I bought a ceiling fan
If this is a new product and it is defective, take it back to Lowe's and insist on a replacement, talk to the manager if you have to. This site will only advise you on how to fix it.
Posted on Mar 06, 2008
galati2k
  • 281 Answers
SOURCE: I purchased a hoover windtunnel
the filter stands up right.the bottom goes in first then snap in the top.turn it by hand and you should hear it click if you have it in right
Posted on Apr 10, 2009
  • 377 Answers
SOURCE: I have a ceiling fan
Sounds like a loose wire. If you turn the lights on via a wall switch or a pull chain, I would start where you hooked the wire for the lights to the house electricity, most likely where the fan meets the ceiling. Pull the "bell" part of the fan down that covers the ceiling box and see if there is a loose wire inside. There should be a plastic cap called a wire nut that covers the wire connection. Make sure it is secure and if possible, put some electrical tape around it. Please let me know if you have questions.
Posted on Sep 12, 2010
Testimonial: "Your suggestion was a good place to start. I couldn't find any loose wires, however, with the wires under tension the lights started working again."
  • 6 Answers
SOURCE: my hunter ceiling fan is
If the product did not come with a manual control on it then yes you will have to use the remote. However, if the replacement remote will cost nearly as much as the ceiling fan itself you could simply purchase a new fan.
Posted on Feb 28, 2011
My Hoover pure power 1700w upright, bagged vacuum cleaner shuts down after 5 minute's use. Although I purchased the pure Hoover power 1700w upright vacuum cleaner around eight years ago it has not u
Are the brushes worn down too far? As they wear the springs tension gets weaker. The brushes can also get stuck inside the channel they slide in. Could also be a buildup of dust etc inside and around the internal fan or commutator, etc.
Jan 18, 2015 | Hoover Vacuums
Hoover Core Plus Vacuum Cleaner is no longer cleaning properly. The button on the handle which when turned on has before allowed for a more efficient cleaning of my carpets and allowing easier movement...
Simple. The dirt sucked in is trapped inside a bag with tiny holes. Once these holes are clogged, the vacuum cleaner cannot do its job efficiently. Remove the 'bag' by opening the back, clean it of dust (do not wash it), replace it and close the cover. The cleaner will do its job properly again!
Jun 19, 2017 | Vacuums
I HAVE AN ARIES MODEL CT-298TF TOWER FAN THAT BURNED OUT AND I NEED TO CONTACT ARIES CUSTOMER SERVICE/WARRENTEE SUPPORT BUT THEIR 800 NUMBER IS NON FUNCTIONAL
I have same unit that is having problems this month. Was able to reach customer service at 8006453867 (number on the unit label). Got a ticked number and was told someone would get back to me about repairing or replacing. That was about an hour ago. Will wait and see. Do not have the original packaging, do not know the warranty period. Unit belongs to my roommate, I don't know when he purchased it. Think it was purchased at Walgreens. When did you purchase yours?
Mar 04, 2011 | Vacuums
My hunter ceiling fan is not working and according to hunter technical support, I need to replace the remote control receiver (part # 8511204000) at a cost of 50.00 plus shipping.is there a way to by-pass...
Feb 28, 2011 | Vacuums
A 40 W fluorescent lamp gives out more light than a 4o W filament bulb.explain whether the fluorescent lamp is actually using electrical energy at the same rate as the filament bulb??
The lamps are both using 40 watts of energy, but the fluorescent lamp gives more lumens (visible light measurement) than the incandescent.
Fluorescent gives at least 5000 lumens for 100 watts.
Incandescent gives 1750 lumens for 100 watts.
You can see that if you had a 100 watt incandescent, it would be 1750 and you would only need 35 watts of flourescent.
Gary
Feb 19, 2011 | Vacuums
I have a Hampton Bay Midili fan which I just installed about a month ago and it was working fine. A few days ago when I flipped the switch on the light flickered on and off consistently until I turned the...
in many of these remote controlled lamps you cant use the new spiral light bulbs .. you can only use standard incandescent lights .. if thats not the trouble then you may indeed have a bad controller (in the fan) .. there is probably at least a 90 day warranty maybe as much as 3 years .. make sure the wire nut power connections are secure inside the fan.. if one of the the wires in the fan are not making contact then you will see a similar problem .. once in a while i have seen strong external RF signals interfere with the controller but thats rare and usually doesnt last long ..
i would : 1. check all the connections .. 2. replace the light bulb to make sure its not flakey or the wrong type .. 3. try to get the fan replaced in warranty ..
Jun 06, 2010 | Vacuums
In the interest of saving electricity, is there any way to turn off all those annoying power indicator lights, charging lights, LEDs, etc? Like on the stove, microwave and nearly every other piece of...
Not much power is generated by those lights, I can assure you! Most LED bulbs are so small they only generate a fraction of money that a standard light bulb uses up. Especially if its just on household appliances. If you just switch them off at the mains and only use them when you need them as you would any other appliance youd be saving yourself some money in the long run.
Mar 28, 2009 | Black & Decker 15.6 Volt DustBuster Vacuum
I bought a ceiling fan from lowe's, got it home got ceiling fan up in the bathroom, when we put in the light one of the halogen bulbs does not work , also two of the cobalt blue glass covers are cracked...
Mar 05, 2008 | Vacuums
Vacuums Logo
37 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
